Go Back   NASIOC > NASIOC Subaru Models > Baja Forum
Old 08-28-2004, 10:32 PM   #1
ajabobrut
Member#: 56726
2004 Baja Turbo
Regatta Red Pearl
Default Fog Lights
I've been playing around with these trying to get them to work with the headlights off.And i'm just about there,i had my dealer fax me a wiring diagram of the fog lights and right now i got them working with the lights off,parking on,headlights on.Once you hit high beams the fog light fuse blows.Tommorrow i'm going to disconnect the headlight wire at the relay and that should fix the problem.If this way works,you'll be able to use the fogs any time.It will be just like Factory.
ajabobrut is offline   Reply With Quote
Old 08-29-2004, 12:29 AM   #2
ajabobrut
Member#: 56726
2004 Baja Turbo
Regatta Red Pearl
I could'nt wait and went and cut the wire,still blows the fuse.Looking at the wiring diagram again,the only thing tied into the system is the daytime running lights.It looks like you can either unplug the Diode or the Control Module.With one of those unplugged and the wire cut that leaves nothing left to affect the fog lights.I guess i'll try that tommorrow since i have ran out of fuses
Old 08-29-2004, 01:48 AM   #3
gentzleon
Member#: 66903
2005 baja turbo
onix black
u better be carefull u fry that module ur up some good $$$$$$$$
gentzleon is offline   Reply With Quote
Old 08-29-2004, 01:51 PM   #4
ajabobrut
Member#: 56726
2004 Baja Turbo
Regatta Red Pearl
I disconnected the DRL'S and there's no more fuse blowing,but the fogs still go off on high beams.I'm happy with what i got,i can run parking lights with fogs which is what i was wanting to do.And by doing this i got one extra,i can run just the fogs with out any lights.And the switch works normal.
Old 08-30-2004, 12:26 PM   #5
Pursuit
Member#: 38370
Pursuit is offline   Reply With Quote
Old 08-30-2004, 09:00 PM   #6
ajabobrut
Member#: 56726
2004 Baja Turbo
Regatta Red Pearl
Originally Posted by Texas S
Hey Texas S thanks for the info,i think i remember seeing something like that a while back but i forgot.oh well, i'm happy with the way mine turned out.Mine won't work with high beams,but my switch lights up when its turned on.I'm always a day late and a dollar short,Better luck next time.
FT: 04 WRX fog lights and fog bezels for STI fog light covers WRXSuShi Private 'Wanted' Classifieds 9 11-01-2011 01:59 AM
FS : '04/'05 WRX/STi CGM Fog Light Bezels (Surrounds) in VA TrailRated Exterior/Styling 4 10-27-2010 01:34 PM
FS : '04/'05 WRX/STi Fog lights, Brackets, Switch in VA TrailRated Exterior/Styling 2 07-07-2010 11:49 PM
Which hella fog lights fit the the stock fog light area? advance Interior & Exterior Modification 2 06-26-2001 01:32 PM
Fog light VS Fog light Cover gerardchau General Forum Archive 6 05-19-2000 07:58 AM
