Welcome to the North American Subaru Impreza Owners Club Saturday September 5, 2015
Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Suspension/Brakes/Handling
Old 08-27-2004, 05:39 PM   #1
WorxTuning
NASIOC Manufacturer
Vendor Sales Rating: (0)
Member#: 42684
Default STi Brake Upgrades- In Stock & on Sale!
New Specials page is up! Here are some of our current Sale Items.
We have 2pc. drilled rotors in stock and ready to ship for the 04 STi. 05 is coming soon (now accepting pre-orders).
The WorxTuning 2pc. front brake rotors for the STi are a direct replacement for the factory rotor. They feature a directional vein pattern and cross drilling for superior cooling over stock, and the drill holes feature a chamfered edge to reduce the chance of cracking. The hat is made from aerospace grade aluminum that has been hard anodized for a durable finish, and has radial vent holes at the hat/rotor mounting surface which aid in caliper cooling and even pad wear. Total rotating mass is reduced roughly 5 lbs. per rotor, and they are a fraction of the cost of a factory rotor. Take your factory Brembo system to the next level. Pad and line upgrades are also available.
MSRP - $689.99 SALE - $589.99
Also, while you are working on your brakes:
WorxTuning Stainless Steel brake lines feature the highest quality PTFE lined hose covered by stainless steel braid. A clear protective covering is also applied for increased abrasion resistance and long term cosmetic durability. Installation of these lines will give you a more responsive brake system with a firmer pedal feel. No more spongy performance due to the expansion of the factory rubber lines. Our lines are D.O.T. approved and carry a lifetime warranty against manufacturers defects. They are also a factory match meaning that they retain all factory fitting and mounting tab styles.
Available for WRX or STi
MSRP - $119.99 SALE - $74.99
You can find our Sale page with online ordering at www.WorxTuning.com/specials/specials.htm
Thanks
Mike
WorxTuning is offline   Reply With Quote
Old 08-29-2004, 07:30 PM   #2
sti63
Member Sales Rating: (1)
Member#: 57248
Great to deal with. TTT.
sti63 is offline   Reply With Quote
Old 08-31-2004, 08:26 PM   #3
WorxTuning
NASIOC Manufacturer
Member#: 42684
Thanks
Old 09-08-2004, 04:51 PM   #4
sti63
Member#: 57248
Hi Mike, How long will these specials be running? Also will the 05 brake rotors be on special. Thanks Carl
Old 09-08-2004, 04:56 PM   #5
WorxTuning
NASIOC Manufacturer
Member#: 42684
Carl - Specials will be through the end of this month. 05's are included in the price, we are just waiting to get 05 rotors in.
Thanks
Mike
Old 09-08-2004, 05:44 PM   #6
sti63
Member#: 57248
Thanks Mike, I will take a set of the 05 rotors and a set of the brake lines. Also thank you for the pictures that you e-mailed me. The stock rotors i beleive weigh 23lbs so that means there is almost a 8 lbs savings!!! Great job.Carl.
Old 09-09-2004, 03:34 PM   #7
wduvall
Member#: 35352
2004 STi
Silver/Silver
Who makes the 2-piece STi rotors? Are you able to get them in slotted instead of cross-drilled?
wduvall is offline   Reply With Quote
Old 09-09-2004, 07:17 PM   #8
ami2fst4u
Member Sales Rating: (10)
Member#: 40638
'04 PSM STi
Has some work done... ;)
Are rear rotors available? What is the weight on the 2pc front rotors compared to the OEM front rotors?
Rick
ami2fst4u is offline   Reply With Quote
Old 09-09-2004, 07:18 PM   #9
WorxTuning
NASIOC Manufacturer
Member#: 42684
The brakes are WorxTuning brakes. We only stock drilled, but can order slotted rotors and build them that way as a special order. Price would be the same. Let me know if you have any other questions.
Thanks
Mike
Mike@WorxTuning.com
Old 09-09-2004, 07:21 PM   #10
WorxTuning
NASIOC Manufacturer
Member#: 42684
Rear rotors are under development. They will be pretty spendy because they will retain the e-brake. This requires a hat constructed of Aluminum and Titanium.
The front rotors weighed 6 lbs less than the stock STi that came off of our car at 30k miles. The new 2pc was 15.12 lbs and used stock was 21.10 lbs. The weight reduction is surprisingly noticable. After installation it really felt like the car had its light weight track wheels on.
Driveline Motoring /// STRI & Defi Gauges & Pods *IN STOCK & ON SALE* DriveLineSales Gauges & Electronics 39 06-18-2009 02:29 PM
Gallery Fresh - Engine Dress Up Kits l Full Kits for WRX/STi In Stock & On Sale!! DriveLineSales Exterior/Styling 2 05-08-2009 01:45 PM
APR and Carbign Craft Summer '08 Sale! Lots in stock and on sale. GNV Motorsports Exterior/Styling 34 06-27-2008 12:29 PM
Unorthodox Ultra SS Pulley Sets for STi in stock and on sale! GNV Motorsports Engine/Power/Exhaust 6 01-18-2007 12:48 PM
