Go Back   NASIOC > NASIOC Subaru Models > 'Old School' Subaru Forum
Old 08-22-2004, 12:07 AM   #1
Brian204
Member#: 56528
1989 GL
white
Default worn struts
Where can one find shock absorbers for old school subies? The passenger rear shock in my 89 gl wagon seams to be sagging a bit...how hard are they to replace?
Brian204 is offline   Reply With Quote
Old 08-22-2004, 02:09 AM   #2
Calebz
Member#: 54398
1980 CB400 Hawk
1996 GrandCherokeeLimited
The shocks/struts won;t make it sag.. the spring will. The shocks/struts can be had anywhere from sears to autozone.
Springs on the other hand.. try a wrecking yard
Only 3 bolts to remove the rear shocks.. real easy..However, it requires a spring compressor to remove the spring from the strut. Still not terribly hard. I can do both rears in under an hour
Calebz is offline   Reply With Quote
Worn Strut= bad alignment? sube-trex Brakes, Steering & Suspension 8 11-11-2009 01:21 AM
Worn Struts? wantinaSTI Brakes, Steering & Suspension 2 09-20-2008 11:16 PM
Can worn struts or springs cause oversteer? spuck Brakes, Steering & Suspension 3 09-05-2005 04:16 PM
Worn Strut? Prodrive Springs & Stock Struts Udonboy Brakes, Steering & Suspension 5 06-02-2005 11:34 AM
worn strut or swaybar bushing only 2k miles! Scoobs Brakes, Steering & Suspension 1 04-25-2002 04:53 AM
