Old 08-30-2004, 09:15 PM   #1
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Default OEM sparkplug come pre-gapped from factory?
NGK platinum plugs for 02 WRX come pre-gapped from the factory?
Old 08-30-2004, 09:19 PM   #2
OneOBS
Member#: 63076
2004 Outback Sport
Red!
All plugs are pre-gapped these days. I sure don't trust them and always double-check the gap. A gauge is what, 50 off the counter at AutoZone? Some multi-electrode plugs are almost impossible to check. All you can really do is give them a good visual check and install them.
OneOBS is offline   Reply With Quote
Old 08-30-2004, 09:58 PM   #3
Hondaslayer
Interpretively Paraphrasing
Member#: 4562
1995 Legacy LSi
1998 Declasse Moonbeam
Yes they do some pre-gapped from the factory.
I lost count of how many suby tune-ups I have done, although I will tell you that I stopped checking the gap sometime after 100 without a single mis-gapped plug.
Old 08-30-2004, 11:27 PM   #4
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
I've found that the NGK's are usually pretty much right at .8mm, which is a bit big for my boost....also....you should inspect them for cracked/broken insulators...I got a box of 10 that likely had been dropped and one was broken in the box.
Old 08-30-2004, 11:32 PM   #5
Hondaslayer
Member#: 4562
1995 Legacy LSi
Yes I should make a note to my post, I do check them if the boxe's appear damaged, or if they were delivered by CCX (Conway **** up Express)
Old 08-31-2004, 10:43 AM   #6
Hayes
Member#: 11808
Like uncle scotty does, i always check visually each plug AND check the gap. Too much trouble if your tune-up runs less than perfect and you start guessing what could be the problem. A misgapped plug may run better that your old plug but for how long if the gap is 0.010 over spec. ed
Hayes is offline   Reply With Quote
Old 08-31-2004, 01:03 PM   #7
vvk
Member#: 6436
1998 Impreza 2.5RS
BDP
Impreza GC8 platinum plugs
As far as I know, platinum spark plugs are not supposed to be checked/gapped. Checking them damages the precious metal layer on the electrodes. The platinum layer may be only a few micron thick and could be damaged by the gap gauge.
Another reason to prefer copper plugs.
vvk is offline   Reply With Quote
Old 08-31-2004, 11:44 PM   #8
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
just installed them~ car runs great.
Pre Gapped Plugs??? ZOMBIEWAGON02 Normally Aspirated Powertrain 7 04-08-2009 02:56 PM
Champion sparkplugs from factory??? Absubtle Forester Forum 6 08-19-2006 12:58 AM
Do all WRX's come pre-wired for the factory subwoofer? mynameischris Car Audio, Video & Security 2 06-27-2006 07:26 PM
Do factory spark-plugs come pre-gapped? TimStevens Service & Maintenance 9 05-02-2003 07:41 AM
