Go Back   NASIOC > NASIOC Subaru Models > Baja Forum
Old 08-25-2004, 03:43 PM   #1
mjalex007
Member#: 66022
2005 Baja Turbo
Default What Fits the Baja Turbo
In my pursuit of modding my 05 Baja Trubo, I've been trying to figure out what works from the STI/WRX worlds... Some things are pretty obvious, like a boost controller or intake; it isn't so clear for other stuff.
For example, I recently bought a Perrin Performance intercooler hose kit and found that only two of the three pipes fit, although Perrin's Web site indicated that it would fit the Baja (actually it won't fit an 05 but apparently it will fit an 04).
I sent off an e-mail to Perrin and they've been helpful letting me know what of their stuff will fit the 05 (and I assume 04). Here's what they told me:
"--WRX intakes
--STI rear sway bars and links, not the WRX.
--WRX front endlinks
--TMIC will work, but you need the y-hose specifically for it and not the one you bought that is for the WRX.
-WRX crank pulley
--STI fuel injectors
--WRX downpipe and uppipe
At this point the catback doesn't work, or at least we haven't tried it.
The FMIC may fit but not for sure, the main problem is the bumper plastic not being opened up enough for the IC to show through.
"I hope that helps with future purchases and questions you might have. There is a dealer local to us, who owns a Baja and has installed these parts and has some experience with that car/truck. Their name is Rallitek performance, and the number is 503-309-8645."
I've bought stuff from Rallitek already and have been pleased about my dealings with them.
mjalex007 is offline   Reply With Quote
Old 08-28-2004, 07:46 AM   #2
Chris N
Member#: 5322
07im +07Leg+00Forest
Scooby wrench turner
What about the Sti turbo? If, of course, you changed to STi up and down pipes? The nitty-gritty of hose and bracket fitment would probably be a headache. STi computer? Fuel injectors would probably have to be done at the same time.
I'm glad they tried the swaybars. The wicked under steer of the Baja bugs me. Worse than an 88 Escort.
Chris N is offline   Reply With Quote
Old 08-28-2004, 08:42 AM   #3
mjalex007
Member#: 66022
2005 Baja Turbo
I don't know about the STI turbo, but there are several other options as far as I can figure out. AVO makes 300 to 500 HP turbos that will fit the Baja. I don't know about the STI ECU but, you could go with a Unichip or have your ECO reflashed by Vishnu when that is available (supposedly at the end of the month).
Old 08-28-2004, 08:50 AM   #4
mjalex007
Member#: 66022
2005 Baja Turbo
Default Updated List
I've been checking around and these parts are available for the Baja (most based on Web sites). I'm sure that if Perrin's uppipe or downpipe fits, then everyone elses' will fit too, so that would make the list quite extensive...
PERRIN PERFORMANCE
WRX intakes
STI front and rear end links (not WRX)
WRX front endlinks
TMIC with Y-hose for TMIC
WRX crank pulley
STI fuel injectors
WRX downpipe
WRX downpipe
Cold air intake
Turbo inlet tube
O2 simulator
Manual boost controller
Positive response steering system
Panel filter
AGENCY POWER
Crank pulley
STI
Transmission mount
Short-throw shifter-5 speed
Air filter
CRUCIAL RACING
Uppipe
AVO
Short-throw shifter
Waste gate actuator
320 HP turbo
400 HP turbo
450 HP turbo
500 HP turbo
Uppipe
Turbo timer
GP MOTO
Headers with uppipe
Short pod kit
Mechanical CEL fix
Cold-air intake
TVM
Short-throw shifter
KARTBOY
WRX shifter bushings
IPD
Rear sway bar
COBB TUNING
Cold-air intake
Crankpulley
Short-throw shifter
Shifter bushings
Transmission mount
Fly wheel
Front limited slip differential
Pro-street clutch kit
Front strut-tower bar
Stainless-steel brake lines
328 MM big front brake kit
K&N
Air filter -- 332232
Oil filter -- HP1008
XCCELERATION
Uppipe
Downpipe
Turbo-back exhaust
Cat-back exhaust
Hot stage 2 street cams
Hot stage 2 cylinder heads
Hot short block
HOT 11.2:1 CR racing pistons
Exedy street clutch
Exedy flywheel
DASTEK
Unichip
INJEN
Cold-air intake
GREDDY
Radiator cap
Old 09-14-2004, 07:33 AM   #5
mjalex007
Member#: 66022
2005 Baja Turbo
I found out the hard way the Perrin rear sway bar does not fit the Baja...
Old 09-15-2004, 09:15 PM   #6
Chris N
Member#: 5322
Originally Posted by mjalex007
IPD
Rear sway bar
So this one probably wont fit either.
Old 09-16-2004, 06:43 AM   #7
mjalex007
Member#: 66022
2005 Baja Turbo
Rallitek says that the IPD will fit, and I'd trust them on that point. They have a Baja and they actually try things on it unlike some vendors. I'm going to give that one a try after I get my dough back for the Perrin.
Will this grill fit the Baja? pcmdude Baja Forum 5 04-17-2008 11:49 AM
Will WRX rotors fit the Baja Stock setup? billzebub Baja Forum 6 03-04-2008 05:59 PM
Any coilovers that fit the Baja? DiscoWagon Baja Forum 1 06-04-2006 08:12 PM
How many of you are angered that the Baja turbo was out before the Legacy turbo? ciper Legacy Forum 23 08-05-2003 12:11 AM
so when is the baja turbo due at the dealers? Big Nasty Baja Forum 3 06-27-2003 10:18 PM
