Old 08-25-2004, 08:37 PM   #1
Benjamin Tang
Member#: 4496
2009 Forester
red
Default problem! showing no boost on boost gauge
it just happened. defi boost gauge. i've had it for 2 years. today it was working and then suddenly when i came to a stop and it dropped to zero. it only reads when i'm at WOT, and the needle is bouncing all over the place. i am getting boost, but not sure if it's all there.
i tried looking for anything loose, but it's a rats' nest in there...
help?
Benjamin Tang is offline   Reply With Quote
Old 08-26-2004, 01:57 AM   #2
voam
Member#: 33460
2003 WRX Wagon
Is the gauge mechanical or electrical?
My electrical oil temp guage started jumping all over the place and one of the connectors on the back of the gauge was loose. I would check there first and then work your way from there.
voam is offline   Reply With Quote
Old 08-26-2004, 03:47 AM   #3
KIMUTAKU
Member#: 19776
2012 GVF SWP
Ninja Lime Green
my greddy elec gauge did the same thing before.. it showed boost, but not accurate.. the reading was below usual..
couldn't figure out the problem.. so changed all the rubber hoses.. bingo! back to normal.. i guess one of the hoses was melted and clogged..
KIMUTAKU is offline   Reply With Quote
Old 08-26-2004, 06:12 AM   #4
sti118
Member#: 62310
2000 WRX
Dark Blue
Default Re
check the rubbler house first and see any bend or sthing like that
sti118 is offline   Reply With Quote
Old 08-26-2004, 10:55 AM   #5
Benjamin Tang
Member#: 4496
2009 Forester
red
i was not present during the installation... which hose am i supposed to be looking for?
Old 08-26-2004, 01:44 PM   #6
KIMUTAKU
Member#: 19776
2012 GVF SWP
Ninja Lime Green
vaccum hoses..
Old 08-26-2004, 11:22 PM   #7
Benjamin Tang
Member#: 4496
2009 Forester
red
well this morning i take the car to work and it's working again, albeit the readings are a bit lower. but as the car warmed up, it dropped further and further down until it stopped reading altogether
Boost and boost gauge problem BajaT05 Baja Forum 19 03-24-2005 08:24 PM
boost gauge problem! acting strange and low boost seasons Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 03-07-2005 02:42 AM
Boost gauge shows no vacuum/what gives? jikhead Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 05-23-2004 04:48 PM
boost gauge problems, reading no vac and 5-6lbs racewagon Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 03-13-2004 04:45 PM
buzzing from Subaru Boost gauge on boost? Cosworth Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 06-29-2001 11:47 AM
