Go Back   NASIOC > NASIOC Subaru Models > 'Old School' Subaru Forum
Old 08-26-2004, 05:48 PM   #1
jstbecauz
Member#: 69122
Default 1986 GL Wagon help
Hey there, I have an 86 GL Wagon with a fuel injected 1.8 automatic transmission. The car has no spark at all, I have replaced the distributor, ECU, coil, and timing belts. When it first stopped running the last fusible link blew, the ones that are on the left hand strut tower. After replacing the fusible link it had no spark. I am still sitting here with a dead GL and wondered if anyone has run into this before. I tested the wires at the ECU and they have the correct voltage and resistance, as well as the CAS at the distributor.
Any help would be appreciated.
Thanks
jstbecauz is offline   Reply With Quote
Old 08-26-2004, 07:27 PM   #2
Sub_Speed_Guy
Member#: 25007
2004 WRX
OEM +
Starter?
Sub_Speed_Guy is offline   Reply With Quote
Old 08-26-2004, 09:43 PM   #3
jstbecauz
Member#: 69122
Originally Posted by Sub_Speed_Guy
Starter?
It turns over, it has no spark though
Old 08-26-2004, 11:26 PM   #4
dusktilldawn
Member#: 57766
1987 GL Wagon 4WD
The Silver Bullet
got 12v at the coil with the ignition on?
dusktilldawn is offline   Reply With Quote
Old 08-27-2004, 07:40 AM   #5
jstbecauz
Member#: 69122
Yes and there is 10+ volts at pins A+C and 4+ volts at pin B at the CAS harness. There is also the correct voltage and resistance at the ECU harness.
Old 08-27-2004, 03:25 PM   #6
Flowmastered87GL
WCSS Drunk
Member#: 8914
2005 Baja Sport
Regal Blue Pearl
I lost spark on mine due to a fuse blowing, fusable links were all fine. Have you checked the 15Amp fuse under the dash??
Flowmastered87GL is offline   Reply With Quote
So CA: 1986 Subaru GL Wagon Blue $600 crowbar Private Vehicle 'For Sale' Classifieds 9 07-12-2008 08:41 PM
Free to a good home: 1986 GL-10 Turbo Wagon WJM Private Vehicle 'For Sale' Classifieds 10 04-01-2007 10:23 PM
For sale: 1986 Subaru wagon GL joshslegacygt96 Private 'For Sale' Classifieds 1 07-09-2005 10:38 PM
1986 gl wagon 1.8 wvance 'Old School' Subaru Forum 2 09-13-2004 07:09 PM
