Old 08-19-2004, 12:59 PM   #1
STi_Drift
Member#: 25759
99 impreza
rally blue
Default Detonantion: Help
Basically I have the following setup. 22t on SOHC 2.5rs Heads with a vf29. I am running 18psi.
I am currently getting det at 4000 rpm on and my timing is set really conservative already. AFs are 11s.
Any suggestions? Thanks
STi_Drift is offline   Reply With Quote
Old 08-19-2004, 01:11 PM   #2
JenisonWRX
Member#: 6049
02 WRX & 99 RS
1. being even more conservative with timing
2. colder plugs
3. change gas stations
JenisonWRX is offline   Reply With Quote
Old 08-19-2004, 01:16 PM   #3
big_adventure
Member#: 40501
2005 Decathalon 21sp
One WheelSeanPower
What kind of EM are you using?
Can you log and post them?
What EGTs do you see, and where is your EGT probe?
FMIC or TMIC?
Where are you located? If you're in California, there is no way you'll be able to run 18psi from that turbo through those heads and (assumed) stock cams with >11:1 AFRs.
Where in the 11's are your AFRs? 11.3:1 is MASSIVELY different from 11.8:1.
We really can't give good suggestions without more information.
Thanks,
sean
big_adventure is offline   Reply With Quote
Old 08-19-2004, 01:20 PM   #4
Zola
Member#: 16876
2002 Impreza WRX
WR Blue
Also (implied in Sean's post), the octane of the fuel you are using would be helpful.
Zola is offline   Reply With Quote
Old 08-19-2004, 01:24 PM   #5
Wedge
Member#: 2279
2000 Slingshot
Pastelito Racing
Same question, whats your EM? And how does your fuel setup look like??
Wedge is offline   Reply With Quote
Old 08-19-2004, 02:28 PM   #6
STi_Drift
Member#: 25759
99 impreza
rally blue
ok. stock RS heads. I know the fuel in Canada is crap 91 (I know I know i was trying to tune to 91 then use our crap 94). so we won't go there I will be running 94 all day as of tonight. but I am using the Hydra as my EM.
AFRs are flat 11s all the way through. It really starts det at 5000rpm ... EGTs do not go over 1500 ( my sensor is in the header right after the flange).
For plugs I am using NGX BKRE7s. 3 ranges colder than stock.
As for data logs they aren't that great
Old 08-19-2004, 02:38 PM   #7
hippy
Member#: 36528
2002 Impreza Wrx
lower boost?
Old 08-19-2004, 02:39 PM   #8
STi_Drift
Member#: 25759
99 impreza
rally blue
lower boost? hell no
BTW timing is abour 19adv at that point around 5000rpm
Old 08-19-2004, 02:57 PM   #9
big_adventure
Member#: 40501
One WheelSeanPower
You will HAVE to lower boost on 91 octane with that turbo. There is just about no chance of running 18psi without det on that setup. Well, I take that back. You could probably do it by running lots of fuel (perhaps 10.3-10.5:1) and very soft timing (-3 deg from now). You will then, very likely, develop a hot spot and pre-ignite, burning a hole in your piston and making engine salad.
How about your intercooler? What are you using?
Remember, det itself LOWERS EGTs, and is more likely caused by over-advanced timing for a particular fuel/boost curve. Yes, this CAN manifest as high temps, but increasing timing in general LOWERS EGTs until something goes PING.
-Sean
Old 08-19-2004, 03:01 PM   #10
HOK
Member#: 447
1999 EJ22T222B&EVO
Are we racing yet?
drastic timing can also be a factor... if you are at 15 adv at max torque then to 19... i think thats too much...
HOK is offline   Reply With Quote
Old 08-19-2004, 05:03 PM   #11
STi_Drift
Member#: 25759
99 impreza
rally blue
its not drastic timing peak tq is around 3600 so its gradual to there. I have seen ppl run 23 and higher
Old 08-19-2004, 05:18 PM   #12
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
Sounds like you've got it all figured out.
jblaine is offline   Reply With Quote
Old 08-19-2004, 05:29 PM   #13
STi_Drift
Member#: 25759
99 impreza
rally blue
No... it's never figured out. I think i will have to lower the boost to 17 run much higher octane and run 10.5 AFs rather than 11 flat
Old 08-19-2004, 05:35 PM   #14
hippy
Member#: 36528
2002 Impreza Wrx
water injection?
Old 08-19-2004, 05:41 PM   #15
HOK
Member#: 447
1999 EJ22T222B&EVO
Are we racing yet?
lol hehehe
Old 08-19-2004, 06:46 PM   #16
BATSCUBIE
Member#: 56850
1987 WHEELCHAIR
CROME
This is big_adventure, on Ben's computer.
Peak torque is NOT at 3600. Not without the worst tune in history. The only way I can imagine it is if the over-advanced timing you're running in that range is giving you whatever peak you feel, then det starts and timing pulls, but you're just running through it. Bad bad bad.
Anyway, post your timing curve. The only information you've given substantively is that you're running 19points of timing at 5000, and 18psi.
You have not mentioned what kind of intercooler you're using. And you have not addressed the fact that you're running WAY TOO MUCH boost on 91 octane. I know you want to run 18psi. Well, get yourself some cans of Torco, or add water injection. A really good front-mount intercooler might let you get away with it. But it might not. That's the reality
I doubt that this motor will run more than 14 degrees hapily at 3500, and 19 is probably pushing it at 5K. And that's considering running 16psi rather than 19.
Good luck, perhaps I'll check back later.
-Sean
BATSCUBIE is offline   Reply With Quote
Old 08-19-2004, 09:20 PM   #17
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
....sounds like you TELLING the motor that it's gonna run the way YOU think it should run....or blow up tryin'....
Old 08-19-2004, 09:35 PM   #18
hippy
Member#: 36528
2002 Impreza Wrx
He said that he's been running 91 octane, but is going to be running 94 octane. That will probably help..... Lately, I've been feeling like I'm tellin my motor how it should run. My motor seems to like it though.
peace
Old 08-19-2004, 09:57 PM   #19
Uncle Scotty
Member#: 16200
OK buy Nates beans
Mine is strong as hell even as hot as it has been....lots of toluene helps though, too...
Old 08-20-2004, 12:11 PM   #20
STi_Drift
Member#: 25759
99 impreza
rally blue
lol I got it to work. All it needed was some good ol 94. I also advance the timing a number of degrees too. btw i can make 20psi now with no det
I am using the WRX TMIC, money says at am at the limit of it's capabilities
Old 08-20-2004, 12:15 PM   #21
big_adventure
Member#: 40501
One WheelSeanPower
You are at and beyond the limit.
It's amazing what the right gas can do. I moved from San Diego to Florida. It's hotter and more humid in Florida - not good for power at all, but I was able to lean the car out .3-.5 AFR everywhere AND add a pound of boost AND add some extra timing thanks to 93 octane gas versus 91.
-Sean
Old 08-20-2004, 12:18 PM   #22
Wedge
Member#: 2279
2000 Slingshot
Pastelito Racing
Thumbs up
What was your timing change?
I'm running 18psi daily on 93 octane, same setup as yours, with a T3/T04B snail and put down 286hp to the wheels.
Never det. once, and Clark even said, when tuning my car, that the engine felt real strong, and asked if I wanted him to keep going! (I chickened out, and told him to stop @18 ) EJ22T ownz all! , you should be just fine.
Old 08-20-2004, 01:07 PM   #23
ForesterPerformance
Member#: 5424
BRP STi Version 3
Type RA V-Ltd RHD
but wait? If he is running stock cams, it is very likely he is getting peak torque that early, no? Someone get their hands on Omarudy's dyno sheet and it will tell you!
ForesterPerformance is offline   Reply With Quote
Old 08-20-2004, 01:14 PM   #24
inpreza kid
Member#: 3334
the torque does peak fairly early. here is a dyno sheet of rs-t with stock heads off tech works website. i would imagine the torque curve is similar.
http://www.techworkseng.com/News/Releases/dynotest.html
inpreza kid is offline   Reply With Quote
Old 08-20-2004, 02:02 PM   #25
big_adventure
Member#: 40501
One WheelSeanPower
impresza Kid, the RS-T Stock turbo is MUCH smaller than a vf29. Notice where the horspower falls off.
Wedge, the T3/T04 you're running is more efficient than a vf29 - period. Plus, you're not trying that on 91 octane CAN gas. Ick - there is no way you run that on 91 with that turbo - it just won't compress that way without saying PING.
As for ej22T's ownzing - wanna race?
-Sean
Need Turbo Help!!!!!! 07subywrxtr Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 06-05-2010 03:52 AM
Need Help 06 legacy 2.5i problem BlobeyeSTi Mid Atlantic Impreza Club -- MAIC 9 06-04-2010 08:53 AM
A/C Pressure switch 94 Leggy? Need Help DjKlown Legacy Forum 2 06-02-2010 05:42 PM
Help with greasing up the bushings kmper02 Newbies & FAQs 1 06-02-2010 03:52 PM
EJ25 build, need help! rcarlson87 Built Motor Discussion 0 06-02-2010 10:36 AM
