Old 08-23-2004, 09:22 AM   #1
cjfike
Member#: 60116
1999 RS Coupe
Silver Thorn
Question 2.2 Single exhaust port - enlargment
Single exhaust port heads for the 2.2, is there potential to enlarge the port?
Unfortunately, the summary of the threads usually is 'becareful, there isn't really a lot of room to remove metal in that area...'.
Or start up the 'let's swap heads theme music'.
I certainly understand caution and reservation, not loading up the grinder with the 3" metal removal attachment, and having 'at it'.
Points that I have been pondering:
  • EJ22 dual port and single port head castings are basically identical.
  • Other than metal, how would it be possible or logical for engineers (other than ego) to place internal workings into that space?
Has anyone enlarged the exhaust port on 2.2 heads to improve exhaust flow?
What was the outcome?
Or in other words: did you load up the grinder and have at it?
cjfike is offline   Reply With Quote
Old 08-23-2004, 05:00 PM   #2
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
Default Ttt
humm....sounds interesting.... Maybe I'll have at it as a next project for me.
FuJi K is offline   Reply With Quote
Old 08-23-2004, 06:11 PM   #3
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
I would try getting a spare head and use it as a sacrificial lamb.
Tim Sanderson is offline   Reply With Quote
Old 08-23-2004, 10:00 PM   #4
cjfike
Member#: 60116
1999 RS Coupe
Silver Thorn
First I need to see how the 2.2 heads compare to the 2.5 as flow is concerned. Everyone seems to use the 2.5 as the benchmark for flow, intake and or exhaust.
Then buy the 'lamb', and the 3" metal removal attachment. Does Binford make that?
Old 08-24-2004, 08:57 AM   #5
Boost-Free Subee
Member#: 61052
1999 2.5 RS
Download the free lecture off of N2performance.com on porting techniques. going "BIG" will slow down the air velocity in the port and actually hurt your performance. trust me, it's all physics (yes I'm a geek) that lecture will show you how to shape the port to get the desired result. you really don't have to remove that much metal, and simply flattening out the inner radius of any turn in the port (shape it like a D, with the flat part being the inner radius) will give you 10% more flow without even opening up the port.
Boost-Free Subee is offline   Reply With Quote
Old 08-24-2004, 10:32 AM   #6
cjfike
Member#: 60116
1999 RS Coupe
Silver Thorn
Thanks! very nice info!
So then, expansion (if any can be tolerated) would have to happen post cat(s)...
I will download the article and read it thoroughly.
Old 08-24-2004, 10:59 AM   #7
Boost-Free Subee
Member#: 61052
1999 2.5 RS
no problem, man. glad I could help. any other questions, don't hesitate to throw out there. remember, the only ignorant people out there are the ones who already "know everything". 16 years of tuning, and I'm still learning every day!!!
N1 Exhaust on 2.2 Single-Port... Subie22 Normally Aspirated Powertrain 9 11-28-2006 04:47 PM
Run phase 1 dual port 2.2 heads on a phase 2 single port 2.2 block? wagonovsky Subaru Conversions 12 03-01-2006 10:27 AM
Warning for 2.2ltr Single Exhaust Port and Borla Kevin Thomas Normally Aspirated Powertrain 10 09-18-2005 10:20 PM
When did the 2.2L heads change to single exhaust ports? subysouth Normally Aspirated Powertrain 2 09-06-2001 12:25 AM
Does MRT make a single exhaust port header for the 2.2L? 96Lconversion Normally Aspirated Powertrain 4 03-14-2001 12:38 AM
