Old 01-16-2001, 07:01 PM   #1
Fred Fredburger
Member#: 2539
Question Switched power wire for radar detector?
Hey, all.
I bit the bullet and just bought a Valentine 1 radar detector. I'm planning on permanently wiring into the car so I still have my lighter plug available.
What is the best wire under the dash/fuse box to connect the power to so it only has power when the ignition's in the "on" position (I don't think it's necessary to have it on with the key in the accessory position).
Also, a general idea/description of the wire would be helpful. I still don't have a Haynes book for my RS.
Thanks!
Geoff.
Fred Fredburger is offline   Reply With Quote
Old 01-16-2001, 08:31 PM   #2
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
2000 2.5 RS, '14 For
92 5MT SVX
Post
Well, if you have a MY00, there is a dark blue wire (with a black stripe I believe) on one of the wiring harnesses for the fogs lamps (or it might have been the cruise control) switch to the left of the steering wheel, which is switched by the ignition. That's what I used for my detector.
Brian
AIM: NUrsalia ICQ: 84483950
http://members.nbci.com/_XMCM/northu...reza/index.htm
Come See The Magic World Inside the Abandoned Refrigerator!
Old 01-16-2001, 08:44 PM   #3
Fred Fredburger
Member#: 2539
Post
I have an '01, but I assume it'll be there.
Thanks for the reply!
Geoff
Old 01-16-2001, 08:51 PM   #4
RidinLow
Member#: 329
1995 325i
Arctic Gray
Post
I just tapped the cigarette lighter terminals, ran that to a switch by the foglight switch, and ran that up the A-pillar to the detector. Works great, you can nonchalantly cut power to the detector by flipping a little switch & the cop didn't see my detector mounted way up high in the corner.
RidinLow is offline   Reply With Quote
Old 01-16-2001, 09:05 PM   #5
Fred Fredburger
Member#: 2539
Post
RidinLow> What's the purpose to your switch in there? So if you get pulled over you can cut the power and not have it beep right next to the cop?
Old 01-17-2001, 08:36 AM   #6
tmat3
Member#: 2817
2001 Impreza 2.5RS
BRP
Post
I tapped everything (little stuff) to the positive cigarette lighter wire. I didn't hardwire my radar detector, but I hardwired my voltimeter to that wire. Works very well.
tmat3 is offline   Reply With Quote
Old 01-17-2001, 09:21 PM   #7
Jessie James
Member#: 2072
Talking
The way to do it, assuming you're using the visor mount, is to wire the thing into your SUNROOF power.
Pop the over head light cover off, unscrew the two screws inside, the whole tihng drops down. Find the power wire (red or yellow, as I recall) and the ground (black I recall) and wire the thing in.
Leave the excess wire in the housing, mount it back, and voila! If you need to pull some wire out, it's easy, and now you don't have to run the wire all the way from the bottom, plus it now looks like a garage door opener (from the outside; parked) because there's "no wire" going to it, so no one busts your window to get it.
Jessie James is offline   Reply With Quote
Old 01-18-2001, 11:28 AM   #8
Fred Fredburger
Member#: 2539
Post
McCavity> Excellent idea. The only problem is that I got the remote display module so I'll still need to run a wire from the sunroof panel down to the dash (or wherever I put the display). Do you know if there's room enough for the direct-wire adapter in the sunroof cavity? It doesn't look that big but it's big enough to be able to plug two phone cords into it (that's what the V1s use for power cords).
Old 01-18-2001, 11:31 AM   #9
RidinLow
Member#: 329
1995 325i
Arctic Gray
Post
Hepcat, yeah, & it worked beautifully (speaking from experience).
Old 01-18-2001, 11:35 AM   #10
Fred Fredburger
Member#: 2539
Post
RidinLow> Do you have a V1? If so, was there enough room in the sunroof cavity for the direct wire adapter?
Old 01-18-2001, 11:37 AM   #11
RidinLow
Member#: 329
1995 325i
Arctic Gray
Post
No, I have some generic BEL... a bit smaller than the V1, & it's mounted on the visor against the corner so you can't see it unless you stick your head in thru the window.
Old 01-18-2001, 11:40 AM   #12
Fred Fredburger
Member#: 2539
Post
No, I'm wondering if there's enough room in the cavity that you tapped the power for the V1 direct power adapter. It looks like it's 1"x1"x0.5".
Power-on delay circuit for radar detector? e28fixer Electrical & Lighting 4 05-01-2005 10:16 PM
Shopping for radar detector. Which one?? I am b Off-Topic 23 03-25-2003 07:56 PM
Wiring in Radar detector through compass/mirror scooby snack Car Audio, Video & Security 5 06-15-2001 11:05 AM
Wiring my radar detector? burr101 General Forum Archive 16 07-02-2000 12:05 AM
