Welcome to the North American Subaru Impreza Owners Club Tuesday August 23, 2016
Old 08-20-2004, 07:02 PM   #1
scubydrew
Member#: 32609
2005 saab 9-2x
rhd ej20tt sold...
Default Link Help
so today I decided it was time to install link after having it for months. Here's the problem I plug it in and try to load a map and it say unable to establish connection with link computer. What's going on. I'm thinking either the ribbon cable from the serial link is bad but then again I just replaced it or the cable from the labtop to the serial link is bad. I really don't know but this is what I'm guessing. someone help
scubydrew is offline   Reply With Quote
Old 08-21-2004, 12:29 PM   #2
Wedge
Member#: 2279
2000 Slingshot
Pastelito Racing
Is the LINK logo on the top right spinning?? It could be your version of the software you have loaded up on the laptop. At least thats what happened to me.
Wedge is offline   Reply With Quote
Old 08-21-2004, 07:53 PM   #3
WRC 555
Member#: 94
1999 2.5 RS-T RBP
EJ257 Hybrid Link'd
Do you the keys on 'ignition on'? If the car is completely off it will not connect.
WRC 555 is offline   Reply With Quote
Old 08-22-2004, 06:34 AM   #4
scubydrew
Member#: 32609
2005 saab 9-2x
rhd ej20tt sold...
the car was on the on position. could it be that i made my own plug and play harness. i didn't want to have to wire it in and not be able to go back to stock so i made my own harness.
Old 08-22-2004, 06:37 AM   #5
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Hydra+HMist+PPG+35R=DEATH
what the?
if u made ur own harness and did it properly it should work
what connectors did u use?
Old 08-22-2004, 02:35 PM   #6
scubydrew
Member#: 32609
2005 saab 9-2x
rhd ej20tt sold...
i used the ecu connector from the same style ecu as mine. i have a 96 and it's seperated into 2 sections. I took the clip off the mother board of the other ecu and ran the link side wires to the back of it.
Old 08-22-2004, 02:59 PM   #7
PHATsuby
Member#: 13617
2001 Legacy GT back
to stock is a project too
check your com port, if you have anti virus software it can mess the port up so that it wont communicate, disable any stuff you think may be messing it up.
what operating system are you using? i know on my laptop xp wont let me use my serial port so i have both 98 and xp, 98 for tuning.
could be something like that but do wedge's suggestion first as he has the link.
Ben
Old 08-22-2004, 09:53 PM   #8
scubydrew
Member#: 32609
2005 saab 9-2x
rhd ej20tt sold...
i don't think it's the com port because I hooked up the wideband tonight without any problems. I'm going to load another pclink and try that.
Old 08-24-2004, 08:57 PM   #9
scubydrew
Member#: 32609
2005 saab 9-2x
rhd ej20tt sold...
does anyone think the problem could be with windows xp?
Old 08-24-2004, 09:03 PM   #10
dunk
Member#: 15359
I'm running pclink on xp with 0 problems.
Duncan
dunk is online now   Reply With Quote
Old 08-25-2004, 02:23 PM   #11
scubydrew
Member#: 32609
2005 saab 9-2x
rhd ej20tt sold...
does anyone know what the blue switch does inside link? there's two choices on or 1.
Cusco rear adjustable arms/links help wlelandj Brakes, Steering & Suspension 4 04-07-2003 09:13 AM
Link help Skulltoy Engine Management & Tuning 0 03-30-2003 10:40 PM
link help mkbvictory Engine Management & Tuning 5 01-15-2003 01:46 PM
link help!!!!! gabewrx Engine Management & Tuning 9 10-22-2002 01:49 PM
Link help Impreza Rider Normally Aspirated with bolt-on Forced Induction Powertrain 51 05-22-2002 02:18 AM
