Old 08-26-2004, 04:50 PM   #1
MINO
Member#: 12841
Default Your thoughts on grams per second / volts (maf)
I've been doing a lot of research on air flow since I've decided to fab a cold/ram air set-up on the stock box. I don't think the ram air would change anything because I'm still on the OE airbox and it is turbo/intercooled afterall (it was more of a fun project for the weekend).
Curious, I finally decided to check the MAF today and found that in 3rd gear, 17 psi, 6900 rpm, I am at 227 g/sec (what is that? 4.45 volts?). I am catless with APS TMIC, fuel mods/ecutek and Deadbolt 16g, 91 octane. Does that flow sound right based on my mods? Comparing against other similar modded Utec logs, I'm assuming yes.
I think I've been hearing some detonation on the top-end since doing the ram air but I can't imagine it adding/changing much more flow/air than the OE+elbow delete+snorkel. I didn't bother to check the pre ram-air flow but will be doing so this weekend.
Here's my "I had too much time on my hands" project:
MINO is offline   Reply With Quote
Old 08-27-2004, 09:33 AM   #2
attitude
Member#: 52043
04 sti
how does the air get from the scat tube to the turbo inlet?
attitude is offline   Reply With Quote
Old 08-27-2004, 09:59 AM   #3
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
Luck?
cdvma is offline   Reply With Quote
Old 08-27-2004, 10:03 AM   #4
attitude
Member#: 52043
04 sti
Old 08-27-2004, 11:51 AM   #5
MINO
Member#: 12841
very funny guys. the 3.5" tube fit's right in the airbox inlet hole with the grommet removed.
Grams per second-cfm?IAM of 15? quazimoto Commercial ECU Reflashes 7 07-30-2009 04:51 PM
your thoughts on the evo-style vortex generator on an 06 wrx chu my pu Interior & Exterior Modification 11 04-19-2007 10:41 PM
Your thoughts on picking my turbo, your #'s? CatfaceType-R Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 48 03-12-2007 12:20 PM
thoughts on the 5 second rule? ataac_flat04 Off-Topic 17 12-09-2002 04:00 PM
TEC-II anyone have one? your thoughts on it?? tonyb New England Impreza Club Forum -- NESIC 10 02-07-2001 08:22 PM
