Welcome to the North American Subaru Impreza Owners Club Tuesday September 1, 2015
Go Back   NASIOC > NASIOC Classifieds > Vendor 'Group Buy' Classifieds
Old 11-06-2004, 01:54 PM   #151
afpdl
Member Sales Rating: (1)
Member#: 26361
My shenanigans are
cheeky and fun
Originally Posted by matz73z
Weight balancing is the process of equalizing the weight of the vehicle on each of the tires. Any good race shop should be able to help you with this, if you don't mind paying the race shop hourly rate. Once the weight balancing is done (on a cool set of coilovers like this) then the ride height can be set (because these have the separate adjustment). This way the car's ride height can be set to look level as opposed to being crooked.
That makes no sense at all for any car with any coilovers. Once you corner weight it useing the spring perches if you adjust the ride height afterwards you will throw the weight balance off negating all the stuff you just did.
afpdl is offline   Reply With Quote
Old 11-08-2004, 12:55 PM   #152
ReX_N
Member Sales Rating: (4)
Member#: 22917
2002 Boro WRX (RIP)
aspen white
blank
ReX_N is offline   Reply With Quote
Old 11-08-2004, 12:57 PM   #153
ReX_N
Member#: 22917
2002 Boro WRX (RIP)
aspen white
Originally Posted by RCMM
do the threads have a coating over them to prevent rust or are they just black?
Yeah they are coated.
Old 11-08-2004, 02:23 PM   #154
afpdl
Member#: 26361
My shenanigans are
cheeky and fun
Used them in a autox yesterday, the only issues I was having is I kept lifting the inside rear, but that is not entirely the coilovers fault. If you rotate the front plates you can get almost 7 degrees of caster on the front of an sti and still manage over -4 degrees of camber. So far Im very pleased with them other then the lack of an abs line bracket, and that I recieved the wrong spring rates.
Old 11-09-2004, 04:30 PM   #155
mr. m
Member#: 44229
2000 2.5 RS
blue ridge pearl
these coilovers do have a lot less travel than the stock pieces. im sure thats normal for most coilovers though.
mr. m is offline   Reply With Quote
Old 11-09-2004, 04:32 PM   #156
mr. m
Member#: 44229
2000 2.5 RS
blue ridge pearl
michael, did you find out anything about this. im assuming theyre not an included item since nobody seems to have gotten them but are they doing anything about it?
Old 11-09-2004, 04:42 PM   #157
mr. m
Member#: 44229
2000 2.5 RS
blue ridge pearl
how far down the strut shaft can the strut mount be set? im worried about screwing it too far down and the mount breaking. ill try to clarify later when i have more time but use urbanimports picture for reference.
Old 11-09-2004, 07:14 PM   #158
afpdl
Member#: 26361
My shenanigans are
cheeky and fun
Im well aware of that, my previous suspension was jic coilovers with 7/5k rates and there is alot more wheel lift apparent in the d2s that Im going to have to tune out.
Old 11-09-2004, 10:34 PM   #159
agterlik
Member Sales Rating: (2)
Member#: 41626
SPB We make people
quit teh internet
For the preload thing is the pre load already set where it should be when they arrived to me or do I need to tighten them up some? The ride seems almost bouncy I expected it to be somewhat rough but not in the way that they are currently riding. Also any one puting these on their rs did you have any problems with fitment in the rear having very little to no room for adjusting the camber?
agterlik is offline   Reply With Quote
Old 11-09-2004, 11:28 PM   #160
afpdl
Member#: 26361
My shenanigans are
cheeky and fun
You drop the car then raise it up and just snug up the spring perch to meet the rubber bushing on the spring. As for camber adjustment you can move the allen screws inwards to give you more adjustment.
I havent found these to be bouncy at all, they are firm but havent felt any bouncyness.
Old 11-10-2004, 10:13 AM   #161
Templar
Member Sales Rating: (3)
Member#: 483
2010 RSV4
Aprilia Racing Black
This is also possibly due to the fact that the D2s apparently have stiffer rebound damping than the JICs. We got two sets in, one was for the dealership sponsored car and was requested with extra rebound damping valved in. The other set was ordered to sell and had street rates and regular valving. Both sets have visibly higher rebound damping than the extra JIC struts I have lying around. So, when you lift a strut, it will take the suspension longer to extend fully than with the JICs since the JICs have ridiculously little rebound damping. This is also the main reason for the infamous JIC bounce.
Templar is offline   Reply With Quote
Old 11-10-2004, 10:15 AM   #162
afpdl
Member#: 26361
My shenanigans are
cheeky and fun
Thats about what it feels like. I went up 100lbs all around and the ride got much better then the jics.
Old 11-12-2004, 09:25 AM   #163
mr. m
Member#: 44229
2000 2.5 RS
blue ridge pearl
what spring length does everybody have on the front?
Old 11-15-2004, 11:40 PM   #164
swappedGF
Member#: 5075
98 v7 OBSTi
white/grey/gold
I was just wondering what spring rates everyone went with. I was thinking about 9kf/7kr. Or 8kf/7kr. I want a stiff sent up but still driveable. Roads arent too bad around me, unless i go into the city. But the idea behind the 8k/7k was that i want a stiff rear end to maybe be able to kick the rear out every now and again. But then again that could get me in some trouble. Tell me what you guys think about your or my setup plans.
Rudy
swappedGF is offline   Reply With Quote
Old 11-15-2004, 11:42 PM   #165
afpdl
Member#: 26361
My shenanigans are
cheeky and fun
The ride on 9/7 really isnt that bad. Its very firm but feels well matched to the struts, its not bouncy at all unless its a really big bump or pothole. But everyones idea of a decent ride is different.
Old 11-16-2004, 12:49 AM   #166
swappedGF
Member#: 5075
98 v7 OBSTi
white/grey/gold
But i was thinking, since you have an sti and i have a 2000 RS, yours is a bit heavier. Making the 9/7 a bit more intense. But I guess i forgot to mention my car.
Old 11-16-2004, 05:36 PM   #167
Grey Ghost
Member#: 43070
How long will the deal last? I am VERY interested, but I am little short of cash. Maybe by mid December I will have enough.
Grey Ghost is offline   Reply With Quote
Old 11-16-2004, 11:11 PM   #168
afpdl
Member#: 26361
My shenanigans are
cheeky and fun
nm..
Old 12-09-2004, 01:54 PM   #169
swappedGF
Member#: 5075
98 v7 OBSTi
white/grey/gold
So whos got updates on the coilovers? Anyone found some tricks to tuning them or anything? No problems? Just wanna know cause mine should be here in a few weeks. I'm driving a 00 RS if anyone has installation tips to make it easier on me. And i wanted to know for anyone who put them on themselves, did you then get the suspension aligned at a shop after installation?
Old 12-18-2004, 03:02 PM   #170
dippi
Member#: 44424
2007 Impreza WRX
dirtiest crystal grey
ok, wow, this looks like a great deal, so far it seems like everyone likes the coilovers. I was looking to get some soon. are the deals still available? I also autox, but on the d2 box it says for track racing cars only, is this just a slogan, or is this like something i should worry about, i drive my car on the street often, but i do go racing every month, and i do "spirited driving" alot, meaning all the time i am taking turns the way they should be taken .
will these coilovers be right for me, and is there a site i can look at that has all the info, like d2.com or something, and does the vendor have a site?
dippi is offline   Reply With Quote
Old 12-19-2004, 04:01 AM   #171
SubaFastR
Member#: 5786
While it's been a few years since I have worked on a car with coilovers, I have helped set up a few serious cars (think ALMS). The best way to establish pre-load is to install them on the car and then weight balance the car using a scale system from a company like Longacre Racing (pretty expensive). Weight balancing is the process of equalizing the weight of the vehicle on each of the tires. Any good race shop should be able to help you with this, if you don't mind paying the race shop hourly rate. Once the weight balancing is done (on a cool set of coilovers like this) then the ride height can be set (because these have the separate adjustment). This way the car's ride height can be set to look level as opposed to being crooked. If your going to mostly tracking the car, or doing any serious track events, I would suggest that you spend the time and money and set up the car this way.
The other way that I can think of - for anybody just trying to get by - would be to find the center point on the strut rod (half way between full compression and full droop). Then install the spring (just snug with the mounts), mark/measure the relative height of the assembly, then install them on the car. Of course you will want to have all the ride heights set the same for front or rear, so the LH rear is the same height initially as the RH rear, etc. Once installed on the car, lower the vehicle to the ground, drive it around the block (to get things to settle), then remeasure the the relative assembly height. Here you are checking to see how far the rod is from its center point. The objective behind the dual spring perch/ride height adjustment is to keep the piston rod in the center of its stroke under nominal conditions. If the rod has settled on way or the other, adjust the spring preload to compensate. Once this is done, you can adjust your ride height.
Now, having said all that, I won't be doing this until the spring, since it is now time to change back to winter tires. Please let me know - if you try this - if you run into any issues. Perhaps, we can rewrite the procedure.
Templar is correct, this is wrong. Back in the days before ride hight was adjustble seperate from preload, you would almost be right here. The problem is that what they were actually doing was shifting the weight of the car BY changing the ride hight. This is called cross weighting or corner weigting. Now that the two are seperate, preload can be set properly. For the most supple ride, just take out the slop between the spring and the perches.
SubaFastR is offline   Reply With Quote
Old 12-20-2004, 05:43 PM   #172
dippi
Member#: 44424
2007 Impreza WRX
is this deal still avaliable?
Old 12-20-2004, 06:44 PM   #173
afpdl
Member#: 26361
My shenanigans are
cheeky and fun
Am I the only one whose coilovers get noisy as hell in under 60 degree weather? Also Ive had the allen bolts that compress the lower strut body around the dampner loosen up all around the car, not really a big issue but its somthing to look out for.
Old 12-20-2004, 08:07 PM   #174
agterlik
Member#: 41626
SPB We make people
quit teh internet
Yeah mine are super noisy especially when it is below 3o. I am pretty sure its because they have the metal pillow ball joint.
Old 12-20-2004, 08:11 PM   #175
afpdl
Member#: 26361
My shenanigans are
cheeky and fun
Ive had 2 other coilovers all with pillowball joints and these are by far the noisiest.
FS: BC Racing Coilovers [05-07 STi] w/ Cusco Rear Camber Plates Angry Toaster SCIC Private Classifieds 15 03-30-2010 04:11 PM
STi 4-Way adjustable coilovers chazly413 Brakes, Steering & Suspension 10 12-01-2008 09:57 PM
K-Sport 36 way adjustable coilovers MEGA GROUP BUY! P&L Motorsports Inc. Vendor 'Group Buy' Classifieds 43 03-06-2006 12:03 PM
3 STi 4-way adjustable coilovers PolePosition08 Private 'For Sale' Classifieds 25 06-13-2005 05:28 PM
which are 2 ways adjustible coilovers? Hojai Brakes, Steering & Suspension 0 04-16-2002 02:58 PM
