Welcome to the North American Subaru Impreza Owners Club Wednesday July 8, 2015
Go Back   NASIOC > NASIOC Subaru Models > Baja Forum
Old 08-27-2004, 03:07 PM   #1
2003Baja
Member#: 52985
Default Where is the manual for removing the door panels?
I used to know of a website that told me how to remove the front and rear door panels.....It seems like I cant find it anymore....can someone help me out?
2003Baja is offline   Reply With Quote
Old 08-28-2004, 02:07 AM   #2
BajaNut
Member#: 36905
2014 Outback SAP
leggtnut on lgt.com
I haven't found one. I looked, but I have taken mine off and might be taking them off in the near future. I can take pictures and do a wirte up. But it is quite simple.
I was able to take mine off w/out taking out a single screw.
there are a bunch of tabs on the lower part of the door
The hardest thing is to make sure and not do what I did and break the bezel around the door handle. There are 3 clips, upper, lower and next to the lever. the one next to the lever is the hardest to get to and can cause it to break.
Next you wiggle/pry the door out then up. Make sure to be gentle with it because there are a couple of clips under the sill next to the window and if you bend it, it can cause a rattle. That is why i have take mone off sometime soon.
Ben
BajaNut is offline   Reply With Quote
Old 08-28-2004, 04:14 PM   #3
mjalex007
Member#: 66022
2005 Baja Turbo
The instructs for installing upgraded speakers has what you need:
Installation guide
mjalex007 is offline   Reply With Quote
Old 08-28-2004, 08:03 PM   #4
2003Baja
Member#: 52985
Alright thanks. I am going to do a couple things in the few upcomming weeks
I got my permit
Old 09-20-2004, 04:34 PM   #5
SiOrange
Member#: 27679
2002 Impreza WRX
Installation guide
Will this work for a WRX since these instructions are for a legacy?
SiOrange is offline   Reply With Quote
Old 09-21-2004, 09:34 AM   #6
mjalex007
Member#: 66022
2005 Baja Turbo
Check out the other installation guides at the same site.
94 L Manual Roll-Down Window / Door Panel Questions fubarsubaru Interior & Exterior Modification 2 04-16-2007 09:10 PM
How to remove 2005 door panels brad_in_denver Interior & Exterior Modification 5 01-29-2005 11:30 PM
removing driver's door panel winewagon Service & Maintenance 2 05-30-2003 05:00 PM
Help removing my door panels Dre2932 Interior & Exterior Modification 12 10-01-2002 03:00 AM
Best way to remove 97 door panel? HIHO Legacy Forum 3 08-20-2001 08:12 PM
