Old 08-24-2004, 04:05 PM   #1
WRXakaBooSTi
Member#: 61119
2004 Stock WRX
Default How much does it help to change the 4 stock speakers, but leaving the stock 6cd head?
How much of a difference in sound would there be if i were to get aftermarket speakers with the stock 6cd head unit? Does the fact that the stock head unit is powering the speakers mean that its always going to get distorted at high volumes? Or would aftermarket speakers make it sound much crisper and add clarity?
WRXakaBooSTi is offline   Reply With Quote
Old 08-24-2004, 04:51 PM   #2
04blkWRX
Member#: 40890
04 WRX Sedan
You probably won't be satisfied with the improvement. I'd bet the new speakers will just bring out the crappiness of the HU to a greater degree.
04blkWRX is offline   Reply With Quote
Old 08-24-2004, 05:12 PM   #3
offset
Member#: 32636
2004 Impreza STi
Silver/Silver
If you are really stuck on the 6disc HU but still want better sound I would say the first step is an LOC and amplifier. After that you can upgrade the speakers and you would have even better sound. The HU is pretty week to just go with new speakers. If you really don't want to work toward a whole new system, you could try just speakers. But if you do that I would recommend the Infinity Reference line and not much else. They will be a noticeable improvement and may be enough to make you feel satisfied. But for most people that still isn't enough. Getting a new HU and keeping the stock speakers would be another option if you were willing to give up the factory radio for a cheap (that is relative) upgrade.
offset
offset is offline   Reply With Quote
Old 08-24-2004, 06:27 PM   #4
WORWRX
Member#: 36078
2003 WRX Sedan
This is true; I rode around with my MB-quarts connected to the stock HU before I finished my system and it sounded worst than the stock speakers.
WORWRX is offline   Reply With Quote
Old 08-24-2004, 09:34 PM   #5
Mr Ludecrs
Member#: 58830
2004 WRX
My front speakers buzz with certain levels of bass. I'm just trying to elimnate that. Do you think better quality OEM size replacements + some dynamat would help at all? I really don't want to spend much. It sounds like those of you who ran aftermarket speakers on the stock deck had high end/possibly oversized speakers.
Also, what's an LOC?
Mr Ludecrs is offline   Reply With Quote
Old 08-24-2004, 10:17 PM   #6
chrisdeaner
Member#: 24625
Don't waste your money on the dynomat just yet. The buzz isn't from stuff rattling in the car, it's from the crappy speakers distorting the bass. If you can afford to get some new speakers (even just the fronts for now) and a new HU, you'll have a large, noticable improvement (and you shouldn't have to spend too much on either to make a difference). Otherwise, you'll need to add an aftermarket amp onto aftermarket speakers in order to really make them sound good...
-Chris
chrisdeaner is offline   Reply With Quote
Old 08-27-2004, 10:35 PM   #7
Mr Ludecrs
Member#: 58830
2004 WRX
I think I'll go w/ an amp and new speakers in the front (maybe rear too). I'd like to keep the stock head unit for the stock look + I like the 6 disk in dash changer.
The amp would probably fit under one of the front seats, no? Can anyone recommend a setup?
Old 08-28-2004, 01:47 AM   #8
wrxinmn
Member#: 57922
how much does it help to add an amp to the equation?
i recently replaced the stock with alpines all the way around. i did notice some improvement but definitely not the amount i was hoping for. that was my first move in the system upgrade. im currently finishing up a sub box for dual 10's and i also bought an amp to power the 4 door speakers. assuming i have reasonably good quality equipment, how much of an improvement will i see in adding the amp and sub/amp?
i will be replacing my headunit eventually.
wrxinmn is offline   Reply With Quote
Old 08-28-2004, 01:59 AM   #9
iceinject
Member#: 1318
2003 WRX Cobb Sedan
An LOC is a Line Output Converter
It converts speaker level input to RCA outputs. Our 6 discs don't have RCAs out. Some amps have speaker level inputs on them, but all have RCAs. If you buy an LOC from someone, say www.davidnavone.com it will allow you to hook up the 6 disc to an aftermarket amp as well as it can be done (short of a new headunit)
Tuned right (gains) and wired right (power/RCAs well seperated) this type of setup can sound VERY good. but then again I have two 1/3 octave eqs so that may help a bit too...
iceinject is offline   Reply With Quote
Old 08-28-2004, 02:02 AM   #10
iceinject
Member#: 1318
2003 WRX Cobb Sedan
btw, aftermarket amp is very VERY important. The stock head isn't bad, but it struggles to pump out somewhere like 10 watts per channel (peak). When they aren't forced to power the speakers, modern OEM heads are very nearly as good as most <$400 aftermarket ones. my opinion of course.
Wagon Exhaust Drone & Sound Deadening - How Much Does it Help? drees Car Audio, Video & Security 102 05-13-2011 02:13 PM
How much does it cost to go to a rally? subiegirl_kt General Community 7 01-16-2010 12:48 AM
Dynomax Bullet Muffler.. how much does it help? wrx2k3 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 03-30-2005 09:53 PM
How much should it cost to change the MT oil? NeoteriX Texas Impreza Club Forum -- TXIC 4 03-22-2004 11:32 PM
How much does it cost to keep a WRX on the track? HoRo1 Motorsports 10 10-10-2003 01:37 PM
