Old 08-31-2004, 08:01 PM   #1
BDR
Member#: 39445
2003 WRX/RA-Geared
07 Honda Fit VIP'd
Default grounding kit ??
i have relocated my battery to the rear and got a hook up on a HKS Circle Earth kit. i was planning on making a post screwed down to the car to the stock batt negative postion. what my ?? is , is the grounding kit just as functional not being mounted on the negative of a battery?
BDR is offline   Reply With Quote
Old 08-31-2004, 11:38 PM   #2
420WRX
Member#: 27752
2004 WRX+Ver.8 EJ207
Long lengths of cable are less effective, but assuming you've used heavy gauge wire from the battery in the back to the components in the front of the car, then taking a ground off of that connection will be your best option. That's not as effective as a battery located closer with a shorter length of cable, but you must of been ready for minor trade-offs when you did the mod or else why would you of done it?
420WRX is offline   Reply With Quote
Old 08-31-2004, 11:44 PM   #3
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Hydra+HMist+PPG+35R=DEATH
for the grounding mod i dont believe you actually need hefty cable
i think that 10 gauge would suffice for runs as long as the car
i dont know that much about electronics, but remember, were only assisting the ground, were not grounding the car
Old 09-01-2004, 09:09 PM   #4
armand1
Member#: 10309
'02 OBS 2-tone!
'95 Montego Miata
Originally Posted by BDR
..., is the grounding kit just as functional not being mounted on the negative of a battery?
Yes (although "just as functional" may just mean that it also has no function ). As 420WRX says, just make sure you have nice big diameter cables from the battery up to the front (probably 0/1 gauge).
Old 01-19-2005, 05:53 PM   #5
subaru mike
Member#: 30749
2002 wrx
Bump...anyone have a trunk grounding kit installed?
subaru mike is offline   Reply With Quote
Old 01-19-2005, 06:08 PM   #6
420WRX
Member#: 27752
Yeah I have a 4ga trunk grounding kit and I dunno what I did without it..
Before grounding the LED in my wing was dim and inconsistent.. Now it's bright like the sun on crack.. And the LED pulses are super responsive.. It's like a night and day difference..
Old 01-19-2005, 10:21 PM   #7
subaru mike
Member#: 30749
2002 wrx
Do you have any picures? I am trying to get some ideas
Old 02-10-2005, 04:55 PM   #8
adeliciouspizza
Member#: 7844
05 STI CGM 450whp
05 FXT CGO Stock
guys, just ignore 420WRX. he apparently has nothing better to do than troll around on nasioc and **** with people. he even started a separate thread to brag about how stupid you all are and how hes such a clever and witty troll. http://forums.nasioc.com/forums/show....php?p=8898519
rich, i think you will be ok with grounding stuff up front even though the battery is in the back. just make sure there isnt alot of paint on the spot where you ground to so you get a solid ground. some people have had to use a little sand paper to get an effective ground.
adeliciouspizza is offline   Reply With Quote
Old 02-10-2005, 06:36 PM   #9
420WRX
Member#: 27752
Hahaha .. weitek gets the golden noogie prize! Too bad you're not a sarcasim connoisseur!?
It's true that it's a sad day when I have to point out my own sarcasim, but that's not my fault.
Oh and I didn't say anyone was 'stupid' .. weitek did though.. please go easy on him.
Basically a trunk grounding mod doesn't exist cause it's not very usefull.. There's nothing in the trunk that really needs a better ground, including the lights.
Old 02-18-2005, 02:59 AM   #10
it8ezbngrn
Member#: 35590
This grounging thing.... It doesn't need huge wires from the battery to all over. You can make a kit with some 10ga wire. All it is doing is making up for all the poor grounding points in the engine bay. Not every connection to the chassis is a perfect ground due to paint, poor welds differences in metal, etc.
I see people dumping money on a grounding kit and LMAO wishing I thought of it first.
it8ezbngrn is offline   Reply With Quote
grounding kit freeze Electrical & Lighting 18 06-10-2011 05:36 AM
SoCal : Sun HotInaZma Ground Kit & Split Fire Japan Hyper Voltage Kit!!!!! outcast Engine/Power/Exhaust 10 12-20-2006 08:14 PM
F/S: SunAuto voltage kit and HKS circle earth grounding kit swift2fly SCIC Private Classifieds 0 10-25-2006 09:55 PM
grounding kits stock ground points spdracr00 Legacy Forum 4 10-30-2005 10:05 PM
intake/ground kit Orville Cote Legacy Forum 1 03-21-2003 11:05 PM
