Welcome to the North American Subaru Impreza Owners Club Saturday September 24, 2016
Old 01-27-2000, 05:42 PM   #1
JJTheSubeDriver
Member#: 391
2004 STi Blue/Gold
2000 RS BRP
Question Weird electrical problem
I noticed something this morning: I stopped the car, took the key out of the ignition, and my radio stayed on!! WTF?? I'm taking it into the car stereo shop to look at it tommarow. Any ideas on this one?
JJ
JJTheSubeDriver is offline   Reply With Quote
Old 01-27-2000, 06:04 PM   #2
paultg
Member#: 437
'91 Miata MX5 (Red)
'09 Impreza OBS (Blk/Gry)
Post
I am no expert, but I would say they wired your power lead on the radio directly to the battery, so it now has constant power.
Paul G.
paultg is offline   Reply With Quote
Old 01-28-2000, 09:39 AM   #3
soob2k
Member#: 567
Post
ihad that same thing in my last car, the(usually red) power wire was wired directly to the battery, all you have to do is remember to turn the headunit off when you getout of the car. otherwise you'll come back to a dead battery.
soob2k is offline   Reply With Quote
Old 01-28-2000, 10:24 AM   #4
mlomker
Member#: 777
Post
The accessory power is often a yellow wire.
mlomker is offline   Reply With Quote
Old 01-28-2000, 08:23 PM   #5
JJTheSubeDriver
Member#: 391
2004 STi Blue/Gold
2000 RS BRP
Wink
OK- Found out what happened. Headunit recieved a surge after dealer installed a power window switch and door lock auctuator without disconnecting power causing a short and then surge (Ok, ok that's what I think happened, but I do know they did not disconnect battery )
Solution: Car Toys installed a brand new headunit and tested all electricals. It works fine now. Next- Amp installation.
JJ
Weird electrical problem GooseMan Electrical & Lighting 4 06-22-2004 06:39 PM
Dead WRX -- weird electrical problem Fubaru Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 05-14-2004 01:08 AM
weird electrical problem! markyrage Electrical & Lighting 4 04-24-2004 02:34 PM
Weird electrical problem with single headlight Stroke Electrical & Lighting 1 11-05-2003 09:58 PM
weird electrical problem need help! Evegan Normally Aspirated Powertrain 3 09-03-2002 06:47 PM
