Rocky Mountains Impreza Club
Go Back   NASIOC > NASIOC Chapters > Rocky Mountains Impreza Club Forum -- RMIC
Old 08-23-2004, 04:36 PM   #1
Yogiwerx
Member#: 68009
Default CO: How much boost loss
How much boost are you guys loosing here in CO. Im running a Cobb stage 1 and its only putting out 13.1 psi in the springs which is btwn 6k-7k feet. The target is 14.7 Is this normal or should i try something else.
Thanks
Dan
Yogiwerx is offline   Reply With Quote
Old 08-24-2004, 12:22 PM   #2
paintbing
Member#: 59388
2003 WRX - Hybrid
I do my own stunts
Run the map that states, 91 hwg Stage 1... USE AT YOUR OWN RISK, and watch the boost... if you go over the target 14.7 then go back to the regular stage 1 map. I am not to blame if you blow your turbo cause your boost is too high for the exhaust system.
paintbing is offline   Reply With Quote
Old 08-24-2004, 12:38 PM   #3
Yogiwerx
Member#: 68009
14.7 is the .1 MPa right?
Old 08-24-2004, 01:08 PM   #4
paintbing
Member#: 59388
2003 WRX - Hybrid
I do my own stunts
Roughly... 15.5 is slightly over the .1 mark...
Do you have the ECU flashed, or do you have the handheld port? The port has a live boost readout.
Old 08-24-2004, 03:45 PM   #5
snowman4us
Member#: 21764
Some GDM V8,
JDM Flat 4 X2
there shouldnt be any PSI drop becouse of the Altitude....is something more then that, look over everything to make sure its ok. the altitude does not effect how mutch you boost....10psi in LA is still 10psi in Denver(just an example)
snowman4us is offline   Reply With Quote
Old 08-24-2004, 05:21 PM   #6
Yogiwerx
Member#: 68009
I know that 10 psi is 10psi but doesnt the ecu retard the timing and everything and reduce the boost since there are less air molecules in the air.
How much coolant loss is too much? Boxerocks Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 11-24-2009 07:30 PM
How much boost loss from cracked vacumn line? reddevil Normally Aspirated with bolt-on Forced Induction Powertrain 8 07-14-2006 01:48 AM
How much boost is to much boost? xtheviperx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 09-16-2002 08:49 AM
How much power loss with MRT DP? jclick Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 03-25-2002 05:32 PM
