Old 09-19-2000, 11:58 PM   #1
Kaffiene
Member#: 2113
Question how to tell if amp is toast?
Here's the deal. I had 2 10" subs in the back of m explorer before i bought my RS. about a week before i got rid of the car I blew the fuse on the amp. I just took evrything out instead of bying a new fuse because i had to take them out anyway. So now the amp and the subs are just sitting in my apartment. Here's my question...i want to sell the amp but i don't want to screw anybody by giving them one thats fried. how can i tell if it still works or not - short of trying to reinstall it in the RS (don't want to do that)
-Tim
P.S. anybody wanna buy 10" JBL subs in a ported box? They were only in the car for 6-7 months. great condition. I have RCA's too.
Kaffiene is offline   Reply With Quote
Old 09-20-2000, 08:22 AM   #2
ColinL
Member#: 114
'03 Evo, Rice White
'01 Erion CBR 929
Post
Option 1:
Get a DC power converter and use it to switch from 110VAC to 12VDC. Replace the fuse and hook up a speaker and a source, or a source and a multimeter. Speaker is better since a meter just detects signal, not quality.
Option 2:
Bring it to a shop and have them test it. Should be $20 to $40.
ColinL is offline   Reply With Quote
Old 09-20-2000, 11:15 AM   #3
cwhalgren
Member#: 1874
2007 WRB Sports XT
Post
You could do a very quick install job. Find something as an audio source (maybe a walkman) hook up a couple of speakers (your subs in the box) and connect the power to your battery and a ground to anything handy in your engine bay. I imagine you could hook it all up sitting on the ground in front of your car in driveway. This should tell you that it works at least.
cwhalgren is offline   Reply With Quote
Old 09-21-2000, 09:46 PM   #4
John2.5RS
Member#: 1140
2000 S201 #78, '95 L
'13 F150 Ecoboost
Post
Unless you had a fuze with more Amps than your amplifier was made for chances are you didn't toast your amp. Fuzes are made to burn out before you fry your amp.
<img src=http://geocities.com/r337m0nk3y/net/bandit.gif>
KD
John2.5RS is offline   Reply With Quote
Old 09-21-2000, 11:54 PM   #5
Kaffiene
Member#: 2113
Post
here's the tricky part. forgot to mention this. I replaced the fuse after i blew the amp. still nothing. but the was a 5 amp inline fuse running from i think the power wire (can't remember) behind the deck but i never took the head unit out to look. think that was it and i'm ok?
Old 09-22-2000, 02:55 AM   #6
Fitz
Member#: 1426
'07 335xi, '07 ZX6R
SV650 Race Bike
Post
As a guide...and a rough one at that... open up the amp and take a sniff. Every amp that I've fried had a distinctive "melted electronic componentry" smell.
Fitz
Fitz is offline   Reply With Quote
Old 09-22-2000, 06:33 AM   #7
ColinL
Member#: 114
'03 Evo, Rice White
'01 Erion CBR 929
Post
Are you serious, the amp uses a 5A fuse?
It's not worth repairing if there is anything burnt, unless you fix it yourself.
Old 09-22-2000, 06:26 PM   #8
ShaneW
Member#: 226
1999 Impreza 2.5RS
Rally Blue Pearl
Post
I would apply butter and taste it. If it taste like toast, it is toast.
I would recomend getting a stock unit from somebody on the list and seeing if the stock radio is the problem.
ShaneW
[This message has been edited by ShaneW (edited September 22, 2000).]
ShaneW is offline   Reply With Quote
Old 09-22-2000, 06:49 PM   #9
minix42@
Member#: 548
'98 Impreza RS
dinged up faded black
Post
the 5A fuse he said was "behind the deck".
this would be on the remote turn on lead, not the power.
definatly check this fuse... it would prevent the amp from turning on. If the Amp does turn on and nothing comes out you probably blew the output transistors. (fairly cheap to fix)
If it doesn't even turn on though, if it's not fuses you could've lost your power supply and who knows what else...
mike
minix42@ is offline   Reply With Quote
How to tell if diff is going? yelWRXlow1 Transmission (AT/MT) & Driveline 2 05-08-2006 06:16 PM
How to tell if something is real carbon fiber? sportz135 Interior & Exterior Modification 20 10-07-2005 09:09 PM
How to tell if strut is bad engr Brakes, Steering & Suspension 7 06-20-2005 10:18 PM
How to tell if clutch is slipping?? Crash477 Transmission (AT/MT) & Driveline 4 01-18-2005 12:55 PM
how to tell if turbo is bad? Costanza Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 04-24-2003 08:56 PM
