Old 09-01-2004, 12:06 AM   #1
RallyFord
Member#: 47699
2012 STI Wagon
Dark Grey Metallic
Question Air conditioner not working - AT ALL.
I was wondering if anyone else has had a problem with their air conditioning quitting. I know about the "icing" problems and had started to experience that issue on hot humid days this summer. Just recently, however, I was away on business for a week, away from my beloved Subaru, and came back to drive it and found that the air conditioner wasn't working AT ALL. It was never that great in the first place, but now when you push the air conditioner button with the fan on, it doesn't do anything. It used to make the engine idle higher to run the compressor and such, but it doesn't make any kind of noise and doesn't affect the engine idle at all. Any suggestions as to what may be causing the problem?
2003 WRX - 34400 miles, just barely under warranty yet thankfully.
RallyFord is offline   Reply With Quote
Old 09-01-2004, 07:04 AM   #2
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
Since it's under warranty, just bring it in to the dealership - it could be a number of things, ranging from a dead compressor to a leak which discharged the system to some sort of electrical issue.
Old 09-01-2004, 07:39 AM   #3
rogue
Teddard Snark
Super Moderator
Member#: 7977
100% Abuse
Yeah, it's broken... my 02 with 45k miles still blows cold air just fine, no reason yours should be dead.
rogue is offline   Reply With Quote
Old 09-01-2004, 07:58 AM   #4
Calamity Jesus
Member#: 44501
1984 That's *Sir*
Weinerlicks of Douche 2u.
Checked the fuse yet?
Old 09-01-2004, 08:00 AM   #5
Odin
Member#: 25428
2005 STi
Sounds like a leak in your system. I say this because you were away for two weeks. This exact same thing happened on another car of mine. If you are under warranty go to the dealer. The may run one of those UV tests to check for leaks. If it is a pinhole they won't find it. If you feel like it go buy a couple cans of refrigerant and put them in.
Odin is offline   Reply With Quote
Old 09-01-2004, 08:03 AM   #6
RallyFord
Member#: 47699
2012 STI Wagon
Dark Grey Metallic
beaverboy - thanks, didn't even think to check the fuse
rogue, drd, odin - thank you for the advice, I'll be using it all =)
Old 09-01-2004, 10:28 AM   #7
aerofan897
Member#: 61143
03 Cobb Stg II WRX
WR Blue
Mine hadn't worked since I got the car (although I didnt notice it until summer). Turns out there was a faulty "pressure sensor" for the AC somewhere, and that had to be replaced. The subie mechanic said that if that sensor is easy to mess up on installation, so I guess he's done a few... Subie dealership will know best.
aerofan897 is offline   Reply With Quote
Air Conditioner Not Working seanr2 Baja Forum 8 05-15-2009 03:09 PM
Rear defroster not working at all silence2-38554 Electrical & Lighting 9 03-06-2009 12:49 PM
I installed a SATA Raptor drive, why does my IDE CDROM run slow/not work at all? White 2.5rs Off-Topic 17 06-07-2006 11:46 AM
air conditioner not working FinalBean Service & Maintenance 5 04-27-2004 07:53 PM
Overdoing ground mod will cause it to not work at all! d4d4d4d4 Electrical & Lighting 4 07-14-2003 04:25 PM
