View Poll Results: WIll it help spoolup?
Yes, it will spool faster (specify how much you think, or have seen) 16 76.19%
Nope, pure snake oil 5 23.81%
Voters: 21. You may not vote on this poll
Old 08-18-2004, 08:01 PM   #1
Davenow
Member#: 23676
Default Inlet hose, Spool faster or not?
In preparation for my new motor (next summer lol) I am going to do EVERYTHING in my powe to optomize spoolup
I started porting exh manifolds for my car today, I have already ported the P20 on my VF22 (with MUCH success), I plan on header wrapping the manifolds and up pipe (as well the crosspipe) and downpipe.
I have read nothing but good about the install of the perrin inlet hose. The entire reason I havent done one already, was being a puss about the install.
With teh perrin, that reason is gone.
But will it help spool? Even a 200rpm sooner spoolup is WAY worth it to me for the 249 bucks...
Will it happen? Is it snake oil?
Old 08-18-2004, 08:04 PM   #2
Red Rexx
Member#: 67187
2004 STi
Check this out my friend. I started this thread not too long ago and got good results:
http://forums.nasioc.com/forums/showthread.php?t=614639
Red Rexx is offline   Reply With Quote
Old 08-18-2004, 10:06 PM   #3
cnk
Member#: 10757
2013 BRZ Limited 6MT
It helped with my car. . spools up a few hundred RPM faster now.
Calvin
cnk is offline   Reply With Quote
Old 08-18-2004, 10:29 PM   #4
Scoobs2002
Member#: 64615
2002 Impreza WRX
GT42R Power!
IMHO I think thats a very over rated and expensive mod for the performance output it gives. I ran my VF22 setup for a while with the stock inlet hose @20psi on 94 oct and had no issues.....tried the perring inlet hose that a buddy had....didnt do much breathed a bit better, but thats about it.....I would do that mod when you have a bigger turbo that moves lots of air....then you would probally gain more bang for your buck!
Scoobs
Scoobs2002 is offline   Reply With Quote
Old 08-18-2004, 11:34 PM   #5
gjhsu
Member#: 12329
2o15 WRX
Ice Silver
helps with my car. 5th gear full boost is had at 2750 on mine.
uppipe, i/c hoses, inlet pipe, catback.
gjhsu is offline   Reply With Quote
Old 08-18-2004, 11:36 PM   #6
Unabomber
👏 Big Ron 👏
Member#: 18062
on car parts so PM
me b4 j00 buy
I say if you have the extra money go for it. Personally, I would love to have one of the AVO/BPM/MRT L shaped ones that replace all that crap, but $400 is way too rich for my blood. You might consider wrapping your turbo in Thermo Tec wrap as well. It will destroy a lot of heat soak issues and keep your turbo nice and hot. This might help spool a touch too, but I wrapped mine in conjunction with a P&P, I wasn't able to tell how much/if at all it helped.
Old 08-18-2004, 11:38 PM   #7
Davenow
Member#: 23676
DEI turbo insulation bag is what I am planning on. Stuffed under the jet hot coated factory heat sheild that I already run.
Old 08-19-2004, 01:17 AM   #8
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
I think that the inlet is an important mod, to be done along the way sometime, if you are going to mod to the point of going to a bigger turbo....OR....you want to squeeze the last bit out of the TD04.
For a bigger turbo, the AVO/BPM/MRT inlet would be the better choice, and if I end up doing anything other than the EJ20, that's what will be on mine.....the Samco or Perrin would suffice for an app using the TD04.
The biggest benifit that I saw was transient throttle response, and with a P&P turbo and P&P TB, I think that it would be well worth it, indeed.
Old 08-19-2004, 04:42 AM   #9
InfamousDX
Member#: 25413
How much was it to coat the factory heat shield Dave? And it's only the top half, correct?
-Mike
Old 08-21-2004, 02:22 PM   #10
Davenow
Member#: 23676
-Mike
its the entire whats left of it after it was trimmed for a TXS dp.
And I bought it that way from XXtuning for like 25 and my factory sheild
Old 08-21-2004, 02:46 PM   #11
subalou1
Member#: 57966
2002 wrx Sedona Red
[email protected], best trap 131
i did the mod not so much for performance, but my rigid factory one was getting holes in it after acouple of turbos were put in and out.
subalou1 is offline   Reply With Quote
Old 08-21-2004, 03:46 PM   #12
WRXBob
Member#: 12455
02 WRX
I did notice noticeable improvement in performance after the inlet hose installed. On my car, the stock hose was leaking and drive the ECU crazy. I think it is a worthy mod.
WRXBob is offline   Reply With Quote
3" inlet means faster or slower spool? ownnij Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 18 07-19-2008 11:57 AM
AVO turbo inlet hose for sale or trade for Sti front strut bar Thomas Ruble Private 'For Sale' Classifieds 4 04-14-2006 01:15 PM
Cop asked me if STi was faster or not!? Subaruist Southern California Impreza Club Forum -- SCIC 37 01-28-2005 07:38 PM
Faster...? or not? rukkie Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 09-04-2004 11:39 PM
Stromung midpipe...louder or not, faster or not? gtguy Normally Aspirated Powertrain 12 02-10-2001 02:19 AM
