Old 01-12-2001, 10:32 AM   #1
ImprezedRS
Member#: 2771
2003 BMW Z4
Post 10" Side Panel Sub Install!
Hey everone i just finished installing a 10" sub in the drivers side rear panel after seeing that someone did it with a 8" sub and it sounds really good and has no box for added weight i will post pics of it soon and will be finishing the other side this weekend.
And also if anyone else wants to do this i still have two 10" subs left and will sell them for $50 and you pay shipping
ImprezedRS is offline   Reply With Quote
Old 01-12-2001, 10:39 AM   #2
bratmantlz
Member#: 3231
88 626 Turbo
white
Lightbulb
just looking forward to those pics i have some 10's and about to get a amp finally so might do the low pro install dont like how the box takes up the trunk.
bratmantlz is offline   Reply With Quote
Old 01-12-2001, 01:21 PM   #3
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
Post
Glad to know that the 10" subs fit, since I was planning on doing the same.
What subs are they?
Old 01-13-2001, 09:55 PM   #4
AaronB
Worst Mod Ever
Member#: 369
Question
Do the subs hang over the edges of the baffle you created to mount the speakers to?
When I put my 8"s in there I contemplated putting my 10"s in but the speaker diameter would have been larger than the baffle I made. I didn't want to compromise any more strength than I already had, so I chose to go with the 8"s and a solid 3/4" mdf baffle. I figured that was the only strong wall of the enclosure
AaronB is offline   Reply With Quote
Old 01-14-2001, 02:39 AM   #5
CosmoTheCat
Member#: 3409
1998 Ram 2500
Green.
Post
You guys have photos?
CosmoTheCat is offline   Reply With Quote
Old 01-14-2001, 02:59 AM   #6
AaronB
Worst Mod Ever
Member#: 369
Talking
For some dumb reason I didn't take any photos of my install. You can see where I got the idea from at http://www.importcars.net/subaru Dan did a good job of documenting his install.
I did the sae thing except I dynamatted the area first, I used a baffle that covered the entire opening, and I reused the stock fabric to cover the speaker opening so it looks 100% stock.
Aaron
Old 01-15-2001, 09:19 AM   #7
ImprezedRS
Member#: 2771
2003 BMW Z4
Post
I used 3/4 MDF piece which covered up the entire hole that was in the side and then mounted the sub from the backside as the sub would hit the panel inside the car and i also sealed of the inside of the hole with spary in foam and Liquid Nails sealent. As for pictures i'm getting ready to take them now, and will have them up withn the hour.
Old 01-15-2001, 09:41 AM   #8
Chuck
Member#: 791
1998 Impreza RS
Brilliant Red
Post
Heh... that's where I mounted my amps.
Chuck is offline   Reply With Quote
Old 01-15-2001, 03:04 PM   #9
elemental
Member#: 2701
'00 obs
Question
i dont understand... can you tell what volume the enclosure is? how do you run the wire to the sub? im always confused with the basic questions
elemental is offline   Reply With Quote
Old 01-15-2001, 08:44 PM   #10
omahasubaru
Member#: 1594
1995 WRX
2011 WRX
Post
Where's the pics???? I'm waiting!
omahasubaru is offline   Reply With Quote
Old 01-16-2001, 12:05 AM   #11
CosmoTheCat
Member#: 3409
1998 Ram 2500
Green.
Post
If I'd only known.... I might have bought a coupe.
Old 01-16-2001, 06:55 AM   #12
ImprezedRS
Member#: 2771
2003 BMW Z4
Post
I will have the pics up today i'm looking for the connector for the camera to download the pics to my PC
Old 01-16-2001, 01:49 PM   #13
omahasubaru
Member#: 1594
1995 WRX
2011 WRX
Post
sweet I can't wait!!
some details as to what all you did/used would be a bonus too!
What kind of subs are you selling??
[This message has been edited by omahasubaru (edited January 16, 2001).]
Old 01-16-2001, 09:04 PM   #14
ImprezedRS
Member#: 2771
2003 BMW Z4
Talking
Ok here are the pics, finally, but i will be soon posting all the details to doing this when i do the other side.
The sub without cover on,
<IMG SRC="http://albums.photopoint.com/j/View?u=1357564&a=10113925&p=38294378&Sequence=0" border=0>
Now with the cover,
<IMG SRC="http://albums.photopoint.com/j/View?u=1357564&a=10113925&p=38294395&Sequence=0" border=0>
It still needs a little bit of cosmedic touchups before its really done. The subs are JBL Loud and Clear subs.
[This message has been edited by ImprezedRS (edited January 16, 2001).]
[This message has been edited by ImprezedRS (edited February 01, 2001).]
Old 01-17-2001, 12:41 AM   #15
jdOgg3355
Member#: 3053
2005 Legacy LTD 2.5i
Obsidian Pearl
Question
I guess I don't get it. What did you bolt the 'box' to? You aren't drilling right into the body panel are you?
If anyone could send me more detailed instructions on how this install is done, I would greatly appreciate it. The ones on the above link are kinda fuzzy to me.
Thanks
[This message has been edited by jdOgg3355 (edited January 17, 2001).]
jdOgg3355 is offline   Reply With Quote
Old 01-17-2001, 02:46 AM   #16
hacman
Member#: 3603
Question
Anyone that's been runnin this for a while... have any excessive body rattle or loose panels? That's the only thing that's making me want to spend the extra cash to get the fiberglass enclosures over the foam.
hacman is offline   Reply With Quote
Old 01-17-2001, 07:03 AM   #17
ImprezedRS
Member#: 2771
2003 BMW Z4
Post
So far no body rattle(thanks to the foam i sprayed in it) and no loose panel which i don't think will come loose since those are welded to the rest of the body
Old 01-17-2001, 07:48 AM   #18
Bob O
Member#: 1502
2000 2.5RS & SV1kS
BRP
Post
What approximate volume did you end up with? The smallest 10's usually are spec'ed for .6 ft^3, though you can get away with less by stuffing it. What's the specs for the JBL stuff and how close you you think you got to the required volume?
thanks
Bob
Bob O is offline   Reply With Quote
Old 01-17-2001, 10:20 AM   #19
ImprezedRS
Member#: 2771
2003 BMW Z4
Post
I do not know what the volume of the space is but it sounds about right. The 10"s i have are for 1 cu ft of air space
Old 01-17-2001, 11:43 PM   #20
hacman
Member#: 3603
Post
Here's the detailed instructions from <a href="http://www.importcars.net/subaru/" target="_blank">Dan's Impreza RS </a>page...
<a href="http://www.importcars.net/subaru/speaker.html" target="_blank">Stealth Sub Install</a>
Old 01-18-2001, 11:02 AM   #21
ImprezedRS
Member#: 2771
2003 BMW Z4
Post
Thanks hacman
Old 01-18-2001, 11:19 AM   #22
8Complex
Member#: 922
04 FXT
Red
Post
Here's a question for anyone that has done this - does the side of your car where you sprayed in the spray foam sound different when you knock on it? I imagine it must, but isn't that wierd?
Also, what kind of depth is inside there? I would think by the looks of it, that it would be more suitable for 8's.
Old 01-18-2001, 10:21 PM   #23
ImprezedRS
Member#: 2771
2003 BMW Z4
Post
Well the 10" sub i used wasn't really that deep but it was a close call but where i sparyed the foam now when you tap on the outside it sounds as it is solid inside and as for the other side it sounds hollow. which in turn makes the 10" sub sound even better and about the other subs they where sold tonight.
Old 01-19-2001, 02:03 PM   #24
Ethan
Member#: 246
Post
I just wanted to say that is a sweet idea!! I've wanted to get some subs, but the trunk is already so small.
Ethan is offline   Reply With Quote
Old 01-21-2001, 12:37 AM   #25
Penphoe
Friendly Neighbourhood
Member#: 269
2005 ABP LGT LTD BP6
00 Impreza RS GM6 RIP
Post
I didn't want to get a sub for my car because it just took up too much space in the trunk and stuff -- not unless you ditched your spare and used that as the sub enclosure, or did a false floor for your sub. Installing the sub inbetween the cabin and body paneling is a mighty tempting idea! Looks good! You guyz are making me spend too much money!
LaterZ!
Darren!!
Penphoe is offline   Reply With Quote
Message Board Statistics All times are GMT -4. The time now is 02:22 AM.
