Old 08-21-2004, 05:27 PM   #1
sti_rx7
Member#: 38456
Default Real vs Base Maps for AP
I understand what both do, but I was wondering if you are using a real run time map which is not flashed to the ECU does the AP have to remain connected?
sti_rx7 is offline   Reply With Quote
Old 08-21-2004, 05:40 PM   #2
949
Member#: 58906
A/p Does Not Need To Be Connected Only To Change The Maps
But The Thing Looks Cool Connected Tho
949 is offline   Reply With Quote
Old 08-21-2004, 05:55 PM   #3
hondaeater69
Member#: 60324
that's correct, once the map is flashed (base or real time), you can disconnect the AP.
Old 08-21-2004, 05:57 PM   #4
sti_rx7
Member#: 38456
Thanks for the replies.
bikerval
Old 08-21-2004, 10:47 PM   #5
SAL-23
Member#: 3474
2013 WRX
Unless you want to read boost with the AP...
SAL-23 is offline   Reply With Quote
a bit confused about real vs. base maps freezer16801 AccessPort 4 11-05-2008 05:32 AM
04 WRX - Going to be installing STAGE 1... Real Time vs Base map Question. Jeenyus AccessPort 10 12-27-2007 02:44 PM
No base maps on AP for 04 STi? subieluvr AccessPort 1 08-20-2006 01:48 AM
HELP: Temporary Protune Base Map ~ AP Doesnt list the map teh sash AccessPort 1 06-23-2006 09:39 AM
how long does it take for you to change base maps with AP? intence Engine Management & Tuning 7 01-06-2006 07:19 PM
Message Board Statistics All times are GMT -4. The time now is 07:28 AM.
