Old 08-20-2004, 04:32 PM   #1
verc
Member#: 41754
03 wrx
gt35r, 2.5L, meth
Default RE: ECU sampling frequency?
Hey, I'm sure someone from TXS/Cobb/ecutek at least will be able to answer this:
I know that all these engine management stuff must have some FPGA or microcontroller doing the signal processing. So I'm wondering, when you read/write from the ECU, what frequency are you sampling parameters at?
Reason is, I'm doing this as a little project, converting my instrument panel to a digital display with a cool bar tach like on the S2000, and I am also wondering the pros and cons of sampling from the OBD port using a ISO to Serial converter, or the ECU, since a company (Elm electronics, www.elmelectronics.com) makes an ISO-Serial converting PIC 12F microcontroller and the OBD scanners using this chip are capable of displaying quite a lot of information. And that you can ping it serially for various ECU data. But I was looking at the ECU pinouts on Rift's ProjectWRX the other day and noticed that things like TPS, tach and vehicle speed (PWM'd?) are pinned out in analog voltages/waveforms, so it seems easier to just sample fom there...
Thanks,
Ambert
verc is offline   Reply With Quote
Old 08-20-2004, 04:38 PM   #2
verc
Member#: 41754
03 wrx
gt35r, 2.5L, meth
o and also, does anyone know if the voltages from like, the fuel level sensor, the MAP sensor, fuel pressure, fuel temp, fuel injector/ignition control, MAF sensor, coolant temp, TPS, change linearly or log or what?
Maybe some questions are kind of n00b, but I apologize b/c I've never done any research into the WRX ECU, I'm just making some candid observations here based on my personal knowlege and what I've read.
Old 08-21-2004, 01:48 AM   #3
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
maf is polynomial. map is pretty linear. tps is linear with angle of rotation. there is no fuel pressure signal.
those are the ones i know for sure.
ken
RE: re: RE: FW: re: RE: FW: re: RE: re: RE: RE: RE: cotton under-shirts El Camino Off-Topic 65 08-18-2008 04:07 PM
What is ECU execution frequency? batchman Open Source Reflashes 16 02-01-2008 06:12 PM
From: [email protected] Re: Virus sample beachbum Off-Topic 0 06-30-2004 11:10 PM
Newbie question RE: ECU upgrades NETWRX Newbies & FAQs 0 04-08-2002 09:21 PM
opininons on this please... re: ecu herzy2.5RS New England Impreza Club Forum -- NESIC 3 06-11-2001 04:46 PM
