Old 08-20-2004, 01:03 AM   #1
Sojuuk
Member#: 61423
2004 Outback H6
Champagne
Default let my car sit in the shade for a week and found a problem. 2.7mb worth of pictures.
well long story short car sat in my grandparent's car dock which is well ventilated and cooled for about a week. i come back and the car has trouble starting as in i had to give it some gas to get the engine to fully start. let it idle a bit thinking it just needed a good warm up. pop the hood just for a look over inspection and i find that about 4 hoses had leaked. they weren't currently leaking but they had been. Most likely they had leaked when i started the car because it was very fresh.
so i tightened the hoses back down and figured i was good to go. guess i was cause it got me home (134miles).
the 4 hoses were on the right side of the engine next to the washer fluid tank.
just wondering what anyone else can make of this because all i can think is the screws loosened themselves from being in a cool place for so long.....
which doesnt make much sense.
just gimmie any ideas.?
Sojuuk is offline   Reply With Quote
Old 08-20-2004, 01:45 AM   #2
runnyD
Member#: 50786
00 E46 Touring
They might be the fuel hoses, but that is weird for them to come off from the filter area.
runnyD is offline   Reply With Quote
Old 08-20-2004, 11:46 AM   #3
bhall
Member#: 56015
02 WRX Wagon
05 XT Forester
I second the fuel lines from your discription of location. Did they lead to a black can looking thing in the driver corner front (fuel filter)? Seems odd that they leaked but if they where a bit loose I can see it. Since the car was sitting for a while the system was not pressureized anymore. I guess when you cranked it up the pressure came back up and it could have squited some fuel out of the lines if they where loose, and this could explain the slow cranking time.
How did it run for the 130miles home? Any fluid once you got home?
bhall is offline   Reply With Quote
Old 08-20-2004, 12:43 PM   #4
KD7000
Member#: 16653
2012 Mazda 3
2013 Toyota Vanling
My fuel filter is silver. And it's not in the corner- it's tucked right between the washer fluid tank and the brake fluid reservoir.
But the fuel filter only has two lines- one in and one out. Sojuuk said he found 4 leaking lines.
I've only ever heard of fuel lines loosening up or leaking during extremely cold weather... Did someone recently replace your filter? Possibly just didn't tighten the hose clamps enough?
-Brian
edit: Another possible, albeit unlikely explanation, is that your fuel filter is so filled up with crap, that after the junk settled for a week, and the system was re-pressurized upon startup, the fuel just couldn't flow through at all...
KD7000 is offline   Reply With Quote
Old 08-20-2004, 01:30 PM   #5
bhall
Member#: 56015
02 WRX Wagon
05 XT Forester
See thats what I get for assumeing that the BE is like older models. Sorry
How does the fluid smell, feel?
Old 08-20-2004, 02:10 PM   #6
Sojuuk
Member#: 61423
2004 Outback H6
Champagne
yeahp it was the black can thing. i figured it was fuel from the smell but it was the thickness of oil but i guess that was from it drying.
and it ran great for the 130 and i did check when i got home if there was anymore leaks and it was all dry so i guess its fixed itself now.
perhaps fuel filter change?
Old 08-20-2004, 02:24 PM   #7
KD7000
Member#: 16653
2012 Mazda 3
2013 Toyota Vanling
Sorry
Don't know why you're "rolling eyes" at me; I only meant to try to clarify what parts we were talking about, nothing more.
Sojuuk- can you get a picture of your engine bay so we can see exactly which lines/ fittings were leaking?
--I'd feel somewhat hesitant that the problem has just fixed itself. Even though you've tightened the clamps up, keep any eye on 'em. There's no good reason for it to just start leaking like that...
-Brian
Old 08-20-2004, 02:43 PM   #8
bhall
Member#: 56015
02 WRX Wagon
05 XT Forester
-Brian
Not rolling eyes at you, rolling at myself for not check the model before posting. Did not mean to come across like that if it did, I apploigize.
I too agree that most problems dont fix themselves, it would be nice. A picture of the problem area whould help. Also when did you last replace your fuel filter?
KD7000,
Are there any breather hoses around that area, just wondering from the "thick oil" comment.
Old 08-20-2004, 02:52 PM   #9
KD7000
Member#: 16653
2012 Mazda 3
2013 Toyota Vanling
No prob, B.
There's a vapor collection cannister; on my car it's down next to the radiator. That's where some oily junk might collect, but it's not really under any pressure.
The only breather hoses I'm aware of are at the PCV valve over by the intake- but that's pretty far away from the fuel filter. Again, this is how it is on my '97, the '91 might have a different layout. Is the '91 a turbo?
Sojuuk- when was the fuel filter last changed? I'm thinking more and more that it's just completely clogged up with crap...
-Brian
Old 08-20-2004, 03:03 PM   #10
fibuz
Member#: 53410
BE-> GD->GR->SG->BL
WAawd.org
hrm, maybe its the blinker fluid [/stupid comment for the day]
fibuz
fibuz is offline   Reply With Quote
Old 08-20-2004, 03:17 PM   #11
gtwagon941
Member#: 16874
2008 2008 Audi RS 4
2014 Audi S Q5
fuel filter can be black. Mine is. I replaced it with a Napa one instead of OEM, so just the color difference doesn't mean that it wasn't the fuel filter....
gtwagon941 is offline   Reply With Quote
Old 08-20-2004, 04:26 PM   #12
Sojuuk
Member#: 61423
2004 Outback H6
Champagne
Default 56k beware.
lemme go snap a picture.
you can see where the hoses have been stained if you look closely at the huge images.
thank god i found that edit button.
okay yeah on the engine end of the boxed hoses there is actually 3 hoses all of which had leaked and were loose. the bottom one was not the screw tightening veriaty so i had to leave it be. but the rest i did tighten and they did seem rather loose.
Old 08-20-2004, 04:31 PM   #13
bhall
Member#: 56015
02 WRX Wagon
05 XT Forester
if you are talking about the hoses to the right, behind the washer fluid that is the fuel filter. It looks kinda old and rusted with the exception of that brand new hose clamp. What is the deal with that? Was it missing and you replaced it? Before or after the "incident". Was it tight?
Anyways I would replace that fuel filter and deep clean the engine bay. The finding leaks and there orgin is much easier.
Old 08-20-2004, 07:52 PM   #14
Sojuuk
Member#: 61423
2004 Outback H6
Champagne
well for all i know it could be the original , but i seriously doubt that.but the thing im talking about is black and not rusted. so either way the point is irrelivent.
anymore thoughts?
Old 08-20-2004, 10:41 PM   #15
KD7000
Member#: 16653
2012 Mazda 3
2013 Toyota Vanling
How many more thoughts do you need?
You need to change your fuel filter and replace some / all of those rubber fuel lines and hose clamps. Your old lines are not looking very pliable anymore.
--Actually, you should probably have your mechanic do the work. It's not necessarily difficult stuff, but if you don't get it right, you'll die in a fiery explosion.
-Brian
Old 08-21-2004, 10:08 AM   #16
Sojuuk
Member#: 61423
2004 Outback H6
Champagne
gotta hate those fiery explosions.
Old 08-22-2004, 04:17 PM   #17
Chi_San
Member#: 53558
2005 Baja Sport
Gray/Silver two tone
Sure bad for the liver, anyway.
Chi_San is offline   Reply With Quote
Please help!! Stranded after letting my car sit for 10 days!! silence2-38554 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 02-22-2010 04:01 PM
89 Reasons Why My Suby Sits in the Garage HawkI56 Member's Car Gallery 33 09-30-2008 05:45 PM
Can I let my car sit without the tranny mount? 83Rabbit Transmission (AT/MT) & Driveline 2 06-15-2006 08:03 PM
So, my car is in the shop for a week WagonMonster Off-Topic 29 12-01-2005 12:25 PM
OT My car is misfiring and it's been in the shop for a week. Imprezd New England Impreza Club Forum -- NESIC 15 10-10-2001 09:12 AM
