Old 08-25-2004, 09:28 PM   #1
CMJ
Member#: 39235
Default Utec molex plug, you might have one around the house.
If you have an old computer lying around you can use the plug from the power supply for your utec. The plug on the power supply is a 20 pin unit, cut 8 pins off one side and it will fit perfectly.
CMJ is offline   Reply With Quote
Old 08-26-2004, 09:47 AM   #2
x99percent
Member#: 27108
2004 STi
2004 A4
Some older Kenwood head units use a plug that is identical to the UTEC plug.
x99percent is offline   Reply With Quote
Old 08-26-2004, 12:36 PM   #3
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
nice to know.. thanks!
ken
Old 08-26-2004, 05:07 PM   #4
TurboXS (Pete)
Member#: 16704
The Molex plug and crimps are also available at Digikey. However we do provide a Molex plug with every UTEC.
regards
Pete
(TurboXS)
TurboXS (Pete) is offline   Reply With Quote
Old 02-14-2005, 04:09 PM   #5
litebrite2001
Member#: 41656
2002 WRX Wagon
would you happen to have the digikey part numbers? I wish the plug just came fully loaded from the beginning, or at least the pins so I don't have to search...
litebrite2001 is offline   Reply With Quote
Old 02-14-2005, 04:19 PM   #6
TheMadScientist
Member#: 23717
2005 Big red
TheMadScientist is offline   Reply With Quote
Old 02-14-2005, 06:03 PM   #7
mcowger
Member#: 77483
2009 Audi A3 2.0T q
Lava Grey
Further info - the pushwheel switch on the other other side is a 10 position binary encoded pushwheel switch made by Cherry. I happened to have a rotary encoder laying around with the same truth table and wired it up to my UTEC - works great....and FAR cheaper than the $80 TXS charges .
mcowger is offline   Reply With Quote
Old 02-14-2005, 06:24 PM   #8
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
i did the same.
WTB ma few random parts you may have lying around the garage STI-NKR TXIC Private Classifieds 2 12-23-2008 03:11 PM
Testing the water...Might Have One HFStival Ticket Left Over... I25 Mid Atlantic Impreza Club -- MAIC 9 05-02-2005 05:12 PM
