Welcome to the North American Subaru Impreza Owners Club Sunday July 31, 2016
Old 08-20-2004, 04:57 PM   #1
serious
Member#: 22879
Default Best place 2 tap for boost gauge on jdm 2.0?
Hi all, i'm wondering where is the best place to tap a boost/vacum line on the jdm engine? It doesn't have the T where the usdm one has on the bov line, so i was thinking of just adding one there or going to the turbo line itself.
Is there anyone best place to put it?
Thanks
brent
serious is offline   Reply With Quote
Old 08-20-2004, 05:03 PM   #2
MB38
Member#: 51588
2006 WRX TR
1997 Supra Turbo
Just cut the BOV line and add your own T fitting.
MB38 is offline   Reply With Quote
Old 08-20-2004, 05:07 PM   #3
0db
Member#: 33879
2003 WRX Sporkwagon
do it on the BOV line; not the turbo itself. You're more interested in the amount of boost in the manifold than what the turbo is producing before the IC and (more important) the throttle body.
0db is offline   Reply With Quote
Old 08-20-2004, 05:12 PM   #4
serious
Member#: 22879
Cool, that makes it easy then. Does anyone like napa or one of those stores sell a T fitting that will work in that hose?
Thanks
B
Old 08-20-2004, 06:34 PM   #5
samowrx
Member#: 8403
i tapped mine on the hose to the intake manifold. i have read that you can get inaccurate readings from the BOV hose.
samowrx is offline   Reply With Quote
Best place to tap for water sprayer? 06HAWKMAN Electrical & Lighting 6 03-02-2009 01:23 PM
good place to tap for boost gauge? [email protected] Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 07-07-2006 12:28 PM
Best place to tap for boost gauge on 05 STI? Inprogress Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 09-20-2004 01:06 PM
Is this ok place to tap for boost pressure reading Fubaru Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 18 01-06-2002 10:53 PM
Here is the best place to tap for a Boost Gauge....(big pics) Jimmy S. Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 16 12-15-2001 04:22 AM
