Old 08-23-2004, 06:00 PM   #1
0db
Member#: 33879
2003 WRX Sporkwagon
Talking Up and running on the AEM EMS
I've used it in the past, when they first were released on my turbo Integra, and I really liked the system. It's a bit overwhelming to have so much flexibility, but it works very well.
Today I got the AEM plugged into my "Stage 2-ish" WRX and fired up their MAP-based base map (say that 3 times fast). Started right up, idled smooth, felt good, so I took it out for a drive. Basically it feels exactly like stock but pulls better up top and doesn't have ANY of the stumbling/hesitation that I've gotten used to. So far so good!
Wideband says I'm at 12:1 at cruise / idle, and 9.8:1 at full boost, so I know I can tweak some more power out of this map but it's good to feel safe with the starting values.
The timing was tuned on CA 91 octane, supposedly their tuner put it to what he felt was safe and then pulled 2-3 degrees off everything to add some margin, so I feel pretty comfortable there too.
It's boosting a solid 15 psi on my gauge, which surely accounts for some of the additional quickness I'm feeling, but the boost control is very stable at this value. I probably won't mess with it until I put the 20G in.
All in all, VERY pleasant system. I'll set up automapping tonight or tomorrow and drive it until it's where i'd like (14:1 at least at cruise/idle and start with 10.5:1 at full boost).
I haven't seen many people having any experience with the AEM so I figured I need to represent up in here!
0db is offline   Reply With Quote
Old 08-23-2004, 08:37 PM   #2
rich728
Member#: 40328
2004 WRX STi
BSP #728
how does it connect?
rich728 is offline   Reply With Quote
Old 08-23-2004, 11:27 PM   #3
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
whos stage 2 is that compaiable to
vishnu stage 2
turbo xs stage 2
cobb stage 2
they are VERY differnt
Old 08-24-2004, 08:17 AM   #4
happasaiyan
Member#: 37731
sounds like a txs stg2.
0db, just so you know, you should idle/cruise around 14.7. no need to waste extra gas for nothing.
10.5:1 is a little rich, even at full boost, also. 10.9 in the midrange and 11.0-11.1 up top should be safe.
what the timing like?
happasaiyan is offline   Reply With Quote
Old 08-24-2004, 11:22 AM   #5
0db
Member#: 33879
2003 WRX Sporkwagon
On the hardware side, my car has a gutted stock uppipe, and an APS 3" turboback with one high-flow cat. I compare it to a stage 2 since i have a buddy with a Cobb stg2 reflash and he has basically the same mods.
The AEM matches the factory ECU plug, so you unplug the ECU, and plug the wiring harness straight into the AEM.
I know I'm shooting for a little rich, but I'm stuck with CA gas so I figured I'd be conservative up top. I know I can stretch it out to 14.7 at idle/cruise but I want to keep a margin until I see some datalogs and know that it isn't leaning out on accel or anything.
In about 2 minutes of tuning on the way home from work I got it out to about 10.5:1 anywhere above 7 psi, and about 13.5:1 at cruise. Shouldn't take much more work to clean that up. (boost compensation mapping is REALLY easy to work with, even if it's poorly documented!)
Timing on the base map is around 12 deg at full vac across the board, 15-33 at atmospheric (15 at 500 rpm, 33 at 7500) and 5-20 deg at 16 psi. I'd be interested in comparing this to what others are running!
Old 08-24-2004, 12:53 PM   #6
AZScoobie
Member#: 8785
02 [email protected]
netcom.com
That timing map needs some serious work.
C
AZScoobie is offline   Reply With Quote
Old 08-24-2004, 01:23 PM   #7
0db
Member#: 33879
2003 WRX Sporkwagon
I have no frame of reference, this is my first tuning work on the WRX. I don't even know what the stock timing map looks like. The engine runs smooth as stock, pulls as well if not better, and not a hint of detonation so I wasn't too worried, but I would LOVE to get some feedback on what works well for this engine!
Old 08-24-2004, 02:17 PM   #8
happasaiyan
Member#: 37731
C
i was thinking the same thing.
Old 08-24-2004, 02:19 PM   #9
0db
Member#: 33879
2003 WRX Sporkwagon
Seriously, if I could at least see a stock ignition map it would be helpful. All I can find is UTEC info which doesn't do any good without a starting frame of reference.
Old 08-24-2004, 02:20 PM   #10
0db
Member#: 33879
2003 WRX Sporkwagon
I've got the map in Excel or an HTML table format, is there any way I can post the whole thing up so you guys can look at it?
Old 08-24-2004, 02:24 PM   #11
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
Just download a TXS stage 2 basemap for the UTEC and look at the timing in UTECEdit or just notepad.
cdvma is offline   Reply With Quote
Old 08-24-2004, 03:33 PM   #12
0db
Member#: 33879
2003 WRX Sporkwagon
WOW, holy crap, the TXS stage 2 map is really drastically different from the AEM. Especially the low-load timing. I'll try plugging in similar values to the TXS and see how she runs.
Old 08-24-2004, 03:41 PM   #13
AZScoobie
Member#: 8785
netcom.com
Consider that the Utec maps 0 column is set to ECU so the factory ECu is in control.. That means this map you are looking at is:
1. Only active past 60% TPS.
2. Is really a crappy map to start with
3. Has not enough advance in the lower load columns
4. Has way to much advance in the higher load ranges (for 91 cali pump)
I have some Link ECU maps that I tuned(link is Speed density). But you need the Link software to open and view them.
Clark
Old 08-24-2004, 07:45 PM   #14
0db
Member#: 33879
2003 WRX Sporkwagon
Clark
I thought it looked pretty damned aggressive up top and way too simplistic everywhere else.
I just downloaded the PCLink software from their website, will that let me view your stuff? That's very generous of you to share.
Old 08-24-2004, 07:51 PM   #15
AZScoobie
Member#: 8785
netcom.com
Old 08-25-2004, 12:20 AM   #16
0db
Member#: 33879
2003 WRX Sporkwagon
emailed, thanks!
Old 08-25-2004, 09:40 AM   #17
bikerboy
Member#: 5477
2007 R171.473
2009 SWP Spec B
This is why this place is so good! If only there was more sharing of information and less bickering!
bikerboy is offline   Reply With Quote
Old 08-25-2004, 02:40 PM   #18
0db
Member#: 33879
2003 WRX Sporkwagon
Yeah, I think these conversations are a lot more positive than 4 pages of bickering about FMICs vs TMICs.
Old 08-26-2004, 03:01 PM   #19
rtype16
Member#: 48770
I have personally worked with the EMS and the EMS department is really good friends of mine over at AEM. The timing map if anyone was curious is basically the stock map tweaked a little bit. They do a lot of datalogging on the stock ECU through the OBDII port and make the timing map off of that. They plot all the information out and use that as a starting point. So all in all your timing map is not gonna be that far off. Just a few degrees for margin and up top higher boost you may need to trim up.
rtype16 is offline   Reply With Quote
Old 08-26-2004, 03:06 PM   #20
0db
Member#: 33879
2003 WRX Sporkwagon
That's good to know. Of course I imagine the stock timing is drastically altered by the "learning" ECU, so what they pull from a live OBD port might be very different from car to car. Not that it's a good or bad thing... just thinking about how that might affect things. Overall the car feels pretty good, and it fires up nice and easy every time (albeit with the additional bit of cranking all standalones seem to need for syncing).
Old 08-26-2004, 03:54 PM   #21
CK02WRX
Member#: 27859
2002 EJ257 w/CP's
8cmFP Red, RA 5spd, Hydra
I downloaded the AEM EMS software a few months ago and noticed it had auto tune. Have you used the auto tune feature? If so, does it work well? I'm glad to see people posting about the AEM. It doesn't seem like many subie guys are using the AEM. The Last time I checked their forums there wasn't much info the wrx. It's been awhile so it might be different now.
CK02WRX is offline   Reply With Quote
Old 08-26-2004, 04:09 PM   #22
AZScoobie
Member#: 8785
netcom.com
Yikes... The Factory ECU has the authority to adjust 10 degrees in most places. Somtimes more, sometimes less. Its an active system.....
C
Old 08-26-2004, 06:07 PM   #23
0db
Member#: 33879
2003 WRX Sporkwagon
I used it extensively on my Integra, in its early days, and it worked great. I was within 0.1 AFR of my target ratio everywhere on the map after about an hour worth of driving around. I haven't messed with it on the WRX yet because I'll be changing everything pretty soon (new turbo, IC, fuel setup, etc.).
I think it's a great system; AEM kinda dropped the ball getting it out so late because now it seems that everyone's completely set on the Hydra which pretty much came up out of nowhere. I went with the AEM because i've used it before, they've had a good amount of time to get the bugs out and add interesting new features. Plus I'm working on an EVO and we could run the AEM on both and really cut down my learning curve.
Old 08-27-2004, 07:03 PM   #25
AZScoobie
Member#: 8785
netcom.com
yeah.. Been busy. Let me send those files ova...
C
Why can the AEM EMS not pick up subaru cam/crank signals correctly? Brydon Other Engine Management 17 04-27-2010 04:41 PM
First hand impressions on the AEM EMS for DBW ... [email protected] North West Impreza Club Forum -- NWIC 10 01-26-2009 10:37 PM
MY RS- T-boned, hit and run on the parkway tonight 3BadHabbits Tri-State Area Forum 27 09-20-2004 08:04 PM
Any New word on the AEM EMS? Ryan23 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 02-19-2002 10:16 AM
WOW, hurry up and jump on the bandwagon! Bobalouy General Forum Archive 48 12-25-2000 04:25 PM
