Old 08-18-2004, 06:13 PM   #1
pedrok82
Member#: 36175
02 wrx
black
Default accessECU
hello, this is probably a very newb question, but I have an safc and avcr on my car, would it be worth the reflash? And can I still use these if I were to get a reflash? thanks in advance.
pedrok82 is offline   Reply With Quote
Old 08-20-2004, 03:23 PM   #2
pedrok82
Member#: 36175
02 wrx
black
cant anyone answer this?
Old 08-20-2004, 04:42 PM   #3
clamdip
Member#: 18709
would it be worth a reflash? yes. the reflash will control your fuel and boost as well as timing. so you will have much more usable power at safer levels. and talk about smoothness, it's just awesome. however, if you get a reflash, you will need to get rid of the AVCR and SAFC since your fuel and boost will be controlled strictly the ECU. if you get a UTEC, i think you can still utilize just the AVCR, but not the SAFC. my advice, get the reflash, you won't regret it. the only thing, it's not user tunable. if you mod your car, you will need to flash another map into the ECU, unless you get the ecutek delta ECU which is user tunable using delta dash. hope this helps.
clamdip is offline   Reply With Quote
Old 08-20-2004, 05:22 PM   #4
pedrok82
Member#: 36175
02 wrx
black
it helped a lot thank you.
COBB AccessECU Warmwaffles Mid West Subaru Owners Club Forum -- MWSOC 19 04-10-2003 09:08 AM
Got the Cobb AccessECU Reflash Today... 2003WRX Engine Management & Tuning 5 03-29-2003 01:03 PM
AccessECU is here! silvercharged Engine Management & Tuning 19 03-22-2003 10:50 AM
COBB/AccessECU norseone Engine Management & Tuning 38 03-21-2003 11:52 PM
COBB AccessECU tuned today norseone Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 03-14-2003 02:08 PM
