Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > Other Engine Management
Old 08-23-2004, 02:28 AM   #1
Big Turkey
Member#: 32118
Default Going from UTEC to Hydra.. worth it?
Thoughts on this?
I have a FP Green with a STG4 setup, stock block and motor but will definately upgrade to a built 2.5 with better heads and cams later on. Right now I am running an ECUtek reflash for injector scaling with the UTEC. Is it worth it to change that for a Hydra?
Also, with the Hydra, since it is MAP and you get rid of the MAS, is there any advantages of me running the Perrin BigMAF? What will I use for an intake of I make the switch?
Big Turkey is offline   Reply With Quote
Old 08-23-2004, 08:33 AM   #2
pfhlipwrx
Member#: 19319
Originally Posted by Big Turkey
Thoughts on this?
Like he says^^^..same questions...
pfhlipwrx is offline   Reply With Quote
Old 08-23-2004, 08:42 AM   #3
Eraz3r
Member#: 25446
2005 Nissan 350z
silverstone
I switched because of the transition delay the utec has. However, much to my surprise, the element hydra is even better than stock ever was from a drivability standpoint. I think you'd benefit greatly with a standalone system.
As far as the big maf, you wont get any benefit from it if you switch, you still need the maf sensor to measure air temps, but it doesnt use the sensor to regulate fuel like the utec does. You can use whatever intake you like with the element hydra, doesnt make a difference.
Eraz3r is offline   Reply With Quote
Old 08-23-2004, 08:51 AM   #4
ami2fst4u
Member#: 40638
'04 PSM STi
Has some work done... ;)
I personally will be switching from the STi UTEC to the Hydra ECM. However, I will still be keeping the STi UTEC as it allows me to retain OBDII for the sniffer testing (Ma. emissions) so I will swap around ECM's twice a year.
Nonetheless, on to the topic at hand. I feel as though the Hydra has alot more to offer than anything else out currently, hence the reason I will be purchasing it. Big Turkey I too have a similar setup as you, from reading various posts. It would be a wise idea to call Phil and speak with him to get you more familiar with the setup. One aspect I like most about the Hydra ECM is that is it MAP based which seems to allow an infinite amount of possibilities over a MAF based setup.
As for the MAF sensor, it is now used for the following:
Air intake temperature: This uses your factory MAF sensor for temperature ranges and allows you to globally adjust the fuel and ignition maps to compensate for 16 ranges of air intake temperatures. The benefit is to add extra fuel or adjust timing for when the car is running in a wide rage of temperature conditions due to seasonal changes or desert weather
That is verbatim from Element Tuning's website.
Rick
ami2fst4u is offline   Reply With Quote
Old 08-23-2004, 11:52 AM   #5
CK02WRX
Member#: 27859
2002 EJ257 w/CP's
8cmFP Red, RA 5spd, Hydra
I switched and i'm very happy. I don't have it completely tuned yet and its already better. I love the partial throttle full boost with the bov venting and no bucking like a maf controlled ECU. If you have experienced that before with the utec you understand how annoying it can be. No more lean after shifting or back firing. Some people liked the back firing but I thought is embarrassing. One of the main reasons I upgraded was because I didn't want my AFR to fluctuate with temp changes. I would be pissed when I had the AFR tuned just the way I wanted it. Then a few hours later it would be totally different. I also wanted to be able to use the AVCS.
CK02WRX is offline   Reply With Quote
Old 08-25-2004, 12:22 PM   #6
0db
Member#: 33879
2003 WRX Sporkwagon
If you have the means, a full standalone is awesome. Even on the "not terribly impressive" base maps, my AEM is running smoother than stock.
If you convert to speed-density (MAP) tuning, you can remove the MAF or just ignore it completely. ANY intake will work, but you also have the option of having one made or modifying yours to suit your needs without any of the MAF worries.
0db is offline   Reply With Quote
TMIC swap from wrx to sti worth it? snook07wrx Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 10 07-13-2009 11:37 PM
Is it posible to go from HID to no HID scribb1er Electrical & Lighting 4 02-16-2006 04:11 PM
Worth upgrading from UTEC to Hydra? Cosmo Other Engine Management 14 03-09-2005 10:03 AM
ok Gonna do it. Going from vf22 to 18G What to expect? Davenow Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 22 12-10-2004 10:03 PM
Possibly going from Unichip to UTEC - ?'s PadreWRX Engine Management & Tuning 14 01-28-2003 01:42 PM
