Old 08-17-2004, 10:08 PM   #1
pitcrew
Member#: 45715
1995 2.?L miami vice
Heavy Metal
Default P0453 code EVAP Fuel pressure high circuit
Just wondering what would cause this code? Would a vaccuum leak in the EVAP system do it?
Does anyone know where in the service manual the vacuum diagrams for the EVAP system are? I had to swap gas tanks and now I have a check engine light with this code.
pitcrew is offline   Reply With Quote
P0108 Pressure sensor circuit high input - How do I get rid of this? silentt Normally Aspirated with bolt-on Forced Induction Powertrain 9 12-09-2007 11:22 PM
CEL code P0106 Pressure sensor circuit range/performance problem (low input) crk4 Normally Aspirated Powertrain 4 07-17-2005 02:40 PM
What temp trips factory egt high circuit code? xFactor Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 07-04-2004 01:39 PM
need help with code P0463 Fuel Level Circuit high input? waitandbleed92 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 07-03-2004 11:54 AM
NA Fuel Pressure High after Pump Install [email protected] Normally Aspirated Powertrain 0 07-13-2002 06:21 PM
