Welcome to the North American Subaru Impreza Owners Club Sunday March 29, 2015
Old 08-22-2004, 06:17 PM   #1
wrxstistunna
Member#: 64602
04 wrx sti
java black pearl
Default does anyone else have problems with blowing hoses??
I just got my aps dr500 fmic installed along with my sr50 and at 20lbs of boost it always wants to blow off the silicon hose on the intercoolers hot side. it does it to me alot and i was wondering if their is a quick fix or if have a defective piece of tubing because it seems kind of short, since their is hardley any hose to clamp down after the flange on the piping.
any suggestions would be appreciated
thanks
glenn
wrxstistunna is offline   Reply With Quote
Old 08-22-2004, 06:37 PM   #2
V6TurboTA
Member#: 9090
09 Forester Gump
02WRX->04STi->09Gump
Search.
~v6
V6TurboTA is offline   Reply With Quote
Old 08-22-2004, 07:28 PM   #3
calib17a
Member#: 64150
Default re: wrxstistunna
You gotta have a bead welded around that hot side of the ic, or I've heard of applying hair spray on the piping to hold the silicone hose.
calib17a is offline   Reply With Quote
Old 08-22-2004, 07:36 PM   #4
IA Performance
Member#: 25194
2008 Forester XT 5mt
Dark Gray
T bolt clamps should do the trick.
Stephen
IA Performance is offline   Reply With Quote
Old 08-22-2004, 07:49 PM   #5
impreza_wrx_2003
Member#: 55468
04 STI
East Coast Scooby is right I had the same problem with my perrin fmic then I installed t bolt clamps solved it havnt blown one off yet.
impreza_wrx_2003 is offline   Reply With Quote
Old 08-23-2004, 01:27 AM   #6
IA Performance
Member#: 25194
Dark Gray
and for the $1,000,000 question:
They can be found at almost any pneumatic supply store
Stephen
Old 08-23-2004, 02:55 AM   #7
wrxstistunna
Member#: 64602
04 wrx sti
java black pearl
i have t bolt clamps on every other line but their isnt enough rubber after the flange to get the full use out of a t bolt clamp so one cannot be used. Also their is a flange on the hot side of the intercooler.
Old 08-23-2004, 03:23 AM   #8
Invisiguard
Member#: 43201
04 STi
07 Corvette
Stephen
always a few guys selling them on Ebay too
Invisiguard is offline   Reply With Quote
Old 08-23-2004, 06:47 AM   #9
happasaiyan
Member#: 37731
i have the same exact setup...and yes, once i upped the boost to 20psi, hoses started popping off. from day 1 i had t-clamps...but those kept blowing off, so i used the regular screw-type clamps on the hoses that popped off (same one you mention, as well as the compressor hose -> silicone pipe). havent blown off since.
happasaiyan is offline   Reply With Quote
does anyone else have problems with their hybrid? ted dibiase Built Motor Discussion 9 10-07-2007 08:21 PM
Anyone else have Problems with SWRT Store? Prez&SUS General Community 11 11-14-2003 09:05 PM
Does anyone else have issues with their H3 foglight bulbs? obyone Interior & Exterior Modification 9 11-08-2002 09:55 PM
('93-'01) Anyone else have problems with carparts.com Tex-WReX Impreza Forum 8 07-21-2001 02:05 AM
