Old 08-22-2004, 09:26 AM   #1
loscooby
Member#: 34096
2002 Impreza STI
Micra blue
Default cel P0244 today
Calling all techies!
I have had my euro spec STI -2003 ECUTEK'ed along with a full aftermarket exhaust(1 race cat in center decat downpipe)
I got the cel the other day, my obdII scanner read:
P0244 -Wastegate control solenoid valve malfunction (high input)
The cel came up on the highway in 6th gear, wot while overtaking then I hit fuel-cut and a loud bang was heared from what appeared to be the back of the exhaust...
The car still pulls like normal but there is a burbling sound in the rpm-range 3500 to about 4000, sounds like the turbo or engine is choking or something.
I hear the normal turbo-whining until this rpm-range but it transforms into this strange sound.
I should add the burbling sound is less notable when the engine is colder...
I called my tuner and he says it could be the wastegate??
What do you guys reccon, air-pipe leak, turbo failure ??
/L-O
loscooby is offline   Reply With Quote
Old 08-22-2004, 11:04 AM   #2
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
Oil Dry Sump Goodness
P0244 is the boost cut code. It's possible that you broke something when you hit this hard cut. Sorry I can be of no more help.
mick_the_ginge is offline   Reply With Quote
Old 08-22-2004, 11:33 AM   #3
loscooby
Member#: 34096
2002 Impreza STI
Micra blue
Question
Please you techies out there...
Old 09-11-2004, 10:57 PM   #4
Kushmasterh
Member#: 70027
2004 WRX STi
Platinum Silver
Subaru Stars CEL At High Speed
I have also experinced this but just with out the loud banging sound. I own a 2004 GDB STi and have been told some things about overboosting and boost lag, but no real solution yet. Installed myself Helix 3" blemouth downpipe w/ cat-back exhaust, APS cold air, HKS SSQV bolw-off. At around 90-100 in 5th the fuel cut-off hits and the car just sort of dies. CEL comes with crusie blinking. The scanner reads the same code. P0244.(Turbo wastegate control soleniod valve malfunction, High Input) HELP!
Kushmasterh is offline   Reply With Quote
Old 09-12-2004, 11:33 AM   #5
REDI-wgn
Member#: 38068
03 WRX Wagon
i have experienced this code as well but f course without the bang and choking afterwards. I had a cheap MBC that was sticking and causing me to overboost. After clearing code everything was fine, i never really got on the car with the CEL on so for the choking i am not accountable for, but i also have stock TB Exhaust. Reset the ECU using a scanner if you can and drive the car to see if it is ok. mine was and still is.
REDI-wgn is offline   Reply With Quote
Old 09-12-2004, 11:36 AM   #6
REDI-wgn
Member#: 38068
03 WRX Wagon
forgot to mention that when putting turbo back exhaust on STi,s there is a big chance of overboost becasue the wastegate cannot flow enough air through it causing more air to flow through turbo hence the overboost. Friends of mine have had to get their wastegate ported when puttin downpipes on their STi`s. Do a search cause i am sure this was discussed in great detail before and you will get alot more iinfo on it that i can give you.
CEL P0244??? Turbo wastegate problem stcktnkid Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 08-11-2010 10:31 AM
CEL P0244 Again (hopefully different) serendipity Engine Management & Tuning 3 12-22-2004 12:29 PM
CEL P0244 and TurboXS ABC rainmanjam Engine Management & Tuning 1 09-28-2004 12:11 PM
CEL P0244 - Wastegate out of range? Big Turkey Engine Management & Tuning 2 09-04-2003 12:33 AM
CEL P0244, can someone explain? bdowell Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 10-22-2001 12:47 PM
