Old 08-25-2004, 08:45 AM   #1
fastlane
Member#: 17470
2002 WRX Wagon 5 Spd
^^Nomo - 04 GT Stang now
Question When do you need a bigger MAF?
Here is my situation. I just picked up a Garret GT30 turbo and I am planning on installing it very soon. I am concerned that I might need a bigger MAF however. Right now, I am pulling about 3.9v when on boost with my VF39. What is the max voltage the MAF produces and how much correction can I add with the UTEC?
On a side note, I am currently using PE600 injectors and I am planning on swapping in my modded stockers. Can anyone tell me what to set the injector mapping at in OLF?
Thanks!
fastlane is offline   Reply With Quote
Old 08-25-2004, 09:10 AM   #2
big_adventure
Member#: 40501
2005 Decathalon 21sp
One WheelSeanPower
On a WRX engine, you will not NEED a bigger MAF. That said, what model GT30R is the cartridge?
Anyway, the MAF sensor goes to 5.0v, which is a boatload of air. I run a GT30R with an RA Spec-C engine, and I only see 4.9v's on race-gas at 26psi+.
At what engine speed and in what gear are you stuck at 3.9v on that vf39? That's miserable for that turbo - you should see 4.4-4.5v on pump, easily. When I had a vf34 and an FMIC, I saw consistent 4.6v.
-Sean
big_adventure is offline   Reply With Quote
Old 08-25-2004, 09:44 AM   #3
Soon2Bgreat
Member#: 2258
1999 gc8 ver7 6mt
GT35R 504.7whp;)
it's a -10. 44lb turbo.
For injectors...you can start at 740 and see how rich you will be (with 0's everywhere). I've started them at 800 and it was still very rich on the vf22. Just make sure your fuel trims are semi close.
BTW i'll have a bigmaf with that perrin inlet pipe I'll let you know
Soon2Bgreat is offline   Reply With Quote
Old 08-25-2004, 10:47 AM   #4
big_adventure
Member#: 40501
One WheelSeanPower
Thanks Louis -
fastlane - there is no way you NEED a BigMAF with that turbo. Use the stock MAF diameter and tune easier with it.
-Sean
Old 08-25-2004, 10:51 AM   #5
fastlane
Member#: 17470
Thanks for the replies folks. I don't have a log in front of me to reference but IIRC I am seeing the 3.9-4.0v in 5th from 3700-5700.
Hey Louis....definetly keep me in the loop about the inlet as I might not need to bigmaf like I was thinking.
Old 08-25-2004, 11:02 AM   #6
Zackbo
Member#: 43151
04 STI
Kinda Silver-ish
You'll see higher maf's at higher rpm's. the engine is pulling in more air. that's your problem. Check the maf at full boost and 7k rpm's.
Zackbo is offline   Reply With Quote
Old 08-25-2004, 11:13 AM   #7
TheMadScientist
Member#: 23717
2005 Big red
That is not ALL ways the case. Some setups will pull more air at alower rpm. Depends alot on the turbo. I run ~4.6-4.7v in the high midrange but because the turbo is so small I only get ~4.4 at redline.
TMS
TheMadScientist is offline   Reply With Quote
Old 08-25-2004, 02:17 PM   #8
big_adventure
Member#: 40501
One WheelSeanPower
4.8v for me up high on pump, 4.9v on race, both from ~6K up to >8K. It's amazing what a big turbo and big intercooler can do for you.
-Sean
Old 08-25-2004, 02:20 PM   #9
TheMadScientist
Member#: 23717
2005 Big red
Yeah my boost curve looks like ^
TMS
Old 08-25-2004, 02:22 PM   #10
big_adventure
Member#: 40501
One WheelSeanPower
On the bright side, you're probably at max boost while I'm stuck below a bar. Except in 6th, my car won't go past 20psi (just getting started for my turbo) until past 4K. Of course, I can run 23.5-24psi on my 93 octane daily-driver map...
The tradeoffs, the tradeoffs.
-Sean
Old 08-26-2004, 01:44 AM   #11
rroberrto
Member#: 27104
the maximum MAF voltage will occur at peak power, therefore not necessarily at redline
Robert
rroberrto is offline   Reply With Quote
Old 08-26-2004, 07:46 AM   #12
fastlane
Member#: 17470
Could my low maf voltage possibly be from a crack or tear in the stock inlet pipe letting in unmetered air? As it stands, my car seems to run quite well but not as well as I would think it should. I was able to hit 106 mph at the track but that was with a mix of 104 and running about 20 psi. Unfortunately, I wasn't able to get a datalog of the run to see what the MAF voltage was hitting.....
Old 08-26-2004, 09:02 AM   #13
big_adventure
Member#: 40501
One WheelSeanPower
Your issue is most likely revs. Take a log and post it...
-Sean
Old 08-26-2004, 09:31 AM   #14
fastlane
Member#: 17470
Will do.
Old 08-26-2004, 09:48 AM   #15
bryan carbon
Member#: 34060
-Sean
I don't think maf voltage is consistent amongst cars. I have a dyno proven 364whp at 26psi. I was only pulling 4.6v. Overdose has a 13G and pulls 4.3v.
bryan carbon is offline   Reply With Quote
Old 08-27-2004, 11:17 AM   #16
fastlane
Member#: 17470
After checking some logs last night, I am pulling 4.3 - 4.4 volts but it is up in the 6000-6200 rpm range at 17 psi. So I guess I was looking at the wrong place in the logs.
Old 08-27-2004, 07:21 PM   #17
AZScoobie
Member#: 8785
02 [email protected]
netcom.com
True.. it certainly does vary from car to car. Its an indication of airflow over the sensor itself. If you keep that in mind you are ok.. Inlet pipes, Intakes, elbow pipes, air filters and your air densite and temp all have a pretty drastic effect on those readings.
The other thing to keep in mind is that the ECU cannot read up to 5 volts. The ECu itself will only read to high 200's in Grams... Past that your ECU is ignoring the extra input. From memory thats around 38lbs of air flow.. Any turbo past the 1820 or so will have the ability to max the ECU.. If I flash an ECU I can extend the load columns a bit to gain control back but its limited by RPM. Also note that the higher the RPM, The lower the limit of MAF flow the ECU can read..
The deal... Anything past 38lbs in flow and you need a larger MAF tube to lower the reading across the sensor. This will stop you from pegging the ECu so MAF trickery fueling can work or the ECU can be flashed for the larger pipe to drop the load readings down. In short. Most of us "need" a larger pipe but we get away with it so we dont "need" the larger pipe.... I bet mine is pegged by 5k..
C
AZScoobie is offline   Reply With Quote
Old 08-27-2004, 08:07 PM   #18
eightballrj
Member#: 18520
2005 L GT Limited
Clark what you are saying is that people that have reflashes might want to run a larger diameter MAF tube since you have a limited airflow scale to play with. But, people with OLF and a UTEC can in fact almost max out the stock airflow meter with a smaller dia. piping without worry??
Richard
eightballrj is offline   Reply With Quote
Do i need a bigger maf? JDMFLCL Pre-2002 Factory Turbo Powertrain 4 12-03-2009 12:07 AM
Do you need a bigger / better UPS? avatarr Mid Atlantic Impreza Club -- MAIC 2 06-20-2004 09:13 PM
when do you need re-balancing? iloveturbos Tire & Wheel 1 07-15-2003 01:09 AM
When do you need to upgrade the header? Jake Steed Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 10-31-2002 09:07 AM
When do you need to align/balance the wheels? e_a_olson Newbies & FAQs 7 07-15-2001 02:16 PM
