Old 08-27-2004, 08:34 PM   #1
WJM
Guest
Member#:
Default EA82T Forum...?
I am jsut wondering, if with enough interest....we could get a sub-forum either here, or in the Old School forum strickly for the EA82 Turbo engines...tuning and bulding discussions.
Sticky maybe?
Old 08-27-2004, 09:22 PM   #2
Kevin Thomas
Street Racing Instructor
Member#: 110
1989 1989 XT6
Sticky maybe?
I dunno Will! You know you folks are few and far between. I say 'you folks' but I'd be right there with you if I had an EA82T Scooby. Maybe someday if I get rid of my XT6s. I've been feeling the same way as you do about these cars for a long time. There's some potential there that it seems just haven't been unlocked yet.
Kevin Thomas is offline   Reply With Quote
Old 08-27-2004, 09:23 PM   #3
WJM
Guest
Member#:
i tell you what....if you want an EA82T....ive got one sitting here. a WHOLE car at that. RX.
Old 08-27-2004, 09:27 PM   #4
Kevin Thomas
Member#: 110
1989 1989 XT6
? What are you talking about? I'm curious!
Old 08-27-2004, 09:39 PM   #5
WJM
Guest
Member#:
Well, ive got two RX's...the 89 in non running condition...no rear diff or axles, trans is plenty good.its all stripped out and needs body work and the unibody is tweaked in the front. the 88 is in running condition, at near stock condition. Runs good...just a little weak. Sounds suspension on it. Could use rear axle boots re done, as those are...well...starting to sling that stuff out. 3rd gear syncro is weak, other wise its a good car. Some rust issues, as it was a mountian car. Needs new pads and the rotors resurfaced.
Id like to get....well...had plans to make it a parts car. Its woth $1000 to me, and i know thats too much for an RX in this condition. Id trade for an XT6!
the 89 is not going anywhere. Its parts for the wagon. the trans is due to go in it, and the LSD rear is already in. Other suspenion parts and the engine stuffs are going in it. The wiring will be up for grabs and stuff...as well as the interior.
I guess....after I get the susp. and engine/trans out...and load it up with the rest of the two car's interior parts, id let both go for 1k. Clean titles on both.
Now...as another option....i could get you the parts to turn one of those XT6's into an EA82T powered car...read: engine block+heads+manifold and complete wiring harness.
OR.....as it soon may become mine...an 86 XT turbo 2WD 5spd. one stubborn sticky valve in it...its stuck half open. Needs gas tank...its rusty...the tank that is....one can be had for cheap tho.
Old 08-28-2004, 01:06 AM   #6
ohio turbo wagon
Member#: 69240
Default turbo wagon's
hello all, well i ihave a 88 a/t full time 4wd gl-10 wagon, 86 a/t spfi, sedan, 88 dl dual range 4wd wagon , 86 brat, 88 fwd gl wagon, xt in garage stripping out, which will give a single range tranny, and another spare turbo motor , i am going sunday to look at a a/t 4wd white wagon
ohio turbo wagon is offline   Reply With Quote
Old 08-28-2004, 10:55 AM   #7
Calebz
Member#: 54398
1980 CB400 Hawk
1996 GrandCherokeeLimited
I'm here Will.
Calebz is offline   Reply With Quote
Old 08-28-2004, 09:03 PM   #8
subyrally
Member#: 52662
2009 dgm WRX hatch
86 & 87 rx, 1985 brat
i love turbo, now i just need to get it running. i think i just need to set the timing.
subyrally is offline   Reply With Quote
Old 08-29-2004, 12:09 PM   #9
camshaftprelube
Member#: 54415
A strange
Tercel attraction
Yep, I'm here too.
camshaftprelube is offline   Reply With Quote
Old 08-29-2004, 12:37 PM   #10
WJM
Guest
Member#:
Cool.
Old 08-29-2004, 01:57 PM   #11
ohio turbo wagon
Member#: 69240
Default turbo
on my turbo , i have ngk plugs, gaped at .45, k-n filter ,air box mod, cat hollowd out ,2in pipe all the way back , turbo muffler ,
Old 09-02-2004, 07:57 PM   #12
Kevin Thomas
Member#: 110
1989 1989 XT6
Will,
I'm late in replying but that 2nd car being offered sounds interesting. Hrrmmm....
My 2nd XT6 I just purchased is O/S at the moment for some reason. Fusible link blew and ceiling light blew out and I lost all power. I just replaced the fusible link and will be putting in a new bulb. It's at Xotic Motorsports now. I'm thinking the timing belts broke but I'm no mechanic. I couldn't work on the car on property owner's property and towing it from there is a small fortune (40 minutes away). This all happened as I finished testing before and after results of cat back exhaust on the dyno.
"Sounds suspension on it. Could use rear axle boots re done, as those are...well...starting to sling that stuff out. 3rd gear syncro is weak, other wise its a good car. Some rust issues, as it was a mountian car. Needs new pads and the rotors resurfaced."
Sounds like my 2nd XT6 (the one at the shop). Autotranny runs but feels 'weak' to me, especially compared to my other XT6 and OBS's autotranny. No serious rust issues I can think of. I saw some developing in the rear where the spare tire floor is (saw some water there). It has no radio in it since it was removed by previous owner. I've replaced the spark plugs/wires/cap/rotor and fuel filter. It has had the tranny fluid replaced, coolant flushed/replaced and oil changed. I think it's going on two months since I got it. I have some additional spare parts for it as well as 4 16" steel Legacy rims (one is bent) with good tread on them. Brakes seem to be ok and engine runs strong. I have receipts as well as dyno info on the car in AWD and 2WD mode.
I purchased it with the intent on putting Frank Germano's 'InVAID' supercharger system on it. He's just about completed development for it for the XT6.
http://www.xt6.net/forum/viewtopic.php?t=2658
I need AWD to run it and my FWD XT6 has N/A cams in it. So I got this car. However, I may consider a trade for a turbo in good condition. So what do you think?
You can see a few pics of the car(1989 XT6 AWD/Autotranny) I'm talking about in these threads: *Note, My name is Myxalplyx at the site*
http://www.xt6.net/forum/viewtopic.php?t=2709&start=0
http://www.xt6.net/forum/viewtopic.p...highlight=dyno
Old 09-04-2004, 04:25 PM   #13
silvershad0w
Member#: 54124
1988 Subaru RX, x3
White, White, Black
Another EA82T guy here, came over from usmb. 'ohio turbo wagon' where are you at in ohio, are you "86subaru" on the other board by chance? I live in the NE corner of the state.
Kevin, I guarantee if you got that RX you'd love it, they are fantastic cars! I own 2 roadworthy 88 RX's and 1 parts 88 RX. I will be doing a lot of custom work on it which will be posted in the Old School forum, and perhaps engine stuff occasionally here in other factory turbo. XT6's are nice, and I want one someday to play with too, but ea82t cars like the RX are cheaper and more plentiful to get parts for, and really seem to take well to modifications. The only ea82t car that is perhaps a better candidate for auto-x in stock form would be your light and nimble XT Turbos - still can't beat that RX tranny thou!
silvershad0w is offline   Reply With Quote
Old 09-07-2004, 12:00 AM   #14
oddcomp
Member#: 69805
85 subaru rx turbo
i am here 2 ea82t powers unite!! lol
oddcomp is offline   Reply With Quote
Old 09-07-2004, 06:33 AM   #15
Kevin Thomas
Member#: 110
1989 1989 XT6
Thanks for the info. I'm trading emails with Will now about his RX. I have to get my red XT6 in order though. I don't know why it's down at the moment. Fusible link blew and I replaced it and my electricity is back on but it wont start. I have to get this squared away, after I fix my black XT6 (brake calipers and I knocked loose an ECU wire removing the ECU). I have a some loose wiring from hooking and unhooking a fuel controller and ProECM Powerchip.
Hopefully Will and I can trade up and both be happy. I'm actually looking forward to it. I just hope the RX will be ready to drive around as the XT6 will be.
Now, back to the EA82T stuff. Boss just called (I'm at work).
Old 09-07-2004, 07:59 AM   #16
WJM
Guest
Member#:
PM to you!
Old 03-06-2005, 08:04 AM   #17
ohio turbo wagon
Member#: 69240
Default turbo wagon
yes this is 86 subaru western ohio
Old 03-06-2005, 07:58 PM   #18
avatar382
Member#: 37038
1987 Subaru XT Turbo
Baby Blue
I am go!
avatar382 is offline   Reply With Quote
Old 03-15-2005, 10:36 PM   #19
tysn
Member#: 79735
another ea82t 85 xt here.
tysn is offline   Reply With Quote
Old 03-21-2005, 09:34 AM   #20
Caboobaroo
Member#: 72335
89's RX/XT6
Blacksssssss
'89 RX here in Wyoming... got lots of mods going onto the car including a TWE header and a TD04 turbo.. along with many other goodies!
Caboobaroo is offline   Reply With Quote
Old 12-07-2008, 08:03 PM   #21
greenfreak
Member#: 196819
Subaru Stars ea82t heads
i have a set of completly rebuilt heads for a ea82t motor that i need to sell have the paperwork from the machine shop of the work that was done to them i have 550.00 in to them willing to sell for 475 to 500 just ask for pics.
greenfreak is offline   Reply With Quote
EA82T into EA82 car jeffg Subaru Conversions 10 02-12-2006 12:45 PM
EA82T sub forum?? WJM 'Old School' Subaru Forum 12 09-15-2004 09:07 AM
help! Cracked turbo! EA82T (Leone/Loyale) Subaroid Factory 2.0L Turbo Powertrain 2 01-08-2002 05:33 AM
EA82t and EA81t...whats the difference? FLUBYUx2 Factory 2.0L Turbo Powertrain 7 12-17-2001 03:07 AM
Message Board Statistics All times are GMT -4. The time now is 01:30 PM.
