Old 08-22-2004, 02:24 PM   #1
RichWRX
Member#: 15544
STI hydra,2.65l
BW s374 turbo(twin scroll
Question Check engine light
I just installed a Utec in my Sti, and I got a flashing check engine light. I tried reseting the computer, It clears for a while then flashes again. I have the Utec on map O (stock mode). I looked at the logger and it doesnt show any detonation. I get the check engine light at idle speeds.
Any help would be appreciated.
Thanks
Rich
RichWRX is offline   Reply With Quote
Old 08-22-2004, 05:13 PM   #2
fuz
Member#: 58925
2001 wrx
cel flashing means that the ecu has detected a cylinder misfire and is a warning to protect the cats
flashing speed is explained in the manuel
fuz is offline   Reply With Quote
Old 08-22-2004, 06:19 PM   #3
T-WRX
Member#: 2468
08 RS4
05 STi - Gone
Call TurboXS on Monday. I had this problem on my WRX, and they had me:
1. Reflash the UTEC (didn't help)
2. Go back to stock, and try the car (worked)
3. Receive a replacement unit with a postage paid package to send back the original
Basically, the UTEC was defective, and the car ran in "limp" mode with the UTEC connected. The replacement unit worked perfect.
Give their customer service a chance, and let them help troubleshoot. Good luck!
T-WRX is offline   Reply With Quote
Old 08-22-2004, 09:21 PM   #4
rich728
Member#: 40328
2004 WRX STi
BSP #728
why dont you find out what the the CEL code if first?
rich728 is offline   Reply With Quote
Old 08-22-2004, 10:44 PM   #5
RichWRX
Member#: 15544
STI hydra,2.65l
I will call them tomorrow, hopefully they can help me figure it out
Old 08-25-2004, 06:56 PM   #6
RichWRX
Member#: 15544
STI hydra,2.65l
They said the Utec was defective, and I would have to send it to where I bought it for a return. Emailed the place that I bought it from they won't reply back. So it looks like im screwed!!
Check engine light, VDC light is on, and cruise control light is flashing grimace09 Normally Aspirated Powertrain 7 08-09-2012 03:42 PM
Check engine light, VDC light is on, and cruise control and sport light is flashing Legacymun2k6 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 01-30-2010 12:47 PM
check engine light, wierd engine trouble? gipoliceman Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 01-14-2003 09:04 PM
Engine coolant temp sensor check engine light? rhdude Mid Atlantic Impreza Club -- MAIC 2 11-09-2002 02:42 AM
Engine vibrating, check engine light on codemunky Service & Maintenance 2 09-15-2002 07:50 AM
