Old 08-19-2004, 04:40 PM   #1
SYMSWRX
Member#: 1386
98 imprezaL
red
Default "DOG" at high RPM ??
Hello, I have a link ECU installed on my 98 impreza L with EJ20 motors.. every runs fine.. except the motor will "dog" some times during high rpm... usually happen at 2nd or 3rd gear... some one is telling me is running too rich.. is that ture ?
I'm running the base map for subaru.
Thanks
SYMSWRX is offline   Reply With Quote
Old 08-19-2004, 07:02 PM   #2
JenisonWRX
Member#: 6049
02 WRX & 99 RS
yeah thta would probably do it ...
you are running a 44s or a pro?
post some logs and lets see
JenisonWRX is offline   Reply With Quote
Old 08-19-2004, 07:26 PM   #3
SYMSWRX
Member#: 1386
98 imprezaL
red
hum.. I'm sorry.. I don't know how to put out the log... is a 44S I guess..
boost pauses at 9psi and climbs target boost at high rpms Serkan Factory 2.0L Turbo Powertrain 8 01-10-2011 03:01 AM
High idle with power power cutting out at high rpms subie9022 Factory 2.0L Turbo Powertrain 15 04-14-2009 12:21 PM
wrx stalls at full throttle at high rpms bluesubaru Factory 2.0L Turbo Powertrain 16 03-23-2005 05:50 PM
Rough idle and high-pitched whine at high RPMs fastenova Legacy Forum 10 11-21-2003 02:50 PM
High pitched wistle at high RPM when under boost. roybfr Factory 2.0L Turbo Powertrain 2 10-15-2003 12:22 PM
Message Board Statistics All times are GMT -4. The time now is 09:44 AM.
