Old 08-21-2004, 01:09 PM   #1
Canadian_2004wrx
Member#: 60712
2004 Wrx
World rally blue
Default car wont start
Hey guys just did a 2.5 swap with a jmd six speed and the car wont car
i don't get any spark? i have a u-tec do you think that is the problem.
The car started and run fine for like 5 min then just shut off?
What are thing i can check?
Thanks For the help
Canadian_2004wrx is offline   Reply With Quote
Old 08-21-2004, 01:20 PM   #2
carguyx
Member#: 66850
04 green'd STI
11.41 @ 117mph 93 oct.
Do you have injector pulse?
if not its the crank position sensor or the cam sensors. Unplug the utec and see if the car will start with the utec disabled.
carguyx is offline   Reply With Quote
Old 08-21-2004, 03:08 PM   #3
mj02wrx
Member#: 46335
2002 wrx wagon
wr blue pearl
Did you get the cam and crank sensors plugged in all the way? Also check for possible codes if you can find someone with a sutable scan tool.
mj02wrx is offline   Reply With Quote
Old 08-21-2004, 03:23 PM   #4
carguyx
Member#: 66850
04 green'd STI
Im having the same issues with my car. I think a sensor is at fault.
Either that or there is some reseting sequence I am not aware of.
The problem is that even if you scan the ecu, you get up to the part where it asks you to start the car and you cant.
GRRRRRRRRRRRRRRRRRRRRRRRRRRR
Alarm wont stop going off, car wont start!! felixk Car Audio, Video & Security 3 08-20-2009 05:10 PM
Parking lights wont work now car wont start inevitable_101 Electrical & Lighting 0 07-21-2009 04:51 PM
car wont start in the cold gallstone Normally Aspirated Powertrain 2 01-08-2002 04:03 PM
Need help ASAP! Car wont start! Dane Normally Aspirated Powertrain 8 03-25-2001 12:04 AM
Car WOnt Start, 2 weeks old emprezadent General Forum Archive 3 02-03-2001 06:27 AM
Message Board Statistics All times are GMT -4. The time now is 07:17 AM.
