Old 08-20-2004, 07:25 PM   #1
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
Default fuel problem, is it the fuel pump or FPR?
I'm posting this for a buddy knee deep in fuel problem for an 02 WRX. His fuel pump will not shut off, it constantly runs. It's a Walbro unit. This is after removing the intake manifold, doing the coolant bypass mod, installing Hondata gaskets, and porting the TB. Prior to this, everything worked fine.
Right now we (I'm stuck at home doing the phone a friend thing) are clueless as to why the fuel pump won't shut off. Our guesses are the FPR or fuel pump. We are unsure if the fuel pump shuts off due to backpressure or an electrical signal. He is running a Link ECU. Anyone have any ideas I can call him with?
Old 08-20-2004, 07:29 PM   #2
ImprezaRSfan!
Member#: 13520
99rs ej207 spec-c
its for sale
it shuts off when u take the key off right?
mine runs constantly, but only when the key is left in the ON position
ImprezaRSfan! is offline   Reply With Quote
Old 08-20-2004, 07:33 PM   #3
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
...so it's just circulating back to the tank....and not leaking all over the place.....
Is the FPR vac line connected?
Old 08-20-2004, 07:57 PM   #4
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
When you turn the car on, the fuel pump starts running. When you turn the car off, the fuel pump keeps running. If you disconnect the battery, it shuts off. When you reconnect the battery, it stays off until you turn the car on.....wash, rinse, repeat.
The vac line is connected and no leaks or gas smell.
Ideas?
Old 08-20-2004, 11:01 PM   #5
zomba_830
Member#: 55221
2002 WRX silver
Swap the fp relay for one from another circuit. Recheck. If no improvement, check power supply wire that feeds coil side of fp relay (it should only be hot when ignition is in the on and crank position. If still no improvement, checking of the fuel pump controller and ecu are the most logical next steps.
I'm making the assumption wiring at fp assembly has been checked and is ok.
zomba_830 is offline   Reply With Quote
Old 08-20-2004, 11:10 PM   #6
AZScoobie
Member#: 8785
02 [email protected]
netcom.com
Its likely that your friend pinched the TPS wires and or did not plug in the TPS connector fully.
C
AZScoobie is offline   Reply With Quote
Old 08-20-2004, 11:31 PM   #7
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
Thanks for the advice! I don't know if it's fixed or not, but will relay this stuff to him when I go over there tomorrow a.m. We have to get it all bolted up so we can go to our Scooby Meet in the afternoon.
Old 08-20-2004, 11:39 PM   #8
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
I would check the FP relay first off...who is having the trouble ron? I'm free to help tomorrow after 5:00
Old 08-20-2004, 11:41 PM   #9
bucklidl
Member#: 36765
2007 WRX wagon
2008 FSXT WRB
it's fixed and it was a really easy fix too
bucklidl is offline   Reply With Quote
Old 08-20-2004, 11:56 PM   #10
zomba_830
Member#: 55221
2002 WRX silver
What was wrong???
Old 08-21-2004, 12:14 AM   #11
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
Yeah, what was wrong buttshark?
Old 10-30-2005, 12:09 PM   #12
mooserider
Member#: 79655
Just found this thread while searching for the same problem... I did figure it out a few minutes later. Was the ground wire that connects to the manifold above driver's side fuel rail. Had it off for clearance and didn't put it back. Whoops. Works fine now!
mooserider is offline   Reply With Quote
Old 02-24-2012, 04:42 PM   #13
HarleyAshby
Member#: 310429
i have a problem with an 03 and the idle being high. fuel isnt making it to the engine it seems but it stays on so some must be.
HarleyAshby is offline   Reply With Quote
Fuel pump or FPR JRSTI Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 01-21-2010 04:01 PM
Is this the fuel pump relay? swr999 Service & Maintenance 10 12-15-2009 04:17 PM
Is my fuel pump getting weak or is it the Turbo? ClayMac Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 11-20-2008 03:59 PM
P1101, is it "manufacturer fuel air metering" or "Neutral Circuit Malfunction"?? AcquaCow Service & Maintenance 12 08-12-2008 10:01 AM
is it a bad clutch or engine problem? danger wagon Normally Aspirated Powertrain 6 12-02-2004 07:54 AM
