Old 08-23-2004, 04:25 PM   #1
balrog
Member#: 23131
2005 Saab 9-2X Aero
Free Boot Rides
Default Trans Fluid vs Front Diff Fluid
Last week I had my 00 2.5RS at the dealer for leaking trans fluid. They said they replaced the trans wiring harness O ring. Over the weekend I noticed there was still some fluid leaking. Took the car back today and the told me that the current leak was actually from the front diff fluid having been overfilled by about 2 quarts. I had the fluid changed in April (April fluid change was not done by Subaru). They drained the diff fluid to the proper level and said everything is fine now.
Is it possible for this to happen? Why would it take 4 months for an overfilled front diff to start leaking? Could an overfilled front diff cause the trans wiring harness O ring to fail?
I am a bit confused!
Any info would be helpful.
Brian
balrog is offline   Reply With Quote
Old 08-24-2004, 10:52 AM   #2
balrog
Member#: 23131
2005 Saab 9-2X Aero
Free Boot Rides
Got the car back from the dealer. Overfilled front diff did not cause trans fluid leak, just coincidence apparently. They drained the diff and refilled to the correct level and all is good.
According to the tech the front diff has an overflow valve so when the front diff would get hot the additional fluid would then seek the easiest way out.
I'm happy that there was no charge...not even a diagnostic fee or extended warranty deductible. That suprised me since the front diff was overfilled by an independent shop.
Old 08-24-2004, 11:17 AM   #3
Psydotek
Member#: 44168
2003 Yellow WRX
with too many lights...
Good to hear it's all good but...
Don't the transmission and the front differential share the same fluid? (on Manual Transmissions anyways) (or are you driving an Automatic?)
Old 08-24-2004, 03:21 PM   #4
balrog
Member#: 23131
2005 Saab 9-2X Aero
Free Boot Rides
Sorry, forgot to mention that it's an auto trans.
how to drain/refill front diff. fluid? nosajh9 Transmission (AT/MT) & Driveline 7 03-27-2006 03:37 PM
Changing Front diff fluid jonney_boy Transmission (AT/MT) & Driveline 1 11-13-2005 10:01 PM
Recommendation on STi 6 spd trans/front diff fluid h2o Transmission (AT/MT) & Driveline 12 10-14-2004 06:32 PM
How to change STi trans and front diff fluid? h2o Transmission (AT/MT) & Driveline 12 05-04-2004 07:34 PM
How to change rear and front diff. fluids? skyredrex Service & Maintenance 1 01-05-2004 04:30 PM
