Old 08-18-2004, 09:12 PM   #1
edkwon
Member#: 453
2014 Audi S4 B8
2016 Porsche Cayman GTS
Default CEL P0304 - cyl 4 misfire, want people's thoughts
Ok, i just threw a P0304 with the blinking CEL today. Here's the situation. I have an 03 WRX, here are my powermods:
UTEC piggyback ECU ver 4.2
TXS turboback exhaust with high flow cat
Stromung type XA single tip 3" muffler
replica Perrin solid uppipe
Sti ver 7 top mount intercooler
Basically, i was driving around the city puttering around no faster than 30 mph ready to go home and then suddenly i got the blinking CEL, quickly scanned and got the cyl 4 misfire code. The whole engine block is shaking like its offbalance with a rough idle and running in limp mode, much like the guy in this thread.
Now what i understand after doing some reading is it could be:
1. blown #4 cylinder (worst case scenario)
2. failed spark plug (replaced stock plugs with NGK copper plugs about 6K miles ago
3. burnt out coil pack
With my mods i realize Subaru would probably just void my warranty and give me a hard time, so i am probably going to do the diagnostic work myself, like moving the coil pack to a diff cyliner, inspect and possible change #4 cylinder plugs. I know that a compression test will ultimately rule out the worst case situation.
Just to get other people's thought, how likely is a blown cylinder if i haven't driven aggressively that day and was just going thru stop and go traffic no faster than 30-40 mph? Somehow i feel like its more likely a plug/coil pack problem than cylinder/block. I drive aggressively sometimes, but most of the time its normal city/freeway driving with an occasional WOT. I haven't been auto-xing or doing much aggressive backroads driving lately.
Ed
edkwon is offline   Reply With Quote
Old 08-18-2004, 09:25 PM   #2
Scoobs2002
Member#: 64615
2002 Impreza WRX
GT42R Power!
Ive seen that before and it was the plug and coil pack... needed to be replaced.
Might want to give that shot if its not too expensive to try...if that doesnt work.....I think you have to expect the worse case senario.
Scoobs
Scoobs2002 is offline   Reply With Quote
Old 08-18-2004, 09:35 PM   #3
MINO
Member#: 12841
Also, check the timing belt, cam gears, crank gear that they all are in spec. If you've over rev'd then yoor belt may have jumped a tooth.
MINO is offline   Reply With Quote
Old 08-18-2004, 10:22 PM   #4
edkwon
Member#: 453
2014 Audi S4 B8
Ok i just inspected the #4 spark plug area after talking to some ppl and found the whole coil pack/plug/cable thing that sits over the spark plug had popped out. I pushed it back in and the car ran fine, but there is a bolt thats supposed to hold it down and now its gone, i dont know how that came out but i'll have to replace it.
Ed
Old 08-18-2004, 10:56 PM   #5
Battlewgn02
Member#: 37770
02 WRXWGN
I had the same exact thing right after I put on a lightened flywheel, thought it was that, turns out the dealership re-flashed the ECU, all good now. Are you still under warranty, and do you have any mod friendly dealers in your area? Might want to check it out.
Battlewgn02 is offline   Reply With Quote
Old 08-19-2004, 03:54 PM   #6
WRXout
Member#: 52908
2005 WRX STI FTI 20G
ASPEN WHITE
i have this same problem, i have a cylinder 1 missfire 3 weeks straight once a week, and i have a cam seal leak, but i dunno what it could be
WRXout is offline   Reply With Quote
Old 08-19-2004, 04:44 PM   #7
pfhlipwrx
Member#: 19319
Aghhh...live with it, I have for the last 6 mnths...
pfhlipwrx is offline   Reply With Quote
HELP!! Cyl. 4 Misfire...? SubieStylez Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 04-16-2007 03:38 PM
Cyl 4 misfire simpreza2 Normally Aspirated Powertrain 3 03-18-2005 12:48 AM
Cyl 4 misfire, no drivability concerns... munkis Normally Aspirated Powertrain 11 03-28-2004 10:48 PM
Cyl 4 misfire only with borla headers munkis Normally Aspirated Powertrain 9 02-17-2004 11:10 PM
CEL P0304 - Cylinder 4 Misfire Detected Evan J. Kelly Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 03-08-2002 11:10 AM
