Welcome to the North American Subaru Impreza Owners Club Wednesday July 23, 2014
Old 08-22-2004, 12:42 AM   #1
RichWRX
Member#: 15544
STI hydra,2.65l
BW s374 turbo(twin scroll
Default Utec remote map switch
I just installed a Utec in my Sti , I got a remote map switch but no directions with it. Where do the black and red wires go to?, and where does that little jumper go? Thanks for the help
Rich
RichWRX is offline   Reply With Quote
Old 08-22-2004, 01:05 AM   #2
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
Old 08-22-2004, 03:34 AM   #3
TurboXS (Pete)
Member#: 16704
Read the warnings about the use of Launch Control and the understand the two types of Launch Control Options. The use of Launch Control can seriously affect the life of your car!
If you still want to fit it then;
Locate the top clutch switch for the cruise control (I believe there are two clutch switches on the USA WRX).
Remove the connector from the switch (You may find it easier to remove the clutch switch for this, make sure you keep one of the nuts in place so you can replace in exactly the same spot).
Once you have removed the connector, look into the switch and you should see two electrical contacts. Push the connectors from the remote switch onto these (There is no polarity).
Use the short green wire to bridge the contacts on the connector (This will bypass the safety feature from the cruise control!)
Refit the clutch switch if you have removed it.
Enable Launch Control in the software.
Goto to the Dashboard. It should tell you launch control is enabled. A '*' should appear whenever you press the clutch pedal down.
regards
Pete
(TurboXS)
p.s I copied this from another of my posts.
TurboXS (Pete) is offline   Reply With Quote
Old 08-22-2004, 12:09 PM   #4
RichWRX
Member#: 15544
STI hydra,2.65l
Thanks Pete
I wasnt sure if it was for the launch control or not, I saw the wires an just wanted to make sure they didnt have to be hooked up to something to work. Im going to wait to hook up launch control for a while.
Rich
Old 08-22-2004, 06:42 PM   #5
DISCOPOPE
Member#: 43339
2oo4 STi
URgt35r w/t3hM3finj3cki0n
Originally Posted by Uncle Scotty
http://www.thanksfortheuselesslink.com
DISCOPOPE is offline   Reply With Quote
Old 08-22-2004, 06:46 PM   #6
DISCOPOPE
Member#: 43339
2oo4 STi
In addition to the female connectors that connect to the clutch switch, there is a black and red lead wire coming out of the white connector that connects to the utec.
these are the wires that seem to have absolutely no documentation as to their cosmic purpose......
i believe they are the solinoid control wire.
Old 08-22-2004, 08:45 PM   #7
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
Originally Posted by DISCOPOPE
/www.intercourseyourselfyoualreadyknowhowdontya.uy[/url]
Old 08-22-2004, 08:52 PM   #8
DISCOPOPE
Member#: 43339
2oo4 STi
eat a rock.
Old 08-22-2004, 11:16 PM   #9
TurboXS (Pete)
Member#: 16704
I didn't read your original post carefully enough!
Just to clarify things;
The red and black wire coming from the white Molex connector are used for the spare solenoid and ground.
The cable coming from the switch which have a crimp connector on the ends are for the clutch switch if you want to use it for launch control.
The green link wire is for bridging out the connector that was originally connected to the clutch switch.
regards
Pete
(TurboXS)
Old 08-22-2004, 11:49 PM   #10
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
Thanks Pete
Old 08-23-2004, 11:16 AM   #11
DISCOPOPE
Member#: 43339
2oo4 STi
thnks pete
Old 10-06-2004, 05:18 PM   #12
santofontana
Member#: 26876
1994 Camaro Z28 383
Black M6
If the posts made by TurboXS in this thread were in the manual it would probably save TXS some trouble.
santofontana is offline   Reply With Quote
Old 10-07-2004, 07:15 AM   #13
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
If the bozo's that bought UTEC's actually READ the F'ing manual, it would save TXS a LOT of trouble.....
Old 10-07-2004, 08:01 AM   #14
txjunglist
Member#: 11926
2011 Outback Limited
Dark Grey
Default Hahahaha
thats effin funny
eat a rock.
txjunglist is offline   Reply With Quote
TurboXS Universal UTEC Remote Map Switch UTEC-SWITCH monSTIer Engine/Power/Exhaust 9 09-01-2008 12:39 PM
IL: Utec Remote Map switch...55 shipped Shaitiger Private 'For Sale' Classifieds 1 03-10-2004 10:08 AM
03 ECU, UTEC Remote Map Switch, AEM Pulley Kit biker360 Private 'For Sale' Classifieds 10 02-24-2004 10:23 AM
03 ECU,UTEC Remote Map Switch, AEM Pulley kit biker360 Private 'For Sale' Classifieds 14 02-14-2004 10:38 AM
problem with utec remote map switch bluespeed Engine Management & Tuning 4 03-24-2003 04:02 PM
