Old 08-24-2004, 09:24 AM   #1
overdose
Member#: 46399
0000 Knows nothing,
about nothing.
Default P030x codes before engine is warm part throttle 0-2psi
Keeps happening, tuned map on stock turbo/fuel with APS 70mm CAI, trims look ok... what's going on ?
utec
overdose is offline   Reply With Quote
Old 08-24-2004, 09:55 AM   #2
overdose
Member#: 46399
0000 Knows nothing,
about nothing.
usually it's multiple codes too, like cylinders 1/2 or 1/2/3 or 2/4 whatever
Old 08-24-2004, 01:41 PM   #3
overdose
Member#: 46399
0000 Knows nothing,
about nothing.
Old 08-24-2004, 02:14 PM   #4
happasaiyan
Member#: 37731
too rich @ idle? new spark plugs needed?
those are the misfire codes...im trying to get rid of them myself.
happasaiyan is offline   Reply With Quote
Old 08-25-2004, 12:21 PM   #5
overdose
Member#: 46399
0000 Knows nothing,
about nothing.
well i let ecu have control of timing 10/20% and that seemed to help, now sometimes it'll throw it when i clutch in and the revs drop, too rich?
Old 08-25-2004, 01:18 PM   #6
happasaiyan
Member#: 37731
your map (from what i can see in the logs) looks really weird. are you running OLF? you go from small negative values to 0 to -6. seems drastic. your fuelling might be going too nuts for it to keep up and is throwing misfire CELs.
check your spark plugs.
Slight "whir"-ing sound when engine is warmed up... ctkeith Newbies & FAQs 8 09-29-2008 11:07 PM
p030X codes? gleesamo Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 05-04-2007 04:10 PM
sti wont start when engine is warm RichWRX Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 07-09-2006 05:54 PM
Going to look at/buy wrx engine, is my part list complete? BenBortner Subaru Conversions 12 06-03-2005 11:07 PM
Turbo Engine needs warm up before driving? cinemaster Engine Management & Tuning 10 06-01-2005 01:15 PM
