Old 08-17-2004, 11:48 PM   #1
CMJ
Member#: 39235
Default Launch control without a mapswitch?
Is it possible to setup launch control w/o a map switch?
If so can you tell me how.
Thanks,
Chris
CMJ is offline   Reply With Quote
Old 08-18-2004, 06:17 AM   #2
TheMadScientist
Member#: 23717
2005 Big red
The Utec manual shows you how. I just did this in my car last week. You need to buy some pins to go in the molex conector. The corect pin #'s can be found in the manual. I also took my fog light switch and turned it in to an on/off switch for the LC.
When I get home I will post the part# for the pins you need.
TMS
TheMadScientist is offline   Reply With Quote
Old 08-18-2004, 07:30 AM   #3
Abe Froman
Member#: 22309
04 STI
05 LGT Wagon
TMS
Now that is an interesting idea...
Abe Froman is offline   Reply With Quote
Old 08-18-2004, 07:44 AM   #4
TheMadScientist
Member#: 23717
2005 Big red
I have two fog light switches now. I used fingernail polish to paint over one of the switches face plates and that one is for LC. The second one runs the foglights. It was an easy solution to finding a switch that would look good mounted in the dash. I think the fog light switches are ~$20 kinda expensive but the fit is perfect.
TMS
Old 08-18-2004, 09:39 AM   #5
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
the DIY version works perfectly for me, too.
i will be making my own map switch too, because i'm cheap. it will probably be only 1 bit (two different positions). i can't imagine needing more than one, and if you REALLY need to switch maps all you need is a phillip's head screwdriver to pull the kickpannel.
i'm thinking of integrating a throttle position switch to disable LC under say 90% throttle to make the system a bit more drivable. for example, with the LC on (and the clutch in) you CANNOT blip your throttle over your LC RPM set point. this is sometimes a PITA when you need to rev match a downshift. i've also hit the LC a couple of times while clutching with my foot not completely off the gas (ie clutch feathering). i've got mine set to 5300 rpms.
jm2c
ken
Old 08-18-2004, 09:50 PM   #6
CMJ
Member#: 39235
Found it.
Old 08-19-2004, 07:15 AM   #7
Abe Froman
Member#: 22309
04 STI
05 LGT Wagon
jm2c
ken
I've run into both those issues with the LC on but I have learned to live with it. If I'm shifting over 5500(my set point) I need to be quick with the clutch, it's easy and I rarely rev-match above 5500 becuase the car usually pulls better in the higher gear at that point but that's my driving style. My problem is I like the flat shifting so much I can't bring myself to turn it off .
Old 08-19-2004, 08:41 AM   #8
TheMadScientist
Member#: 23717
2005 Big red
Part # for the pins:
Digi-key WM2501-ND
TMS
Old 08-19-2004, 09:00 AM   #9
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
btw, those pins fit pretty nicely on the gm solenoid!
Old 08-19-2004, 10:45 AM   #10
TheMadScientist
Member#: 23717
2005 Big red
Really? I have just been soldering wires to the pins in the solenoid, then I just fill the conector with epoxy.
TMS
2009 Nissan GT-R acceleration times without launch control USCTrojan4JC Non-Subaru News & Rumors 28 12-09-2008 12:43 PM
Can Cruise control co-exist with launch control with the 2002 wrx Hydra? jigga Other Engine Management 5 04-17-2007 08:16 PM
Utec launch control tried out on my 03 wagon IA Performance Engine Management & Tuning 20 03-19-2003 07:07 PM
UTEC Launch control rev limiter? Typhoon Engine Management & Tuning 6 01-28-2003 09:08 PM
Launch control and flat shift...what do you think? Onederer Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 29 10-23-2002 06:40 PM
