Old 08-26-2004, 10:21 AM   #1
big_adventure
Member#: 40501
2005 Decathalon 21sp
One WheelSeanPower
Default Wish list for next UTEC rev...
TXS and all -
Consider this "user feedback". Here's what we (well, I) would love to have in rev 4.3 or 5.0 (or would that be UTEC 2005(tm)?):
1. Integration with Tuner WB for targetted AFRs.
2. Ramp function for ECU-to-UTEC and UTEC-to-ECU timing changes.
3. MAP-based option.
4. Pulse time adjustments for non-stock based injectors.
5. Per injector global correction - dial in an extra 2% in 1 cyl, or something.
6. OBD-II monitoring and DTC reading/clearing.
7. Selective CEL pass-thru - enable a map of CELs that you do/don't want to trigger the CEL light. Would clearly require #6...
There are other things that would be nice, like low-impedence injector capability, but those might require a hardware change.
Yeah, I know, I'm demanding. These are just what came to mind.
-Sean
big_adventure is offline   Reply With Quote
Old 08-26-2004, 10:51 AM   #2
bikerboy
Member#: 5477
2007 R171.473
2009 SWP Spec B
bikerboy is offline   Reply With Quote
Old 08-26-2004, 11:06 AM   #3
happasaiyan
Member#: 37731
very nice list. i would take them in this order:
2 (not just timing...fuel, too)
(not mentioned) avcs control
6
1
5
7
4
3
man, i cant wait for the next major release. i wanna see whats up their sleeves.
happasaiyan is online now   Reply With Quote
Old 08-26-2004, 11:44 AM   #4
StiDreams
Member#: 26315
07 Outback
Silver/Silver
I like the list. I would like it in this order:
2 (timing & fuel)
1
6
<-- ability to reorder logging columns. This would probably cause confusion on this board when posting logs. But sometimes I don't really want to see everyting in log 1 and the other logs don't have what I'm looking for.
5
The next five are things that I probably will never use but the rest of the community would probably like.
<-- AVCS control. This one might be one that I would move up on the list if I were to have/gain a better understanding on what it does for performance. Haven't really looked into it because I can't control it. Even if I could, could I do better than the factory ECU? It still might be fun to play with down the road.
<-- Rev limit remove for STi. This would be nice for those going to V7/V8/custom heads.
7
4 This one I might use.
3
StiDreams is offline   Reply With Quote
Old 08-26-2004, 12:24 PM   #5
dosage0
Member#: 42323
2004 WRX
Silver - UTEC, Tuna, TBE
Any idea when they may release another update? I'd love to see targetted AFRs.
dosage0 is offline   Reply With Quote
Old 08-26-2004, 12:43 PM   #6
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
considering the crossover hesitation is the most often cited complaint regarding the utec vs. other management solutions, i think it would be in txs' best interests to address that issue posthaste.
Old 08-26-2004, 01:01 PM   #7
Macabre
Member#: 3841
2004 WRX Wagon
UTEC+VF22+WI
Specifying MAFS voltage to the thousandths place would make me happy
Macabre is offline   Reply With Quote
Old 08-26-2004, 01:41 PM   #8
big_adventure
Member#: 40501
One WheelSeanPower
Macabre, do you mean displaying it to the 1/1000 place? All we do now it apply a percentage mod to the real MAF value. By definition, it's already at the 1000's place to voltage, because we can do xx.x percent (1/100).
Anyway, measurements are pretty much useless beyond 3 significant figures. While there is a huge difference between 4.5 and 4.6, there isn't that large of a difference between 4.54 and 4.55. I could, therefore, live with 100's.
About #2 - good tuning will take care of the fuel and prevent any fuel-related hesitation at all. If fuel changes even 4-5%, you're not going to feel it, and if it's changing more than that, you've done a lousy job tuning it. However, you can feel even 1 degree of sudden timing change if you're looking for it, and the conditions are right, and you can feel 3 degrees easily.
I didn't mention AVCS control because, honestly, it's below the bottom of my list. My RA ECU does a pretty good job with AVCS now. In addition, that's not something I really want the UTEC messing with - instantaneous 5 degree cam transitions could be nasty.
-Sean
Old 08-26-2004, 02:31 PM   #9
AZScoobie
Member#: 8785
02 [email protected]
netcom.com
The most important feature we need is more range on the Injector scaling for OLF mode.. This 600CC limit is really hurting alot of people.....
The second most important thing is the injector dead time adjustment for the Utec. There are lots of injector options out there now and with the Utec you are stuck at stock injector timing.. It would be nice to not have to tune aroud this.
Clark
AZScoobie is offline   Reply With Quote
Old 08-26-2004, 03:26 PM   #10
happasaiyan
Member#: 37731
600cc limit?
Old 08-26-2004, 03:33 PM   #11
pegdrgr
Member#: 25693
2008 18x9" goodness
E85-380ftlbs @ 3100
600 cc limit on the "stock" injector size.
You can say you are running 1000cc, but you have to tell the UTEC what the ECU thinks it has. Anyone who has reflashed their ECU to run larger injectors has to make an unusual map to deal with that situation.
pegdrgr is offline   Reply With Quote
Old 08-26-2004, 03:36 PM   #12
Macabre
Member#: 3841
2004 WRX Wagon
UTEC+VF22+WI
Oopsie. I meant hundredths
I really want to be able to use this value to divine g/s reasonably accurately, or get some idea of how much flow difference I see vs. the same 4.5ish no matter what. 10ths is fairly useless especially near the upper limits of the non-linear curve where .1v is a very significant flow difference.
Old 08-26-2004, 04:53 PM   #13
pestysti
Member#: 52765
2004 STI
what a bout a dual stage launch control.... launch at 55 and flat foot at 61 or some thing thke that...
what about a more output for silonoids control so i can turn my neon on when i hit 60%throttle...
pestysti is offline   Reply With Quote
Old 08-26-2004, 05:01 PM   #14
TurboXS (Pete)
Member#: 16704
We are always listening to your ideas and feedback.
UTEC software is constantly being developed and I always review this and other forums for changes and features that we can add to the software.
Some of the suggestions from this and other forums are already being worked on.
I am a bit surprised that the injector range is not wide enough for some people, particularly the stock injector range. Some additional detail about how you are using this parameter would be useful.
How would you plan to tune this?
regards
Pete
(TurboXS)
TurboXS (Pete) is offline   Reply With Quote
Old 08-26-2004, 05:03 PM   #15
Macabre
Member#: 3841
2004 WRX Wagon
UTEC+VF22+WI
That reminds me of the biggest request I'd have- an additional duty cycle map for the spare solenoid
Old 08-26-2004, 05:21 PM   #16
nmyeti
Member#: 4980
4.2c has this fix already. The max value on both parameters is now 1000cc.
-Nathan
www.turboxs.com
nmyeti is offline   Reply With Quote
Old 08-26-2004, 05:23 PM   #17
pegdrgr
Member#: 25693
2008 18x9" goodness
E85-380ftlbs @ 3100
oops!
Pegdrgr runs to download 4.2c
Old 08-26-2004, 05:27 PM   #18
RiftsWRX
Member#: 6124
2000 NFR AP1 S2000
'07 Honda FIT sport (5MT)
Since not everyone who can tune this has the time, or skills to get the transitions setup right. Some form of interpolation delay type algorithm for entering and exiting open loop. On both timing and fueling values.
Open loop IAT temperature and possibly barometric pressure compensation. I've seen quite a few instances of AFR's drifting lean as barometric pressure increases. Sometimes as far as .2-.4 AFR's.
EDIT: let me add to this... on time compensations for larger injectors.
Jorge (RiftsWRX)
www.ProjectWRX.com
RiftsWRX is offline   Reply With Quote
Old 08-26-2004, 05:36 PM   #19
big_adventure
Member#: 40501
One WheelSeanPower
-Nathan
www.turboxs.com
Which is why I didn't mention it. Thanks Nathan!
C -
I though you knew, for some reason. I will now proceed to hit myself in the head with a hammer. Try it, it's fun!
-Sean
Old 08-26-2004, 05:40 PM   #20
big_adventure
Member#: 40501
One WheelSeanPower
Per cylinder EGT probes. If one cylinder is a little hotter, give it some extra gas. If one is a little cooler, pull some out.
It's not the most important thing, clearly, just a value-added option. Hence the low place on my list, in fact, it probably should be lower.
-Sean
Old 08-26-2004, 05:46 PM   #21
AZScoobie
Member#: 8785
netcom.com
C -
-Sean
Nice! I had no idea it was there.. I will load it into my utec and attempt OLF again...
C
Old 08-27-2004, 09:46 AM   #22
x99percent
Member#: 27108
2004 STi
2004 A4
- Interpolation across rows for timing and fuel. It already does this within columns.
- Temperature correction TABLES for boost, fuel, and timing?
- Boost table values that mean something (an actual target number in psi, bar, MPa, whatever)
- gear or speed-dependant boost control?
x99percent is offline   Reply With Quote
Old 08-27-2004, 10:04 AM   #23
TheMadScientist
Member#: 23717
2005 Big red
Change boost map from TPS to MAP for use as a water injection map.
TMS
TheMadScientist is offline   Reply With Quote
Old 08-27-2004, 10:54 AM   #24
happasaiyan
Member#: 37731
i like the first 2...
Old 08-27-2004, 10:59 AM   #25
TheMadScientist
Member#: 23717
2005 Big red
Temp corection that will do + and - at the same time. Right now you can only use either + or - corection.
TMS
For Sale! Utec Rev.6b onefastwrx555 Private 'For Sale' Classifieds 12 05-03-2006 07:39 PM
WTT: 2004 Cobb Accessport for TXS UTEC Rev. 6 phenemwrx Private 'For Sale' Classifieds 3 02-24-2005 08:50 PM
Stock wish list for your WRX chrislehr General Community 10 01-06-2003 06:53 PM
Ultimate Subaru Christmas Wish List (Anyone game for this?) caut10n Texas Impreza Club Forum -- TXIC 29 11-06-2002 05:56 PM
('93-'01) Wish list for the 2003 WRX--a poll mr_disco Impreza Forum 48 08-12-2001 11:40 AM
