Old 08-19-2004, 04:56 PM   #1
paullyt
Member#: 68576
Default Petrol in my Oil Sump pan
I have a 2000 Outback, and have found petrol in my oil. Have spent nearly $1,000.00 on trying to get Subabru to rectify the problem (under warrenty) but they found nothing wrong with the engine. One person said it may be petrol leaking through the catalytic converter, when the car is overfull of fuel, thus leaking into engine bay.
However, Subaru siad that I'll have to pay, to have the tests done, if they find nothing wrong?
Whew, spent lots allready trying to find the problem?
Any advice out there for a simple aussie guy. who doesn't know much about USA warrenties?
Cheers!!
Paul T
paullyt is offline   Reply With Quote
Old 08-19-2004, 06:49 PM   #2
BATSCUBIE
Member#: 56850
1987 WHEELCHAIR
CROME
This is Sean, big_adventure, posting from Ben's computer...
It can't be a cat - that's after the engine, in the exhaust. If fuel got in there, you'd have a fireball.
Anyway, gas in the oil: you're either running too rich by far, which is kind of common, or you have a ring problem, and need a compression test.
If it's fuel from rich run, you might have a sticking injector or a fuel pump stuck at 100% duty. Or perhaps a stuck FPR?
Good luck!
-Sean
BATSCUBIE is offline   Reply With Quote
Old 08-20-2004, 10:44 AM   #3
SubaruCO
Member#: 33566
Did this person tell you to check your blinker fluid as well?? j/k
Actually I just had to say that....BATSCUBIE in the post above has the correct initial diagnosis.
SubaruCO is offline   Reply With Quote
Very poor fuel economy and gas in my oil pan phibs Factory 2.5L Turbo Powertrain 21 11-26-2007 09:24 PM
Hole in my oil pan ROC pit-bull Tri-State Area Forum 5 07-09-2006 11:42 AM
WTB oil sump, pan, baffel and other random parts railguy Private 'Wanted' Classifieds 0 05-15-2006 07:31 AM
That screwdriver was in my oil pan how long?? crash South East Region Forum 53 03-17-2005 01:51 PM
Urgent--have a dent in my oil pan.... merlin8019 Normally Aspirated Powertrain 5 10-24-2000 02:03 AM
Message Board Statistics All times are GMT -4. The time now is 01:33 PM.
