Old 08-27-2004, 11:48 AM   #1
JessesTalon
Member#: 63925
95 R33 / 06 WRX
Dark Slvr / Crystal Slvr
Default Help me out with this issue (smoke out exhaust
last few days I'm getting some white smoke out my exhaust... it seems like alot to me, but not like all the time, its almost clear, just barely has a white color to it.
it smells a little like coolant/water.
I just topped off the overflow bottle with some watterwetter from redline, it went a little over the "max" on the overflow bottle, could that be the excess water burning off through the exhaust?
or maybe am I looking at a Headgasket taking a dump. (not to familar with boxer engines, any help is appreciated)
JessesTalon is offline   Reply With Quote
Old 08-27-2004, 11:56 AM   #2
sixpack subaru
Member#: 64974
1995 WRX,APEXi,HKS,$
Faded, Stonechipped Red
Is it using Coolant??
Coolant when 'Vaporised' has an acrid smell....
Overfilling the coolant CANNOT help it into the Combustion chamber....
Only happens when Cold??
Sixpack Subaru
sixpack subaru is offline   Reply With Quote
Old 08-27-2004, 12:07 PM   #3
JessesTalon
Member#: 63925
95 R33 / 06 WRX
Sixpack Subaru
no it does it when it is fully warmed up too...
at WOT at night yesterday in 2nd gear, from like 3000-5500 rpm's seemed like lots of smoke was pouring out of the exhaust
Old 08-27-2004, 12:19 PM   #4
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Yep,
sounds like a head gasket to me.
Are you still under 100k miles? There was a service recall on our cars and you are covered to 100k. I got mine done with 13 miles left on the ticker. It is a good opportunity to discount some mods if you have any planned. I had the clutch and pressure plate replaced along with the cams, oil pump and a bunch of seals and gaskets while it was apart. I spent less than $500 on labor because the engine was already out of the car...
Old 08-27-2004, 12:36 PM   #5
JessesTalon
Member#: 63925
95 R33 / 06 WRX
Originally Posted by Matt Monson
Yep,
at 56k miles... I shouldn't be having a headgasket problem...
I just went to the dealer and asked if If I had any recalls that are open and the Dealer said one.. tha thad to do with the cooling system, and it got done :-)
Should I go back and ask them to take a look and see if somethign went wrong?
Old 08-27-2004, 12:39 PM   #6
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
my hg's went at 56k in my DOHC 2.5L....
so dont think it cant/shouldnt happen to you
the "cooling system" service bulletin you just had filled, is the headgasket 'recall' that was referred to already.
yes i would take the car in and have it looked at...
white smoke out the back = bad
jamie
www.subiegal.com
Old 08-27-2004, 01:02 PM   #7
RockRaceScooby
Member#: 57120
1999 Forester
Red
There are recalls and there are bulletins. The dealer will tell you about recalls, but not necessarily bulletins. It used to be, you could get a list of the titles of recalls and bulletins from http://www.alldata.com/ for your car.
RockRaceScooby is offline   Reply With Quote
Old 08-27-2004, 01:23 PM   #8
sixpack subaru
Member#: 64974
Interesting that you are all saying white smoke, when the 2.5 Quad Cam was not known for this type of H/Gasket failure!! They normally fail between Combustion chamber and Water Jacket, resulting in coolant loss and 'STEAM' from exhaust.
Please clarify
Sixpack Subaru
Old 08-27-2004, 03:17 PM   #9
JessesTalon
Member#: 63925
95 R33 / 06 WRX
Please clarify
Sixpack Subaru
Steam smoke, looks the same to me... :-P
Seriously though, After I make a quick stop by Home depot to make a cold air box... I'm thinking about going to Subaru and seeing if there is a problem, I really hope they don't charge my ass... :'(
OT IT gods. Help me with this issue please slo06sti Off-Topic 12 08-13-2008 06:56 PM
SQL gurus, help me out with this query - $5 paypal if working before noon EST! Jessie James Off-Topic 12 04-06-2006 12:02 PM
OK, I'm sure someone can help me out with this Thunder Lungs Off-Topic 5 08-18-2005 11:03 AM
I forgot a screen name... help me out with this... Texas25RS Texas Impreza Club Forum -- TXIC 17 08-15-2005 02:29 PM
