Old 08-21-2004, 09:32 PM   #1
mrubino83
Member#: 22987
2010 PB EVO X GSR...
.. It's All Stock Officer
Default Anybody know what type of Turbo is used in the WRC car?
The name of the thread pretty much says it all. I did a search and couldnt find anything on teh turbo specs. Anybody know?
mrubino83 is offline   Reply With Quote
Old 08-21-2004, 09:50 PM   #2
Acostafan
Member#: 67398
2002 Now with 100%
RDA of 2.5l Goodness!!!
I know it's an IHI turbo but I don't know which model.
Acostafan is offline   Reply With Quote
Old 08-22-2004, 12:13 AM   #3
Timdog1650
Member#: 45516
MY04 STi
Bump...I think this would be interesting to know too
Timdog1650 is offline   Reply With Quote
Old 08-22-2004, 12:22 AM   #4
DrBiggly
Member#: 11482
02 WRX
Acute Stickeritis
I remember reading somewhere that they hit like 380lb/ft of torque by something like 2000rpm. Unreal setup.
Have you tried Google searching or just within NASIOC?
DrBiggly is offline   Reply With Quote
Old 08-22-2004, 01:35 AM   #5
DuoMaxwell
Member#: 24565
2000 V6 STi RA #856
Are you that desperate to know. Its not actually like you can really afford to apply this turbo properly to a WRX or STi!!!!
IHI 34mm Restrictor
DuoMaxwell is offline   Reply With Quote
Old 08-22-2004, 03:11 AM   #6
GTScoob
Member#: 68602
02 STi Wagon
antilag possibly? Then you would have full boost around there.
GTScoob is offline   Reply With Quote
Old 08-22-2004, 03:58 AM   #7
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
anti-lag, indeed....
Old 08-22-2004, 04:08 AM   #8
RoadSpike
Member#: 68614
According to the tech article the car runs idle at 2k rpm and produces 1bar of boost thanks to the anti lag system.
It also pushes out 3bar of boost at max (4 bar absolute) according to the arcticle. This thing is wild beyond any anything i've ever seen.
You wont find a model number on the IHI turbo becuase the turbine is custom designed. I suppose it was a RHF model to begin with but supposedly its compressor and exhuast turbines are far from stock.
RoadSpike is offline   Reply With Quote
Old 08-22-2004, 05:27 AM   #9
DuoMaxwell
Member#: 24565
2000 V6 STi RA #856
Its a real freaky design so to speak. The anti lag system is a great thing but you exhaust manifold/headers will not take extended uses. I remember somewhere one of the techies saying that they have never blown a turbo due to anitlag but they replace manifolds/headers constantly!!
Old 08-22-2004, 05:53 AM   #10
RoadSpike
Member#: 68614
Probably do to the constant heat and explosive nature of the antilag system. They probably need a thicker material and passive cooling fins for it to last a decent amount of time. But for weight issues they probably don't want to.
Old 08-22-2004, 06:02 AM   #11
NPC
Member#: 28203
03 Impreza WRX
think titanium
NPC is offline   Reply With Quote
Old 08-22-2004, 06:53 AM   #12
RoadSpike
Member#: 68614
Originally Posted by NPC
think titanium
Ah didn't actually think of that good call though i imagine even titanium can't handle the heat that thing is surely putting out.
Definitely jet hot coated for sure
Old 08-22-2004, 11:45 AM   #13
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
Jet hot coated exhaust wheel? No.
cdvma is offline   Reply With Quote
Old 08-22-2004, 02:37 PM   #14
DumbUglyDragon
Member#: 61077
1993 WRX
Titanium for engine parts = bad idea. Titanium expands too much under prolonged heat!
DumbUglyDragon is offline   Reply With Quote
Old 08-22-2004, 02:47 PM   #15
Uncle Scotty
Member#: 16200
OK buy Nates beans
I think you guys are trying to THINK too much and have no facts....
A bit of resesrch will yeild most anything you wish to know.....it's all been discussed before.
Old 08-22-2004, 04:34 PM   #16
mlambert
Member#: 13831
dont know about this years car but theyve gone thru alot of VF28's
mlambert is offline   Reply With Quote
Old 08-22-2004, 06:19 PM   #17
LyveWRX
Member#: 19057
& Blue Ford & '72 CB350
Inconel>Titanium at High Heat
LyveWRX is offline   Reply With Quote
Old 08-22-2004, 06:56 PM   #18
Pavlo
Member#: 23015
95-> GC8
Black, blue and blue
Silicon nitride for prolonged ALS use.
The turbo is a custom, but available from pro-drive if you have the money. It's a BB core, different housing, and they also do something to allow the turbo to be operated at an anlge that would destroy most normal turbos. Compressor cover is small though, same proportions as a VF30, but different in order to take the restrictor.
Although they run very high boost, they can't maintain that boost at all with RPM, so they are maxing out the turbo, at the practical limit of the restrictor as early as possible. this gives them 300hp + from under 3000rpm to over 6000rpm, which means they always have the max amount of torque available at the wheels at any one time. Unlike a 'normal' wrx where you are only at peak power through a limited range. This is how they get such good performance on the road with relatively little power.
Paul
Pavlo is offline   Reply With Quote
Old 08-22-2004, 08:19 PM   #19
RoadSpike
Member#: 68614
cool stuff guys learning something new each time i reread this
Old 08-22-2004, 09:09 PM   #20
verc
Member#: 41754
03 wrx
gt35r, 2.5L, meth
titanium? What the heck? Titanium is not that great of a material. It's advantage is that it's strong pound for pound, it's actually not that strong on the absolute scale of things. Same thing with Carbon fiber. Really crappy impact resistance, high tensile strength. However, it's not THAT strong, rather strong pound for pound.
So what is this anti-lag? Like 10 people have posted about talking about it in this thread but I have a feeling that no one actually knows how it works? I mean the turbo will spool up because X amount of kinetic energy is being imparted to to the turbine wheels by the gases.
So I'm assuming the anti-lag is something like that backfire option you get with some EMS's where you can run super rich and have some unburnt fuel ignite on the turbo wheels or something?
verc is offline   Reply With Quote
Old 08-22-2004, 09:21 PM   #21
Timdog1650
Member#: 45516
MY04 STi
yes, the technical name for a "backfiring system" or "misfiring system" is Anti-Lag, and it more or less does just that, in conjunction with timing augmentation. The primary benefit of this being that you can lift throttle and retain full boost pressure, have full boost pressure much earlier, and it mimics launch control in the sense that you can slip the clutch and stomp the gas and instantly be in the perfect part of your powerband. Very hard on manifolds/exhaust wheels.
~Tim
Old 08-22-2004, 09:34 PM   #22
RoadSpike
Member#: 68614
The antilag system is quite insane. It has a special plum to feed a bit of compressed air from the turbo into the exhaust housing at the same time feeding the cylinders overly rich mixtures. This ignites and keeps the turbo spooled
I don't know much about their exhuasts and materials but there was a great post on i-club with all kinds of good info.
i-club.com/forums/showthread.php?t=69783
EDIT: GOD DAMNED NASIOC FILTERS!!! link can't work becuase of them!!!
Edit 63: finnally got around them
Old 08-23-2004, 05:17 AM   #23
Pavlo
Member#: 23015
95-> GC8
Yes Anti-slag can be crudely implemented by setting the ignition timing to aything from 10 to 30 degrees after TDC and getting enough air into the engine to produce some serious exhaust gas. Often they idle at high rpm, with a rotational ignition cut to prevent the engine over revving, as the ALS is setup to effectively open the throttle. More advanced systems on the WRC cars as above with the secondary air system to the exhaust manifold, this runs lots cooler and doesn't burn ex valves etc, it's also much quieter. The older style of ALS is banned on some events now.
Paul
Lifeline 1.75 NEW In Car Fire Extinguisher Used in the WRC cars! rallyespec Interior/Dressup/Audio & Security 36 04-29-2010 08:28 AM
What Kind of fluid is used in the center diff of an 04 wrx ericbootz Transmission (AT/MT) & Driveline 5 04-14-2010 09:43 PM
Anybody know what type of pillar pod this is? kogs Interior & Exterior Modification 4 10-19-2006 10:19 PM
Anybody know what type of relay I need to do this..? prototypeWRX Electrical & Lighting 3 07-08-2006 10:12 AM
What kind of bulb is used in the EDM STI lights? Pika's WRX Electrical & Lighting 2 01-12-2004 07:54 PM
