Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Suspension/Brakes/Handling
Old 08-24-2004, 07:14 PM   #1
WorldOne
Vendor Sales Rating: (51)
Member#: 22731
2002 WRB Do-Luck GDA
worldoneperformance.com
Default Do Luck Rear Cross Bars, Great Sale! Pics Inside!
Do Luck Rear Cross bars (RXBs) reinforce your chassis in the same way that a rear sway bar does. A rear cross bar mounts inside of the vehicle cabin right over the transmission hump back against the riser for the rear seat. Rear passenger foot room is hardly compromised with this unit. The only mounting points are the seat belt bolts down by the b-pillar, and new hardware and bolts are provided to bolt the unit into place. Once bolted in your are provided with a wrench which allows you to open up the bar to the stiffness of your liking. Locking nuts hold the bar in place and make for very easy adjustment.
This is one of the only pieces available that will allow you to stiffen up the middle of your frame. These bars are extremely high quality mirror polished stainless and are gauranteed to fit with no issues. Some trimming of carpet is required but its very very minimal.
We have three more units that are not spoken for, and they are being offered for 325.00 shipped. Please contact us if you are interested by email or phone. Emailing us with your phone number telling us that you want one of the units will ensure that we will contact you for order processing very quickly. You may also use the website.
Thanks!
[email protected]
206.938.7975
www.worldoneperformance.com
WorldOne is offline   Reply With Quote
Old 08-24-2004, 07:15 PM   #2
WorldOne
Member#: 22731
Just a note, I personally consider this piece and other Do Luck Chassis stiffening braces to be a key reason why our World One STI was able to perform so well in the time attack event at buttonwillow last year. If you track your STI, this is for you.
Garret
w1
Old 08-24-2004, 08:31 PM   #3
ebeck
Member Sales Rating: (1)
Member#: 35585
RIP I'll always be
The Ver8 Magistrate
Does the Sparco harness bar still fit?
ebeck is offline   Reply With Quote
Old 08-24-2004, 08:48 PM   #4
WorldOne
Member#: 22731
Yes the Sparco, harness bar will still fit, however you will want to have bolts for your seatbelts that are long enough to go though the RXB, the harness bar and still have enough threads to be safe. I can not speak about whether the provided bolts are long enough to do this. Worst comes to worst you could find a bolt that was longer with matching size and thread pitch, which is not a very daunting task.
Please let me know if you have any more questions.
Old 08-28-2004, 01:37 PM   #5
wiseguy1121
Member#: 18387
02 WRX Wagon
Ttt
wiseguy1121 is offline   Reply With Quote
Old 08-31-2004, 09:50 AM   #6
Puckaveli
Member#: 1518
00 2.5RS
GC chassis?
Puckaveli is offline   Reply With Quote
Old 08-31-2004, 01:26 PM   #7
WorldOne
Member#: 22731
Sorry...
I do not have the GC chassis in stock right now. The GDs are all that were available, and there is only one more bar left. Please let me know if you have any more questions!
Old 08-31-2004, 07:46 PM   #8
FLEMON
Member#: 64806
I have always been interested in this piece.
I run in T-1 so I need every bit of help in suspension.
What exactly does this bar do? Does it give over,under steer?
What does it do?
Im also interested in your subframe.
FLEMON is offline   Reply With Quote
Old 09-01-2004, 02:27 PM   #9
WorldOne
Member#: 22731
Hi there...
This bar has a very simliar effect to a rear sway bar, only not quite as pronounced. It stiffens up the center of the car and anchors in to place very firmly. Once installed and opened up from the center you could pick the car up by this thing. Its give much more support through the B-pillars and is most noticeable during hard cornering and when trying to hold a line. If your goal is neutrality, this piece definately contributes to a more neutral stance.
Thanks!
SoCal : Do-Luck Aluminum Floor Support & Do-Luck Rear Cross Bar!!! outcast SCIC Private Classifieds 0 06-17-2009 04:47 PM
SoCal : Do-Luck Aluminum Floor Support & Do-Luck Rear Cross Bar!!! outcast Suspension/Brakes/Handling 0 06-17-2009 04:42 PM
Do-Luck Rear Cross Bar pitstops Private 'For Sale' Classifieds 7 02-16-2006 07:43 AM
Brand New VF-22 and Do-Luck Rear Cross Bar RK Performance Private 'For Sale' Classifieds 16 07-16-2005 09:15 PM
Do-Luck rear cross brace sidewayz Private 'Wanted' Classifieds 0 01-29-2004 12:35 AM
