Old 08-21-2004, 12:01 PM   #1
burt_poppenga
Member#: 16442
2004 STi
Default Help with stripped nut on rear diff support
Hello,
I was installing the Whiteline rear diff bushings on my 04 STI and ran into a problem with one of the differential mount bracket bolts. It started when I tried to take one of the small bolts off the drivers side bracket: it looks like it was cross threaded from the factory.
I got the bolt out but it was really messed up. The nut up inside the body didn't look too bad, so I got a new bolt to replace the old one.
No dice. It is clear that the nut (up inside the body) is completely hosed. How do you fix somthing like that?
Thanks,
Burt
burt_poppenga is offline   Reply With Quote
Old 08-21-2004, 01:41 PM   #2
OneOBS
Member#: 63076
2004 Outback Sport
Red!
If you have a tap & die set ($12 at Harbor Freight), you can try to clean up the threads in the nut and use a new bolt. If that doesn't work, tap it out slightly and use a larger diameter bolt.
OneOBS is offline   Reply With Quote
Old 08-21-2004, 07:47 PM   #3
burt_poppenga
Member#: 16442
2004 STi
I stopped by Harbor Freight, they had a nice metric 40 piece tap set on sale for $9.
I used the 8x1.25 tap and it really cleaned the threads up nicely. Problem now is the hole is just a tad bigger than the new 8x1.25 bolt. Don't know what I did wrong ... but the bolt wiggles around badly (and can't be snugged up or it pulls the thread out).
Old 08-21-2004, 07:59 PM   #4
OneOBS
Member#: 63076
2004 Outback Sport
Red!
Uh-oh. You'll need a bigger bolt, then.
Old 08-21-2004, 08:43 PM   #5
burt_poppenga
Member#: 16442
2004 STi
I was just down at the hardware store. The next size up in a metric bolt with a 1.25 thread is 10mm. That could be a bit big for the available space.
The SAE bolts had completely different thread pitches, don't know if I can run a tap through and expect it to work or not.
What size bolt/tap would you suggest?
If all that doesn't work, is is possible to have the 'nut' replaced? I can't see an obvious way to get access to it ... it doesn't come through to the inside of the car. Looks like its inside the frame someplace.
Doh.
Old 08-24-2004, 12:59 AM   #6
burt_poppenga
Member#: 16442
2004 STi
I talked to my dealer today and they didn't have any good ideas on how to replace the nut, so I ended up buying a heli-coil thread repair kit. I had to shorten the insert a little bit, but it came out really well.
Group Buy GC8 Beatrush Rear Diff Support RallySport Direct Vendor 'Group Buy' Classifieds 124 08-25-2009 06:37 PM
Need help with stripped steering rack nut FaisalT Brakes, Steering & Suspension 4 06-29-2007 11:00 PM
Stripped nut on a camber bolt zuczek Canada Region Forum 11 08-29-2005 10:51 PM
*Brand new* Whiteline Steering Rack Bushings, Rear Diff Support, Subframe Lock Thug Private 'For Sale' Classifieds 13 12-16-2004 09:02 AM
Whiteline rear diff support (KSB751) - help! teiva-boy Transmission (AT/MT) & Driveline 7 12-29-2002 07:14 PM
